<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Replacing gateway doesn&#x27;t work with nodes that require signing]]></title><description><![CDATA[<p dir="auto">Hello there,</p>
<p dir="auto">I have two nodes that currently work with my serial gateway that is running on UNO. One node requires signing and the other does not. I wanted to replace my UNO gateway with Mini Pro. I have configured Mini Pro with the same SOFT_SERIAL, SOF_HMAC_KEY and AES_KEY but when I connect it instead of UNO I can only receive messages. Every message that I send (which require signing) are rejected by node that requires signing. What is it that I need to do to be able to replace my gateway?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mysensors.org/topic/5115/replacing-gateway-doesn-t-work-with-nodes-that-require-signing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 14:37:52 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5115.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 17 Oct 2016 14:40:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Replacing gateway doesn&#x27;t work with nodes that require signing on Fri, 21 Oct 2016 15:34:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/callah" aria-label="Profile: callah">@<bdi>callah</bdi></a> ah, good that you found the root cause. Yes, when signing is used the power supply becomes critical as the radio is stressed more by transmitting full length messages a lot more.</p>
]]></description><link>https://forum.mysensors.org/post/50846</link><guid isPermaLink="true">https://forum.mysensors.org/post/50846</guid><dc:creator><![CDATA[Anticimex]]></dc:creator><pubDate>Fri, 21 Oct 2016 15:34:08 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing gateway doesn&#x27;t work with nodes that require signing on Fri, 21 Oct 2016 15:26:22 GMT]]></title><description><![CDATA[<p dir="auto">I already tried that. I tried it again. Then I tried some more and figured it is some problem with power supply which prevents it to work when communicating with node that requires signing. It seems to work now. Thanks for your help.</p>
]]></description><link>https://forum.mysensors.org/post/50844</link><guid isPermaLink="true">https://forum.mysensors.org/post/50844</guid><dc:creator><![CDATA[callah]]></dc:creator><pubDate>Fri, 21 Oct 2016 15:26:22 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing gateway doesn&#x27;t work with nodes that require signing on Fri, 21 Oct 2016 07:49:10 GMT]]></title><description><![CDATA[<p dir="auto">Have you had your nodes present themselves to your new gateway. The gateway has to know that they require singing for it to sign anything. Enabling debug on your gateway probably information you if it understand your nodes require signing or not.</p>
]]></description><link>https://forum.mysensors.org/post/50820</link><guid isPermaLink="true">https://forum.mysensors.org/post/50820</guid><dc:creator><![CDATA[Anticimex]]></dc:creator><pubDate>Fri, 21 Oct 2016 07:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing gateway doesn&#x27;t work with nodes that require signing on Thu, 20 Oct 2016 19:00:34 GMT]]></title><description><![CDATA[<p dir="auto">Does anyone have any suggestion?</p>
]]></description><link>https://forum.mysensors.org/post/50771</link><guid isPermaLink="true">https://forum.mysensors.org/post/50771</guid><dc:creator><![CDATA[callah]]></dc:creator><pubDate>Thu, 20 Oct 2016 19:00:34 GMT</pubDate></item></channel></rss>
