<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Extending the Range of MySensor GateWay]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
Have a question about Mysensors.<br />
I have a Raspberry Pi 2 loading Domotics and GateWay uses native GPIO of Raspberry.<br />
I also have a Node with in 5-7 meter distance which works fine.<br />
My house is double story and I tried to test the access from far corner of second floor and have realized that the GateWay is not in range!</p>
<p dir="auto">My questions are:</p>
<ul>
<li>What is the best solution to extend the range</li>
<li>Can I use repeater to act to send and receive messages between GW and Nodes? Is that what the repeater does?</li>
<li>I am using "Wemos D1 Mini Pro version" as my nodes and wanna use it as repeater or maybe WiFI Gateway, whatever is right.Can I do that to extend the broadcasting of messages for further distances from main GatwWay?</li>
<li>The sample MySensors code does not compile if I enable the IP of GateWay to make the wifiGateway acts as client.<br />
Is there any guide help me to set it up if the Repeater/ESP8266 WiFiGateWay is the answer.</li>
</ul>
<p dir="auto">Many thanks for your help</p>
]]></description><link>https://forum.mysensors.org/topic/5282/extending-the-range-of-mysensor-gateway</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 02:05:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5282.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Nov 2016 23:03:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Extending the Range of MySensor GateWay on Sat, 12 Nov 2016 07:13:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sghazagh" aria-label="Profile: sghazagh">@<bdi>sghazagh</bdi></a> yes. It can be a wifi gateway with a sensor (for example a temperature sensor) wired directly to it, without any nrf or rfm radio.</p>
]]></description><link>https://forum.mysensors.org/post/52270</link><guid isPermaLink="true">https://forum.mysensors.org/post/52270</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sat, 12 Nov 2016 07:13:54 GMT</pubDate></item><item><title><![CDATA[Reply to Extending the Range of MySensor GateWay on Sat, 12 Nov 2016 01:08:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Thanks for your answers.<br />
This one made me curious : "The wemos/esp8266 can be used as a wifi gateway or as a repeater with non-wifi radio."</p>
<p dir="auto">Do you mean for Wemos D1, I do not need to attach Radio and it still can be used as a Node?</p>
]]></description><link>https://forum.mysensors.org/post/52260</link><guid isPermaLink="true">https://forum.mysensors.org/post/52260</guid><dc:creator><![CDATA[sghazagh]]></dc:creator><pubDate>Sat, 12 Nov 2016 01:08:03 GMT</pubDate></item><item><title><![CDATA[Reply to Extending the Range of MySensor GateWay on Fri, 11 Nov 2016 06:34:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sghazagh" aria-label="Profile: sghazagh">@<bdi>sghazagh</bdi></a> <a href="https://www.mysensors.org/about/network" rel="nofollow ugc">https://www.mysensors.org/about/network</a> and <a href="https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes" rel="nofollow ugc">https://www.mysensors.org/download/sensor_api_20#create-repeating-nodes</a> has information on how a MySensors network works. Start there and if there still are unanswered questions, just post them here.</p>
<p dir="auto">The best solution depends on a lot of factors, but repeaters or switching to radios with longer range is often the easiest solution. See the range troubleshooting flowchart on <a href="https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help">https://forum.mysensors.org/topic/666/debug-faq-and-how-ask-for-help</a><br />
Yes that is exactly what a repeater does<br />
The wemos/esp8266 can be used as a wifi gateway or as a repeater with non-wifi radio.<br />
The guide for buildning an esp8266 wifi gateway is at <a href="https://www.mysensors.org/build/esp8266_gateway" rel="nofollow ugc">https://www.mysensors.org/build/esp8266_gateway</a></p>
<p dir="auto">For the compilation - helping you is incredibly difficult without knowing what error message you got.</p>
]]></description><link>https://forum.mysensors.org/post/52171</link><guid isPermaLink="true">https://forum.mysensors.org/post/52171</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Fri, 11 Nov 2016 06:34:30 GMT</pubDate></item></channel></rss>
