<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem with RFM69 on Arduino nano...]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Since this is my first post I would like to congratulate all mysensors community for the fantastic work.</p>
<p dir="auto">I've been running some prototypes of sensor nodes using standalone ESP8266 as node/gateway with no major problems.<br />
But now, I've ordered some RFM69 modules to start building a sensor network and I'm having trouble getting mysensors to work in a particular combination: Arduino Nano and RFM69HCW (Adafruit 5v safe breakout).</p>
<p dir="auto">Using test sketches from the RFM69 library everything works fine (on the other end I have an 3.3v arduino pro mini with a RFM69 module) but from mysensors I only get this output:</p>
<p dir="auto">0;255;3;0;9;MCO:BGN:INIT GW,CP=RRNGA--,VER=2.0.1-beta<br />
0;255;3;0;9;TSM:INIT<br />
0;255;3;0;9;!TSM:INIT:TSP FAIL<br />
0;255;3;0;9;TSM:FAIL:CNT=1<br />
0;255;3;0;9;TSM:FAIL:PDT<br />
0;255;3;0;9;TSM:FAIL:RE-INIT<br />
0;255;3;0;9;TSM:INIT</p>
<p dir="auto">I've tried to replace the default RFM69 driver with the version from LowPower Labs with no success.</p>
<p dir="auto">The strange is that the very same code uploaded to an arduino pro mini works fine.</p>
<p dir="auto">What can it be?</p>
]]></description><link>https://forum.mysensors.org/topic/5462/problem-with-rfm69-on-arduino-nano</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 15:25:21 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5462.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Dec 2016 13:57:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Sun, 09 Apr 2017 19:15:14 GMT]]></title><description><![CDATA[<p dir="auto">Ah! I never thought of that. Nice to see it's solved! And I think you're right, this kind of info should be made available for easy access.</p>
]]></description><link>https://forum.mysensors.org/post/64285</link><guid isPermaLink="true">https://forum.mysensors.org/post/64285</guid><dc:creator><![CDATA[DavidZH]]></dc:creator><pubDate>Sun, 09 Apr 2017 19:15:14 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Sat, 08 Apr 2017 12:20:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidzh" aria-label="Profile: DavidZH">@<bdi>DavidZH</bdi></a><br />
I finally figured it out, after some forum digging. Check <a href="https://forum.mysensors.org/topic/5806/solved-adafruit-rfm69hcw-breakout-doesnt-respond">https://forum.mysensors.org/topic/5806/solved-adafruit-rfm69hcw-breakout-doesnt-respond</a>.</p>
<p dir="auto">These things should be sticky'ed somewhere, would have saved me a lot of time ;-)</p>
]]></description><link>https://forum.mysensors.org/post/64176</link><guid isPermaLink="true">https://forum.mysensors.org/post/64176</guid><dc:creator><![CDATA[Alpoy]]></dc:creator><pubDate>Sat, 08 Apr 2017 12:20:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Fri, 07 Apr 2017 21:46:47 GMT]]></title><description><![CDATA[<p dir="auto">If the message says: TSP FAIL there is no communication between your Arduino and the RFM, you need to check your wires, which is strange as you have success with that other lib. Have you commented the right <code>#defines</code> before the <code>include &lt;mysensors.h&gt;</code>?</p>
]]></description><link>https://forum.mysensors.org/post/64162</link><guid isPermaLink="true">https://forum.mysensors.org/post/64162</guid><dc:creator><![CDATA[DavidZH]]></dc:creator><pubDate>Fri, 07 Apr 2017 21:46:47 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Fri, 07 Apr 2017 05:40:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fcflopes" aria-label="Profile: fcflopes">@<bdi>fcflopes</bdi></a> did you ever figure this one out? I'm having the same problem on an UNO.<br />
I'm using a <a href="https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/overview?view=all" rel="nofollow ugc">RFM69HCW from Adafruit</a>, which works fine with the <a href="https://learn.adafruit.com/adafruit-rfm69hcw-and-rfm96-rfm95-rfm98-lora-packet-padio-breakouts/overview?view=all#rfm9x-test" rel="nofollow ugc">Radiohead/Adafruit test lib</a> but I only get TSP FAIL when using a mysensor serial GW sketch.</p>
]]></description><link>https://forum.mysensors.org/post/64117</link><guid isPermaLink="true">https://forum.mysensors.org/post/64117</guid><dc:creator><![CDATA[Alpoy]]></dc:creator><pubDate>Fri, 07 Apr 2017 05:40:38 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Tue, 06 Dec 2016 11:53:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fcflopes" aria-label="Profile: fcflopes">@<bdi>fcflopes</bdi></a> - ok, sorry im not into RFM but maybe <a class="plugin-mentions-user plugin-mentions-a" href="/user/scalz" aria-label="Profile: scalz">@<bdi>scalz</bdi></a>  know more?</p>
]]></description><link>https://forum.mysensors.org/post/53956</link><guid isPermaLink="true">https://forum.mysensors.org/post/53956</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Tue, 06 Dec 2016 11:53:31 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Tue, 06 Dec 2016 11:10:22 GMT]]></title><description><![CDATA[<p dir="auto">I also suspected that so I've powered the module from another power supply (and connected all the grounds).</p>
<p dir="auto">Still the same result.</p>
<p dir="auto">I still can't figure is why this only happens with MySensors... Test sketches run ok...</p>
]]></description><link>https://forum.mysensors.org/post/53953</link><guid isPermaLink="true">https://forum.mysensors.org/post/53953</guid><dc:creator><![CDATA[fcflopes]]></dc:creator><pubDate>Tue, 06 Dec 2016 11:10:22 GMT</pubDate></item><item><title><![CDATA[Reply to Problem with RFM69 on Arduino nano... on Tue, 06 Dec 2016 08:41:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/fcflopes" aria-label="Profile: fcflopes">@<bdi>fcflopes</bdi></a> - Power?</p>
]]></description><link>https://forum.mysensors.org/post/53939</link><guid isPermaLink="true">https://forum.mysensors.org/post/53939</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Tue, 06 Dec 2016 08:41:21 GMT</pubDate></item></channel></rss>
