<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How does a sensor 'deal' with another repeater]]></title><description><![CDATA[<p dir="auto">So, I added a new repeater this weekend.<br />
I have two repeaters now.<br />
Obviously they both have their own (hardcoded) ID.</p>
<p dir="auto">If I understand correct a sensor stores a default parent ID in memory.</p>
<p dir="auto">But what happens when I move the sensor to use another parent.<br />
Should the sensor update automagically or do I have to flush the old and set the new parent ID myself.</p>
<p dir="auto">So far I can't see the sensor returning in the network</p>
]]></description><link>https://forum.mysensors.org/topic/518/how-does-a-sensor-deal-with-another-repeater</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 07:49:55 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/518.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Oct 2014 10:26:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How does a sensor 'deal' with another repeater on Mon, 20 Oct 2014 21:48:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> That is what I thought and what I saw before. I will clear memory and see what happens. Thanks!</p>
]]></description><link>https://forum.mysensors.org/post/5854</link><guid isPermaLink="true">https://forum.mysensors.org/post/5854</guid><dc:creator><![CDATA[marceltrapman]]></dc:creator><pubDate>Mon, 20 Oct 2014 21:48:55 GMT</pubDate></item><item><title><![CDATA[Reply to How does a sensor 'deal' with another repeater on Tue, 21 Oct 2014 08:14:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> OK, I think that this is not how it goes.</p>
<p dir="auto">I moved a sensor from repeater 1 to repeater 2 without seeing it show up anymore.<br />
After removing the parent and the distance values from the eprom (what does the distance vaue say btw) the sensor showed up again using the new repeater.</p>
]]></description><link>https://forum.mysensors.org/post/5855</link><guid isPermaLink="true">https://forum.mysensors.org/post/5855</guid><dc:creator><![CDATA[marceltrapman]]></dc:creator><pubDate>Tue, 21 Oct 2014 08:14:35 GMT</pubDate></item><item><title><![CDATA[Reply to How does a sensor 'deal' with another repeater on Mon, 20 Oct 2014 17:45:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marceltrapman" aria-label="Profile: marceltrapman">@<bdi>marceltrapman</bdi></a> If a number of successive transmits to a parent fails the sensor will leave its parent and start searching for a new one.<br />
Another way to trigger this behavior is to clear the eeprom.</p>
]]></description><link>https://forum.mysensors.org/post/5830</link><guid isPermaLink="true">https://forum.mysensors.org/post/5830</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Mon, 20 Oct 2014 17:45:09 GMT</pubDate></item></channel></rss>
