<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UI5 to UI7 update]]></title><description><![CDATA[<p dir="auto">Hello,<br />
It's been a while since I have worked with my vera &amp; arduinos, moved to a new home. So I set up vera and decided to update to UI7.758. Everything transferred ok, however my arduino plugin did not recoginze the gateway - I have updated the plugin to v1.5, removed the device and created it again, configured the serial port. It gives me the can't detect device, I try to start the device an nothing happens. The gateway I am using is a Nano serial gateway. Any help would be appreciated</p>
]]></description><link>https://forum.mysensors.org/topic/5289/ui5-to-ui7-update</link><generator>RSS for Node</generator><lastBuildDate>Fri, 06 Nov 2026 22:22:06 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5289.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Nov 2016 06:43:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UI5 to UI7 update on Wed, 30 Nov 2016 07:12:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> Super!  Let us know if the final verification with an actual sensor works and feel free to ask questions if it doesn't.</p>
]]></description><link>https://forum.mysensors.org/post/53589</link><guid isPermaLink="true">https://forum.mysensors.org/post/53589</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Wed, 30 Nov 2016 07:12:51 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Wed, 30 Nov 2016 06:26:52 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
The checksum results look good..<br />
f9875310ea581c6384046dfd733dc5c9e436ef20  /etc/cmh-ludl/D_Arduino1.json.lzo<br />
e3c4493c7dff216c152b8a4d50c169acf636b1fc  /etc/cmh-ludl/D_Arduino1.xml.lzo<br />
8f0186c85c9a6ef6e0e8ba0755f88cbb5d326e30  /etc/cmh-ludl/D_ArduinoNode1.json.lzo<br />
7d66187bb75beb01606f607ad1e82a6fa6b2a552  /etc/cmh-ludl/D_ArduinoNode1.xml.lzo<br />
722b702937db7aedcb03346229fcc38363b2c378  /etc/cmh-ludl/D_ArduinoRelay1.json.lzo<br />
05ea89a8d904f436c60bd326315724e79c5c47de  /etc/cmh-ludl/D_ArduinoRelay1.xml.lzo<br />
ed15bfde68e6615b7615bd6230ca8040a50f5f28  /etc/cmh-ludl/I_Arduino1.xml.lzo<br />
2f0603b6192006f88e3582788a13a168391ceee4  /etc/cmh-ludl/L_Arduino.lua.lzo<br />
dc1e8a26833890f2d1f412c9b2e915724576cbd4  /etc/cmh-ludl/S_Arduino.xml.lzo<br />
64f886de376e2d932cd55bdf8a6367ed7a394d55  /etc/cmh-ludl/S_ArduinoNode.xml.lzo</p>
<p dir="auto">It does not look like there are any errors on the arduino plugin.. I need to dig ot one of my sensors and see if it is working correctly - thank  you for your help</p>
]]></description><link>https://forum.mysensors.org/post/53587</link><guid isPermaLink="true">https://forum.mysensors.org/post/53587</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Wed, 30 Nov 2016 06:26:52 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Tue, 29 Nov 2016 18:14:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> Ok, let's try to replace the existing plugin files by doing the following.</p>
<ol>
<li>ssh into your vera and remove the existing plugin by typing the following command</li>
</ol>
<p dir="auto"><code>rm /etc/cmh-ludl/*_Arduino*</code></p>
<ol start="2">
<li>
<p dir="auto">On your PC, download a .zip of the UI7 only branch from <a href="https://api.github.com/repos/mysensors/Vera/zipball/UI7" rel="nofollow ugc">https://api.github.com/repos/mysensors/Vera/zipball/UI7</a>  This will ensure that you are pulling the latest UI7 branch from GitHub (avoid git nuances).  The downloaded file should be named mysensors-Vera-73ed9b7.zip.  Unzip mysensors-Vera-73ed9b7.zip unless your browser unzips automatically.</p>
</li>
<li>
<p dir="auto">ssh into your vera and log the plugin output by entering the following command:</p>
</li>
</ol>
<pre><code>tail -f /var/log/cmh/LuaUPnP.log | grep Arduino
</code></pre>
<p dir="auto">This will log the output for the next step.</p>
<ol start="4">
<li>Using the Vera UI (Apps-&gt;Develop Apps-&gt;Luup files), upload the following plugin files to your Vera from the mysensors-Vera-73ed9b7 directory (be sure "Restart Luup after reload" is checked).</li>
</ol>
<pre><code>D_Arduino1.json
D_Arduino1.xml
D_ArduinoNode1.json
D_ArduinoNode1.xml
D_ArduinoRelay1.xml
I_Arduino1.xml
L_Arduino.lua
S_Arduino.xml
S_ArduinoNode.xml
</code></pre>
<ol start="5">
<li>Confirm the install versions by entering the following command:</li>
</ol>
<pre><code>sha1sum /etc/cmh-ludl/*_Arduino*
</code></pre>
<p dir="auto">Please post the results.</p>
<ol start="6">
<li>On your vera, confirm that the plugin initialized properly by looking at the log results from step 3. Please post the log results here.</li>
</ol>
<p dir="auto">Hopefully, the root cause is just a botched plugin install...  This should rule it out.</p>
]]></description><link>https://forum.mysensors.org/post/53564</link><guid isPermaLink="true">https://forum.mysensors.org/post/53564</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Tue, 29 Nov 2016 18:14:24 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Tue, 29 Nov 2016 05:42:29 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Thank you for your patience with this... It looks like the files match but some of the checksums do not. Below is what I found on my vera..<br />
6cde9f3c5f8d5eae74500ef237296e535344ee99  /etc/cmh-ludl/D_Arduino1.json.lzo<br />
b5b5dac4e0441c889fae60ef0db00f5b8b5ebf9e  /etc/cmh-ludl/D_ArduinoNode1.json.lzo<br />
ddc609fc75936e6ed586f25b880cee560250ab6b  /etc/cmh-ludl/L_Arduino.lua.lzo<br />
daba9c401302734735bdddeacd312f47ddcbabcd  /etc/cmh-ludl/S_Arduino.xml.lzo<br />
]]></description><link>https://forum.mysensors.org/post/53521</link><guid isPermaLink="true">https://forum.mysensors.org/post/53521</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Tue, 29 Nov 2016 05:42:29 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Sun, 27 Nov 2016 06:57:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> I am sorry you are still struggling with this but I am fairly certain we will figure it out.  Thanks for posting your logs they are and will be helpful.  It seems the plugin loads, purportedly connects to the serial port, requests the library version from the gateway but times out during lua_startup even though the gateway sends back version 1.4.1...  I know we covered this before I think at this point, we should definitely verify the plugin files installed on your Vera match mine by computing a shasum over them.  Please ssh to your vera and run <code>sha1sum /etc/cmh-ludl/*_Arduino*</code> and post the results here.  If the checksums don't match, then we will know what to do.  If they do match, then we will have definitively ruled out the plugin install and will have to dig further.</p>
</code></pre>
]]></description><link>https://forum.mysensors.org/post/53412</link><guid isPermaLink="true">https://forum.mysensors.org/post/53412</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Sun, 27 Nov 2016 06:57:37 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Sun, 27 Nov 2016 05:04:25 GMT]]></title><description><![CDATA[<p dir="auto">Hello<br />
So I was still unable to tell if the gateway is using a true FTDI chip, using the command lsusb -v -s 002:003.. I went through the process of setting up the gateway and reloaded the zwave engine - Below is the log for the Arduino gateway - There are a few areas that look significant but I pasted all the entries so nothing go missed.</p>
<p dir="auto">09      11/26/16 20:44:45.594   UserData::ParseRooms 13 Arduino &lt;0x2ab7a000&gt;<br />
10      11/26/16 20:44:45.672           Device 150 Description: Arduino Plugin &lt;0x2ab7a000&gt;<br />
10      11/26/16 20:44:45.904   Device_LuaUPnP::LoadDeviceDoc 150 file D_Arduino1.xml size 1034 result 0 &lt;0x2ab7a000&gt;<br />
10      11/26/16 20:44:45.905   Device_LuaUPnP::LoadDeviceDoc 150 file /etc/cmh-ludl//D_Arduino1.xml finished &lt;0x2ab7a000&gt;<br />
25      11/26/16 20:44:47.338   JobHandler_LuaUPnP::ParseAllImplementations parsed I_Arduino1.xml &lt;0x2ab7a000&gt;<br />
10      11/26/16 20:44:47.346   Device_LuaUPnP::MatchupImplementations device 150 using implementation: I_Arduino1.xml with 10 services &lt;0x2ab7a000&gt;<br />
25      11/26/16 20:44:49.894   LuaInterface::LuaInterface 0xc6ae20 device 150 Arduino Plugin &lt;0x2ab7a000&gt;<br />
25      11/26/16 20:44:49.921   LuaInterface::LuaInterface build device id's 0xc6ae20 device 150 Arduino Plugin &lt;0x2ab7a000&gt;<br />
25      11/26/16 20:44:49.922   LuaInterface::LuaInterface done 0xc6ae20 device 150 Arduino Plugin &lt;0x2ab7a000&gt;<br />
luup.log("Arduino plugin: loading library L_Arduino ...")<br />
package.loaded.L_Arduino = nil<br />
p = require("L_Arduino")<br />
if (package.loaded.L_Arduino == nil)<br />
luup.log("Arduino plugin: plugin is not installed correctly. Library L_Arduino cannot be loaded.", 1)<br />
luup.task("Plugin not correctly installed", 2, "Arduino plugin", -1)<br />
luup.log("Arduino plugin: library L_Arduino loaded")<br />
function SArduino_arduino1_SendCommand_job(lul_device,lul_settings,lul_job)<br />
function SArduino_arduino1_SetUnit_job(lul_device,lul_settings,lul_job)<br />
function SArduino_arduino1_StartInclusion_job(lul_device,lul_settings,lul_job)<br />
function SArduino_arduino1_StopInclusion_job(lul_device,lul_settings,lul_job)<br />
09      11/26/16 20:44:51.528   JobHandler_LuaUPnP::Run device 150 Arduino Plugin room 13 type urn:schemas-arduino-cc:device:arduino:1 cat 0:-1 id  parent 0/0xaaefa0 upnp: 0 plugin:0 pnp:0 mac: ip: &lt;0x2ab7a000&gt;<br />
50      11/26/16 20:44:55.247   luup_log:69: device # 150: supports Dimming1; set watch on variable 'LoadLevelTarget' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.248   luup_log:69: device # 150: supports HVAC_UserOperatingMode1; set watch on variable 'ModeTarget' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.250   luup_log:69: device # 150: supports HVAC_UserOperatingMode1; set watch on variable 'ModeStatus' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.251   luup_log:69: device # 150: supports HVAC_UserOperatingMode1; set watch on variable 'EnergyModeTarget' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.253   luup_log:69: device # 150: supports HVAC_UserOperatingMode1; set watch on variable 'EnergyModeStatus' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.254   luup_log:69: device # 150: supports HVAC_FanOperatingMode1; set watch on variable 'Mode' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.256   luup_log:69: device # 150: supports HVAC_FanOperatingMode1; set watch on variable 'FanStatus' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.257   luup_log:69: device # 150: supports TemperatureSetpoint1_Heat; set watch on variable 'CurrentSetpoint' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.259   luup_log:69: device # 150: supports TemperatureSetpoint1_Heat; set watch on variable 'SetpointTarget' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.260   luup_log:69: device # 150: supports TemperatureSetpoint1_Cool; set watch on variable 'CurrentSetpoint' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:55.262   luup_log:69: device # 150: supports TemperatureSetpoint1_Cool; set watch on variable 'SetpointTarget' for Arduino Plugin &lt;0x2b4ca680&gt;<br />
25      11/26/16 20:44:55.399   LuImplementation::StartLua device: 150 file:I_Arduino1.xml startup:startup pLuaInterface: 0xc6ae20 ip: 127.0.0.1 port 3481 protocol: (null) &lt;0x2b4ca680&gt;<br />
10      11/26/16 20:44:55.407   XXX-UpdateSystemMessagesTasks now 1=Arduino Plugin[150]: Opening IO Port timeout 0 (-1480221895) count: 6pend:Opening IO Port/err:(null)/done:(null) &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:44:55.411   XXX-UpdateSystemMessagesTasks now 1=Arduino Plugin[150]: Opening IO Port timeout 0 (-1480221895) count: 6pend:Opening IO Port/err:(null)/done:(null) &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:44:55.416   XXX-UpdateSystemMessagesTasks now 1=Arduino Plugin[150]: Opening IO Port timeout 0 (-1480221895) count: 6pend:Opening IO Port/err:(null)/done:(null) &lt;0x2b2ca680&gt;<br />
25      11/26/16 20:44:59.522   LuImplementation::StartLua running startup code for 150 I_Arduino1.xml &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.523   luup_log:150: Arduino plugin: loading library L_Arduino ... &lt;0x2b4ca680&gt;<br />
10      11/26/16 20:44:59.529   XXX-UpdateSystemMessagesTasks now 1=Arduino Plugin[150]: Running Lua Startup timeout 0 (-1480221899) count: 6pend:Running Lua Startup/err:(null)/done:(null) &lt;0x2b2ca680&gt;<br />
50      11/26/16 20:44:59.564   luup_log:150: Arduino plugin: library L_Arduino loaded &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.565   luup_log:150: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 150 &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.566   luup_log:150: Arduino: Trying for a serial connection &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.566   luup_log:150: Arduino: Serial port is connected &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.567   luup_log:150: Arduino: Baud is 115200 &lt;0x2b4ca680&gt;<br />
50      11/26/16 20:44:59.570   luup_log:150: Arduino: Sending: 0;0;3;0;2;Get Version &lt;0x2b4ca680&gt;<br />
10      11/26/16 20:44:59.579   XXX-UpdateSystemMessagesTasks now 1=Arduino Plugin[150]: Running Lua Startup timeout 0 (-1480221899) count: 6pend:Running Lua Startup/err:(null)/done:(null) &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:44:59.589   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
02      11/26/16 20:44:59.597   luup_log:150: Arduino: Incoming internal command '0;0;3;0;2;1.4.1' discarded for child: nil &lt;0x2e0ca680&gt;<br />
10      11/26/16 20:44:59.609   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:44:59.661   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:44:59.667   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:45:27.112   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
00      11/26/16 20:45:27.385   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'LoadLevelStatus' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.387   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'LoadLevelTarget' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.389   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'ModeTarget' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.390   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'ModeStatus' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.392   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'EnergyModeTarget' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.394   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'EnergyModeStatus' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.396   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'Mode' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.398   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'FanStatus' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.400   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'CurrentSetpoint' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.402   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'SetpointTarget' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.404   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'CurrentSetpoint' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
00      11/26/16 20:45:27.405   luup_log:69: EchoEnergyManager::ERROR:   ergy_pollDevices: FAILED to retrieve 'SetpointTarget' for  Arduino Plugin device # 150 &lt;0x2c2ca680&gt;<br />
10      11/26/16 20:45:38.184   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;<br />
10      11/26/16 20:46:03.321   XXX-UpdateSystemMessagesTasks StartupTask #5 = 4 OK / Arduino Plugin[150] &lt;0x2b2ca680&gt;</p>
]]></description><link>https://forum.mysensors.org/post/53411</link><guid isPermaLink="true">https://forum.mysensors.org/post/53411</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Sun, 27 Nov 2016 05:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Fri, 18 Nov 2016 19:34:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> the command I suggested you use is <code>lsusb -v -s 002:003</code>, not <code>lsusb -v -3 002:003</code>?</p>
<p dir="auto">Looking forward to your results after the troubleshooting steps...</p>
]]></description><link>https://forum.mysensors.org/post/52782</link><guid isPermaLink="true">https://forum.mysensors.org/post/52782</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Fri, 18 Nov 2016 19:34:10 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Fri, 18 Nov 2016 19:31:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blacey" aria-label="Profile: blacey">@<bdi>blacey</bdi></a><br />
I will go through the steps to connect the gateway and then get the logs..</p>
<p dir="auto">When I send the command lsusb -v -3 002:003 It just returns the list of the 3 devices..</p>
<p dir="auto">Bus 001 Device 001: ID 1d6b:0002<br />
Bus 002 Device 001: ID 1d6b:0001<br />
Bus 002 Device 003: ID 0403:6001</p>
]]></description><link>https://forum.mysensors.org/post/52781</link><guid isPermaLink="true">https://forum.mysensors.org/post/52781</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Fri, 18 Nov 2016 19:31:11 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Fri, 18 Nov 2016 05:59:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> No need to apologize - we are trying to get to the root cause.  What happens if you use the command <code>lsusb -v -s 002:003</code>?  I suspect that will show you the FTDI device details because it has the id 0403:6001.  If that is the case, then I suggest that you try the troubleshooting directions posted here - <a href="https://www.mysensors.org/controller/vera" rel="nofollow ugc">https://www.mysensors.org/controller/vera</a>  To paraphrase, the steps are:</p>
<ol>
<li>Unplug the MySensors gateway from the Vera USB port</li>
<li>Restart the Vera LUUP Engine (Settings-&gt;Z-Wave Settings-&gt;Reload Engine)</li>
<li>Plug gateway into the Vera USB port</li>
<li>Re-configure serial port as described above (typically, you only need to reset the baud rate to 115200)</li>
</ol>
<p dir="auto">Now that you have ssh access to your Vera, it is also helpful to view the log entries using the command <code>tail -f /var/log/cmh/LuaUPnP.log | grep Arduino</code> on your Vera while performing the steps above.  For example, when I reload the LUUP Engine on my Vera Plus running UI7, I see the following in my logs:</p>
<pre><code>50	11/17/16 21:57:07.212	luup_log:47: Arduino plugin: loading library L_Arduino ... &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.235	luup_log:47: Arduino plugin: library L_Arduino loaded &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.235	luup_log:47: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,PluginVersion, 1.5, 47 &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.236	luup_log:47: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, -, 47 &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.236	luup_log:47: Arduino: Trying for a serial connection &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.236	luup_log:47: Arduino: Serial port is connected &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.237	luup_log:47: Arduino: Baud is 115200 &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.237	luup_log:47: Arduino: urn:upnp-arduino-cc:serviceId:arduino1,GWAddress, 91(115200), 47 &lt;0x76ef7520&gt;
50	11/17/16 21:57:07.239	luup_log:47: Arduino: Sending: 0;0;3;0;2;Get Version &lt;0x76ef7520&gt;
</code></pre>
<p dir="auto">What are you seeing?</p>
]]></description><link>https://forum.mysensors.org/post/52729</link><guid isPermaLink="true">https://forum.mysensors.org/post/52729</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Fri, 18 Nov 2016 05:59:41 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Fri, 18 Nov 2016 05:09:03 GMT]]></title><description><![CDATA[<p dir="auto">Hello Blacey,<br />
Sorry for all the replys.. I got as far as listing the devices, I couldnt't get the details.. This is what I show for connect devices..</p>
<p dir="auto">when I try the -v -s commands it returns the same list.</p>
]]></description><link>https://forum.mysensors.org/post/52727</link><guid isPermaLink="true">https://forum.mysensors.org/post/52727</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Fri, 18 Nov 2016 05:09:03 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Thu, 17 Nov 2016 21:57:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a> You will need to ssh into your vera using the password on the bottom of the unit.  On macOS or Linux, you would <code>ssh root@&lt;vera ip address&gt;</code> without the &lt; or &gt;.  On Windows you will need to use an ssh client such as PuTTY which is free.  Enter the password on the bottom of the unit when prompted.  Here is a <a href="http://wiki.micasaverde.com/index.php/Logon_Vera_SSH" rel="nofollow ugc">Micasaverde Wiki article</a> on connecting to your Vera.</p>
<p dir="auto">Once you have connected, in the shell, just enter the commands as I did.  To list your usb devices, use <code>lsusb</code>.  If you see an FTDI device (Future Technology Devices International), you can list the details by using <code>lsusb -v -s &lt;Bus&gt;:&lt;Device&gt;</code> without the &lt; or &gt;.  For example, on mine, the FTDI devices is on Bus 001, Device 006 so I used <code>lsusb -v -s 001:006</code>.</p>
<p dir="auto">Give it a try and if you run into problems, post back here.  It would be good to see the output of your devices.</p>
]]></description><link>https://forum.mysensors.org/post/52715</link><guid isPermaLink="true">https://forum.mysensors.org/post/52715</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Thu, 17 Nov 2016 21:57:33 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Thu, 17 Nov 2016 18:58:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I am fairly sure it's a Nano clone for my gateway.. Within the serial port settings in vera it sees the device and the light is flashing on the vera as if it's communicating with gateway. How do I view the port settings / USB devices as you have detailed? I want to check and see if the gateway shows up as a FTDI device.</p>
]]></description><link>https://forum.mysensors.org/post/52703</link><guid isPermaLink="true">https://forum.mysensors.org/post/52703</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Thu, 17 Nov 2016 18:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Tue, 15 Nov 2016 05:32:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/grb" aria-label="Profile: GRB">@<bdi>GRB</bdi></a></p>
<ol>
<li>Ok, are you using a genuine nano or a clone?  I know others have reported issues with certain clones being recognized.  Logging into my VeraPlus and listing the usb devices, I see the following:</li>
</ol>
<pre><code>root@OpenWrt:~# lsusb
Bus 001 Device 002: ID 05e3:0610 Genesys Logic, Inc. 4-port hub
Bus 001 Device 003: ID 0e8d:7662 MediaTek Inc.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Bus 001 Device 007: ID 0781:5571 SanDisk Corp. Cruzer Fit
</code></pre>
<p dir="auto">The nano shows up as an FTDI device - 006 on bus 001.  Here are the details for the nano...</p>
<pre><code>root@OpenWrt:~# lsusb -v -s 001:006
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0         8
  idVendor           0x0403 Future Technology Devices International, Ltd
  idProduct          0x6001 FT232 USB-Serial (UART) IC
  bcdDevice            6.00
  iManufacturer           1 FTDI
  iProduct                2 FT232R USB UART
  iSerial                 3 A7036KQ4
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           32
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0xa0
      (Bus Powered)
      Remote Wakeup
    MaxPower               90mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass    255 Vendor Specific Subclass
      bInterfaceProtocol    255 Vendor Specific Protocol
      iInterface              2 FT232R USB UART
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
Device Status:     0x0000
  (Bus Powered)
</code></pre>
<p dir="auto">What do you see when you log into your Vera and list the USB devices?</p>
<ol start="2">
<li>If the nano is visible on the usb bus as described above, perhaps you should try a powered USB hub to ensure that ample power is delivered to the nano.</li>
</ol>
]]></description><link>https://forum.mysensors.org/post/52490</link><guid isPermaLink="true">https://forum.mysensors.org/post/52490</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Tue, 15 Nov 2016 05:32:27 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Mon, 14 Nov 2016 02:31:53 GMT]]></title><description><![CDATA[<p dir="auto">Hello,<br />
Yes used the zip file in the UI7 branch, looks like the file dates are 3/16/2016.. The version on the plugin is v1.5</p>
]]></description><link>https://forum.mysensors.org/post/52404</link><guid isPermaLink="true">https://forum.mysensors.org/post/52404</guid><dc:creator><![CDATA[GRB]]></dc:creator><pubDate>Mon, 14 Nov 2016 02:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to UI5 to UI7 update on Sun, 13 Nov 2016 06:32:51 GMT]]></title><description><![CDATA[<p dir="auto">Did you update your plugin using the <a href="https://github.com/mysensors/Vera/tree/UI7" rel="nofollow ugc">UI7 branch</a>?</p>
]]></description><link>https://forum.mysensors.org/post/52315</link><guid isPermaLink="true">https://forum.mysensors.org/post/52315</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Sun, 13 Nov 2016 06:32:51 GMT</pubDate></item></channel></rss>
