<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Chicken house door controller (beta)]]></title><description><![CDATA[<p dir="auto">Hi guys. I have just finished a chickenhouse and am in the throes of automating the door. It will be controlled by domoticz and I plan to open 1/2 hour after sunrise and close 1/2 hour after sunset. The door will be driven by an electric antenna from the car wreckers, 12V battery and solar panel/controller.<br />
There are two reed switches to tell position of the door plus a button to manually open/close or reset a jam (for increased WAF).<br />
I have included in the sketch a bit to jiggle the door if it gets stuck, and turn off the actuator and send an alert to domoticz if the jam cannot be freed.<br />
I have yet to try it out as am waiting on the usual final component I only realised I would need once I started building (buck converter).<br />
Anyway code is below. mfalkvidd has kindly looked at it for me already. I believe it should work but am open to critiquing on any part of my coding including conventions.<br />
Thanks,<br />
Matt</p>
<pre><code>/**
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Chicken door controller
#include &lt;MySensors.h&gt;
#include &lt;Bounce2.h&gt;
#define MOTORSW     3  // Motor activation pin
#define MOTORPWR    4  // Motor power lead pin
#define REED_OPEN   5  // Reed switch pin, pulled low when door is open
#define REED_CLOSED 6  // Reed switch pin, pulled low when door is closed
#define MANUALSW    7  // Momentary switch to control door
bool DoorState;        // 0 closed, 1 open
bool PrevState;        // Used to check for stated change
byte jammed=0;
unsigned long timer;   // Counter to check door closes in time ie isn't jammed.
Bounce debouncer = Bounce();
MyMessage msg(2,V_TRIPPED);
    pinMode(MOTORSW,     OUTPUT);
    pinMode(MOTORPWR,    OUTPUT);
    pinMode(REED_OPEN,   INPUT_PULLUP);   // Using internal pullup. When read switch is closed, will pull this pin to ground.
    pinMode(REED_CLOSED, INPUT_PULLUP);   // Ditto
    pinMode(MANUALSW, INPUT_PULLUP);      // Turn on pullup for switch, will be pulled low when pushed
    DoorState = loadState(1);
    PrevState = DoorState;
    debouncer.attach(MANUALSW);
    debouncer.interval(50);
  sendSketchInfo("ChickenDoor", "1.0");  // Send the sketch version information to the gateway and Controller
  present(1, S_BINARY);  // Register door actuator to Gateway
  present(2, S_DOOR); // This will go on if door is jammed
  debouncer.update();
  int value = debouncer.read();
  if (value == LOW) {
    DoorState = !DoorState;
    jammed==0;   // Reset the jam
    send(msg.set(LOW));
  if ((DoorState != PrevState) &amp;&amp; (jammed &lt; 2)) {       //Something has changed and door isn't jammed
    switch(DoorState) {
       case 0: // Close Door
        timer = millis();
        while( digitalRead(REED_CLOSED)==HIGH) {  //Drive actuator until door closes then stop
           digitalWrite(MOTORPWR, HIGH);   //Turn on the actuator
           wait(50);   // Actuator wakes up
           digitalWrite(MOTORSW, HIGH);  //Close the door
           if (millis() - timer &gt; 5000) {   //door is jammed
            jammed++;
            jiggle(); //open and close again
            break;
           digitalWrite(MOTORSW, LOW); //Door is closed, turn off actuator switch
           digitalWrite(MOTORPWR, LOW); //Door is closed, turn off actuator
           jammed=0;
        break;
       case 1: // Open Door
        timer = millis();
        while( digitalRead(REED_OPEN)==HIGH) {  //Drive actuator until door opens then stop
           digitalWrite(MOTORSW, HIGH); //Wake up the actuator
           wait(100);
           digitalWrite(MOTORSW, LOW); //Close the door
            jammed++;
            jiggle();
            break;
           jammed=0;
          break;
    else if (jammed &gt;= 2) {
      send(msg.set(HIGH));
void receive(const MyMessage &amp;message) {
  if (message.type==V_STATUS) {                     // We only expect one type of message from controller. But we better check anyway.
     DoorState = message.getBool();
     saveState(1, message.getBool());               // Store state in eeprom
     Serial.print("Incoming change for sensor:");   // Write some debug info
     Serial.print(message.sensor);
void jiggle()  //J j j jiggle it a bit (4 times)
{ for(int x = 0; x &lt; 4 ; x++) {
  wait(500);
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/5584/chicken-house-door-controller-beta</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 09:30:59 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5584.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Dec 2016 16:40:00 GMT</pubDate><ttl>60</ttl></channel></rss>
