<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] TSP:CHKUPL:FAIL and TSM:FPAR:FAIL]]></title><description><![CDATA[<p dir="auto">Unable to connect the node to my gateway.<br />
I use "MockMySensors" sketch with these additional lines</p>
<pre><code>#define MY_NODE_ID 17
#define MY_PARENT_NODE_ID  0
</code></pre>
<p dir="auto">I also use "GatewaySerial" sketch for my gateway.<br />
Here is what I get in debug</p>
<pre><code>TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSP:ASSIGNID:OK (ID=17)
TSM:FPAR
TSP:MSG:SEND 17-17-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
TSM:FPAR
TSM:FPAR
TSM:FPAR
!TSM:FPAR:FAIL
!TSM:FAILURE
TSM:PDT
TSM:INIT
TSM:RADIO:OK
TSM:FPAR
TSM:FPAR
TSM:FPAR
TSP:MSG:READ 0-0-17 s=255,c=3,t=8,pt=1,l=1,sg=0:0
TSP:MSG:FPAR (PPAR FOUND)
TSP:MSG:PAR OK (ID=0, dist=1)
TSM:FPAR:OK
TSM:ID
TSM:CHKID:OK (ID=17)
TSM:UPL
TSP:PING:SEND (dest=0)
!TSP:MSG:SEND 17-17-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=fail:1
TSP:CHKUPL:FAIL (hops=255)
!TSM:UPL:FAIL
TSM:FPAR
TSM:FPAR:OK
TSM:ID
TSM:UPL
!TSM:UPL:FAIL
TSM:FPAR
TSM:FPAR:OK
TSM:ID
TSM:UPL
!TSM:UPL:FAIL
TSM:FPAR
TSM:FPAR
TSM:FPAR
TSM:FPAR
</code></pre>
<pre><code>0;255;3;0;9;Starting gateway (RNNGA-, 2.0.0)
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSM:RADIO:OK
0;255;3;0;9;TSM:GW MODE
0;255;3;0;9;TSM:READY
0;255;0;0;18;2.0.0
0;255;3;0;9;Init complete, id=0, parent=0, distance=0, registration=1```</code></pre>
]]></description><link>https://forum.mysensors.org/topic/5400/solved-tsp-chkupl-fail-and-tsm-fpar-fail</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 15:27:53 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5400.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 26 Nov 2016 15:04:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] TSP:CHKUPL:FAIL and TSM:FPAR:FAIL on Sun, 27 Nov 2016 09:49:13 GMT]]></title><description><![CDATA[<p dir="auto">Fixed by switching 4.7uF capacitors with 10uF capacitors.</p>
]]></description><link>https://forum.mysensors.org/post/53418</link><guid isPermaLink="true">https://forum.mysensors.org/post/53418</guid><dc:creator><![CDATA[Nikita]]></dc:creator><pubDate>Sun, 27 Nov 2016 09:49:13 GMT</pubDate></item></channel></rss>
