<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Getting !TSF:ASID:FAIL,ID=0 Error In 2.0 Beta]]></title><description><![CDATA[<p dir="auto">I just changed over to an Ethernet gateway and things are working except when I try to use my old Serial Gateway. The gateway I used for almost a year is a 5V pro-mini, worked great. I used a UNO for my Ethernet gateway and would like to use my old gateway as a temperature sensor. I cleared the eprom and loaded the same sketch I'm using on 3 other temp sensors but so far no matter what I do I get the following error.  The other temp sensors are a Nano and 2 UNO's.</p>
<p dir="auto">MCO:BGN:INIT NODE,CP=RNNNA--,VER=2.0.1-beta<br />
TSM:INIT<br />
TSM:INIT:TSP OK<br />
!TSF:ASID:FAIL,ID=0<br />
TSM:FAILURE<br />
TSM:FAILURE:PDT</p>
<p dir="auto">A NANO with the same Sketch starts up with this.</p>
MCO:BGN:BFR<br />
TSM:INIT<br />
TSF:ASID:OK,ID=1<br />
TSM:FPAR<br />
TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:<br />
TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=0:0<br />
TSF:MSG:FPAR RES,ID=0,D=0<br />
TSF:MSG:FPAR OK,ID=0,D=1<br />
TSM:FPAR:OK</p>
<p dir="auto">Right now I have everything the Vera and all the other sensors on my workbench so everything is really<br />
close. Any ideas?</p>
]]></description><link>https://forum.mysensors.org/topic/4953/getting-tsf-asid-fail-id-0-error-in-2-0-beta</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Mar 2026 17:38:58 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/4953.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Sep 2016 01:31:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Getting !TSF:ASID:FAIL,ID=0 Error In 2.0 Beta on Tue, 27 Sep 2016 02:07:48 GMT]]></title><description><![CDATA[<p dir="auto">I cleared the memory but not it seems with the MySensors Sketch so it didn't clear everything out. I ran the MySensors sketch today and everything works thanks.</p>
]]></description><link>https://forum.mysensors.org/post/48721</link><guid isPermaLink="true">https://forum.mysensors.org/post/48721</guid><dc:creator><![CDATA[RWoerz]]></dc:creator><pubDate>Tue, 27 Sep 2016 02:07:48 GMT</pubDate></item><item><title><![CDATA[Reply to Getting !TSF:ASID:FAIL,ID=0 Error In 2.0 Beta on Mon, 26 Sep 2016 05:58:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rwoerz" aria-label="Profile: RWoerz">@<bdi>RWoerz</bdi></a> The node that fails has previously been used as gateway (ID 0). You can either define a static ID or clear the eeprom using the MySensors clear eeprom sketch, and have the controller assigning a new ID.</p>
]]></description><link>https://forum.mysensors.org/post/48615</link><guid isPermaLink="true">https://forum.mysensors.org/post/48615</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Mon, 26 Sep 2016 05:58:22 GMT</pubDate></item><item><title><![CDATA[Reply to Getting !TSF:ASID:FAIL,ID=0 Error In 2.0 Beta on Mon, 26 Sep 2016 05:25:35 GMT]]></title><description><![CDATA[<p dir="auto">I plan to use it as a sensor to that talks to the ethernet gateway. Thanks for the help I'll you know.</p>
]]></description><link>https://forum.mysensors.org/post/48613</link><guid isPermaLink="true">https://forum.mysensors.org/post/48613</guid><dc:creator><![CDATA[RWoerz]]></dc:creator><pubDate>Mon, 26 Sep 2016 05:25:35 GMT</pubDate></item><item><title><![CDATA[Reply to Getting !TSF:ASID:FAIL,ID=0 Error In 2.0 Beta on Mon, 26 Sep 2016 06:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rwoerz" aria-label="Profile: RWoerz">@<bdi>RWoerz</bdi></a> for some reason the node is not happy with its assigned id. <a href="https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/4">https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help/4</a> has a link to information on how to read the debug output.</p>
<p dir="auto">Do you plan to use this node as a serial gateway still, or do you plan to use it as a node that connects to your ethernet gateway?</p>
]]></description><link>https://forum.mysensors.org/post/48610</link><guid isPermaLink="true">https://forum.mysensors.org/post/48610</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 26 Sep 2016 06:19:12 GMT</pubDate></item></channel></rss>
