<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[cannot compile new MQTT GW sketch]]></title><description><![CDATA[<p dir="auto">When trying to compile my MQTT Gateway sketch:</p>
<pre><code>/**
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Version 1.0 - Henrik Ekblad
 * The W5100 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
 * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
 * LED purposes:
 * nRF24L01+  ESP8266
 * VCC        VCC
 * CE         GPIO4
 * CSN/CS     GPIO15
 * SCK        GPIO14
 * MISO       GPIO12
 * MOSI       GPIO13
  * Inclusion mode button:
 * Make sure to fill in your ssid and WiFi password below for ssid &amp; pass.
// Set MQTT client id
//#define MY_W5100_SPI_EN 4
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) &amp;&amp; !defined(ARDUINO_ARCH_SAMD)
  #define MY_SOFTSPI
#ifndef MY_RF24_CE_PIN
  #define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
  #define MY_RF24_CS_PIN 6
#define MY_IP_ADDRESS 192,168,1,51
#define MY_IP_GATEWAY_ADDRESS 192,168,1,1
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 1, 50
#define MY_PORT 1883
// Enable inclusion mode
// Set blinking period
// Flash leds on rx/tx/err
#include &lt;Ethernet.h&gt;
#include &lt;MySensors.h&gt;
void presentation() {
</code></pre>
<p dir="auto">I am getting this error:</p>
<pre><code>
T:\Programme\Arduino 1.6.10\arduino-builder -dump-prefs -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -hardware "C:\Users\Cito\AppData\Local\Arduino15\packages" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -tools "C:\Users\Cito\AppData\Local\Arduino15\packages" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino"
T:\Programme\Arduino 1.6.10\arduino-builder -compile -logger=machine -hardware "T:\Programme\Arduino 1.6.10\hardware" -hardware "C:\Users\Cito\AppData\Local\Arduino15\packages" -tools "T:\Programme\Arduino 1.6.10\tools-builder" -tools "T:\Programme\Arduino 1.6.10\hardware\tools\avr" -tools "C:\Users\Cito\AppData\Local\Arduino15\packages" -built-in-libraries "T:\Programme\Arduino 1.6.10\libraries" -libraries "T:\Arduino Projekte\libraries" -fqbn=arduino:avr:uno -ide-version=10610 -build-path "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino"
Using board 'uno' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
Using core 'arduino' from platform in folder: T:\Programme\Arduino 1.6.10\hardware\arduino\avr
Warning: Board arduino:avr:apm96 doesn't define a 'build.board' preference. Auto-set to: AVR_APM96
Detecting libraries used...
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dhcp.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dhcp.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Dns.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\Ethernet.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetClient.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetServer.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\EthernetUdp.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\utility\socket.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "T:\Programme\Arduino 1.6.10\libraries\Ethernet\src\utility\w5100.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "nul"
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "T:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src\SPI.cpp" -o "nul"
Generating function prototypes...
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"T:\Programme\Arduino 1.6.10\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"T:\Programme\Arduino 1.6.10\hardware\tools\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10610 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR   "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\cores\arduino" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\variants\standard" "-IT:\Programme\Arduino 1.6.10\libraries\Ethernet\src" "-IT:\Programme\Arduino 1.6.10\libraries\MySensors" "-IT:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI\src" "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp" -o "C:\Users\Cito\AppData\Local\Temp\buildff641abe5d5d7a6894d7381b35e917c8.tmp\sketch\MQTTClientGateway_Ver_2.1.ino.cpp.o"
In file included from T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:23:0,
                 from T:\Programme\Arduino 1.6.10\libraries\MySensors/MySensors.h:261,
                 from T:\Arduino Projekte\MQTTClientGateway_Ver_2.1\MQTTClientGateway_Ver_2.1.ino:137:
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:34:31: error: 'SPI_MODE0' was not declared in this scope
 #define MY_RF24_SPI_DATA_MODE SPI_MODE0
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:76: note: in expansion of macro 'MY_RF24_SPI_DATA_MODE'
   SoftSPI&lt;MY_SOFT_SPI_MISO_PIN, MY_SOFT_SPI_MOSI_PIN, MY_SOFT_SPI_SCK_PIN, MY_RF24_SPI_DATA_MODE&gt; _SPI;
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:97: error: template argument 4 is invalid
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.h:38:103: error: invalid type in declaration before ';' token
In file included from T:\Programme\Arduino 1.6.10\libraries\MySensors/MySensors.h:261:0,
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp: In function 'uint8_t RF24_spiMultiByteTransfer(uint8_t, uint8_t*, uint8_t, bool)':
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:44:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
  uint8_t status = _SPI.transfer( cmd );
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:47:18: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
    status = _SPI.transfer( NOP );
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:49:24: error: request for member 'transfer' in '_SPI', which is of non-class type 'int'
   } else status = _SPI.transfer(*current++);
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp: In function 'bool RF24_initialize()':
T:\Programme\Arduino 1.6.10\libraries\MySensors/drivers/RF24/RF24.cpp:261:7: error: request for member 'begin' in '_SPI', which is of non-class type 'int'
  _SPI.begin();
Bibliothek Ethernet in Version 1.1.2 im Ordner: T:\Programme\Arduino 1.6.10\libraries\Ethernet  wird verwendet
Bibliothek MySensors in Version 2.0.0 im Ordner: T:\Programme\Arduino 1.6.10\libraries\MySensors  wird verwendet
Bibliothek SPI in Version 1.0 im Ordner: T:\Programme\Arduino 1.6.10\hardware\arduino\avr\libraries\SPI  wird verwendet
exit status 1
Fehler beim Kompilieren für das Board Arduino/Genuino Uno.
</code></pre>
<p dir="auto">Library is installed, using Arduino IDE 1.6.10. Any idea?</p>
]]></description><link>https://forum.mysensors.org/topic/5018/cannot-compile-new-mqtt-gw-sketch</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 19:51:55 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5018.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 04 Oct 2016 17:15:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to cannot compile new MQTT GW sketch on Wed, 05 Oct 2016 06:01:16 GMT]]></title><description><![CDATA[<p dir="auto">Mmh, thx, I just copied and pasted it from the instructions from the main page... So it must get corrected there as well...</p>
<p dir="auto">Thank you, I will try it later!</p>
<p dir="auto">edit:</p>
<p dir="auto">For the sake of completeness, I want to mention, that <a class="plugin-mentions-user plugin-mentions-a" href="/user/ernst79" aria-label="Profile: Ernst79">@<bdi>Ernst79</bdi></a> already gave the hint in the comments section of "Building a MQTT Gateway" Install-Instruction on the mainpage. I just did not see it, but I would love to see <a class="plugin-mentions-user plugin-mentions-a" href="/user/tbowmo" aria-label="Profile: tbowmo">@<bdi>tbowmo</bdi></a> to add this line to the code. Thank you!</p>
]]></description><link>https://forum.mysensors.org/post/49454</link><guid isPermaLink="true">https://forum.mysensors.org/post/49454</guid><dc:creator><![CDATA[siod]]></dc:creator><pubDate>Wed, 05 Oct 2016 06:01:16 GMT</pubDate></item><item><title><![CDATA[Reply to cannot compile new MQTT GW sketch on Tue, 04 Oct 2016 19:55:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/siod" aria-label="Profile: siod">@<bdi>siod</bdi></a> this line is missing</p>
<pre><code>#include &lt;SPI.h&gt;
</code></pre>
<p dir="auto">You need to add this line before these includes</p>
<pre><code>#include &lt;Ethernet.h&gt;
</code></pre>
]]></description><link>https://forum.mysensors.org/post/49443</link><guid isPermaLink="true">https://forum.mysensors.org/post/49443</guid><dc:creator><![CDATA[BartE]]></dc:creator><pubDate>Tue, 04 Oct 2016 19:55:37 GMT</pubDate></item></channel></rss>
