<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[What does !TSP:MSG:PVER mismatch mean?]]></title><description><![CDATA[<p dir="auto">I have a DHT11 running for about 2 weeks now and suddenly the GW says the following lines over and over again:<br />
What does that mean?</p>
<pre><code>0;255;3;0;9;TSP:MSG:READ 101-101-101 s=101,c=5,t=101,pt=3,l=12,sg=1:25957
0;255;3;0;9;!TSP:MSG:PVER mismatch
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/4843/what-does-tsp-msg-pver-mismatch-mean</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 09:45:07 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/4843.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 13 Sep 2016 11:05:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Wed, 30 Nov 2016 09:18:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Ah ok, then I just have to wait for the stuff :) Thanks!</p>
]]></description><link>https://forum.mysensors.org/post/53596</link><guid isPermaLink="true">https://forum.mysensors.org/post/53596</guid><dc:creator><![CDATA[Daniel Eriksson]]></dc:creator><pubDate>Wed, 30 Nov 2016 09:18:25 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Wed, 30 Nov 2016 09:09:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daniel-eriksson" aria-label="Profile: Daniel-Eriksson">@<bdi>Daniel-Eriksson</bdi></a> said:</p>
<blockquote>
<p dir="auto">Using Arduino Mini Pro 5v - I do not have a Decoupling-Capacitor cause it hasnt been needed for 1.5 will that really be needed with 2.0?</p>
</blockquote>
<p dir="auto">Yes. Decoupling was needed for 1.5 as well, but in some cases people were lucky and it happened to work anyway. Being lucky can work with 2.0 as well, but relying on luck for your home automation is not recommended.</p>
]]></description><link>https://forum.mysensors.org/post/53595</link><guid isPermaLink="true">https://forum.mysensors.org/post/53595</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 30 Nov 2016 09:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Wed, 30 Nov 2016 08:33:23 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I am having exactly the same issue with 2.0, works fine with 1.5.</p>
]]></description><link>https://forum.mysensors.org/post/53594</link><guid isPermaLink="true">https://forum.mysensors.org/post/53594</guid><dc:creator><![CDATA[Daniel Eriksson]]></dc:creator><pubDate>Wed, 30 Nov 2016 08:33:23 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Mon, 10 Oct 2016 07:40:22 GMT]]></title><description><![CDATA[<p dir="auto">Thanks, I try it</p>
]]></description><link>https://forum.mysensors.org/post/49798</link><guid isPermaLink="true">https://forum.mysensors.org/post/49798</guid><dc:creator><![CDATA[Martin Tellblom]]></dc:creator><pubDate>Mon, 10 Oct 2016 07:40:22 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Mon, 10 Oct 2016 07:19:16 GMT]]></title><description><![CDATA[<p dir="auto">Try lowering pa -level</p>
<pre><code>#define MY_RF24_PA_LEVEL RF24_PA_LOW
or
#define MY_RF24_PA_LEVEL RF24_PA_MIN
</code></pre>
]]></description><link>https://forum.mysensors.org/post/49792</link><guid isPermaLink="true">https://forum.mysensors.org/post/49792</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Mon, 10 Oct 2016 07:19:16 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Mon, 10 Oct 2016 07:17:11 GMT]]></title><description><![CDATA[<p dir="auto">You mean the gateway I suppose? The radio is a NFR24L01+ with PA and LNA. a cap (right now the UNO is power by a computer USB port)</p>
]]></description><link>https://forum.mysensors.org/post/49791</link><guid isPermaLink="true">https://forum.mysensors.org/post/49791</guid><dc:creator><![CDATA[Martin Tellblom]]></dc:creator><pubDate>Mon, 10 Oct 2016 07:17:11 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Sun, 09 Oct 2016 19:50:17 GMT]]></title><description><![CDATA[<p dir="auto">The radio looks seriously broken or underpowered. I've seen similar results when trying to use an amplified radio (with high PA level) and supplying it with too little power.</p>
]]></description><link>https://forum.mysensors.org/post/49763</link><guid isPermaLink="true">https://forum.mysensors.org/post/49763</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Sun, 09 Oct 2016 19:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Sun, 09 Oct 2016 19:41:49 GMT]]></title><description><![CDATA[<pre><code>0;255;3;0;9;TSP:MSG:READ 101-101-101 s=101,c=5,t=101,pt=3,l=12,sg=1:25957
</code></pre>
<p dir="auto">This started today again and if I read the values correctly its a sensor with ID 101?</p>
<p dir="auto">What I can find I can decode this:<br />
TSF:MSG:READ,sender-last-destination,s=%d,c=%d,t=%d,pt=%d,l=%d,sg=%d:%s<br />
s=sensor ID<br />
c=command<br />
t=msg type<br />
pt=payload type<br />
l=length<br />
sg=signing flag</p>
<p dir="auto">But I can't find what the values mean.</p>
<p dir="auto">The other problem is that I do not have a sensor with id 101! I think this is something else that is messing with my radio.</p>
]]></description><link>https://forum.mysensors.org/post/49761</link><guid isPermaLink="true">https://forum.mysensors.org/post/49761</guid><dc:creator><![CDATA[Martin Tellblom]]></dc:creator><pubDate>Sun, 09 Oct 2016 19:41:49 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Wed, 14 Sep 2016 09:45:57 GMT]]></title><description><![CDATA[<p dir="auto">I restarted the sensor and it now works like a charm, haven't done anything to it.<br />
I have to wait another two weeks to see if it happens again</p>
<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> for the link ( I was looking for that the other day)</p>
]]></description><link>https://forum.mysensors.org/post/47659</link><guid isPermaLink="true">https://forum.mysensors.org/post/47659</guid><dc:creator><![CDATA[Martin Tellblom]]></dc:creator><pubDate>Wed, 14 Sep 2016 09:45:57 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Tue, 13 Sep 2016 21:03:58 GMT]]></title><description><![CDATA[<p dir="auto">It happens to me with an amplified version of nrf24. i change the module and works fine</p>
]]></description><link>https://forum.mysensors.org/post/47626</link><guid isPermaLink="true">https://forum.mysensors.org/post/47626</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Tue, 13 Sep 2016 21:03:58 GMT</pubDate></item><item><title><![CDATA[Reply to What does !TSP:MSG:PVER mismatch mean? on Tue, 13 Sep 2016 12:29:03 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html" rel="nofollow ugc">https://ci.mysensors.org/job/Verifiers/job/MySensorsArduino/branch/development/Doxygen_HTML/group__MyTransportgrp.html</a></p>
<p dir="auto">You seem to have some serious problems with your radio the data in the log looks corrupted. I.e. t=101...</p>
]]></description><link>https://forum.mysensors.org/post/47601</link><guid isPermaLink="true">https://forum.mysensors.org/post/47601</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Tue, 13 Sep 2016 12:29:03 GMT</pubDate></item></channel></rss>
