<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LIVOLO alike switch mod]]></title><description><![CDATA[<p dir="auto">Hi!! Good to see so many people with common interests!</p>
<p dir="auto">I've seen there's another thread about touch switches but did not find info about what I want to work out.</p>
<p dir="auto">I have two 1 gang &amp; 1 way touch switches that look like LIVOLO's but the brand is not printed in the glass. I did realized that the PCBs are ready for more comps so I guess several models share PCB. The idea is to mod theses 1 way switches so they can be used as 2 way based in their net connections A &amp; B. In order to do this the most important point would be that the PIC firmware is the same loaded in other models like a 2 way......which would make sense in order to reduce production cost. Here follows some pics of the PCBs.<br />
<img src="/uploads/files/1483534444482-img_1.jpg" alt="0_1483534434735_IMG_1.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1483534458562-img_2.jpg" alt="0_1483534449010_IMG_2.jpg" class=" img-fluid img-markdown" /><br />
<img src="/uploads/files/1483534474823-img_3.jpg" alt="0_1483534465162_IMG_3.jpg" class=" img-fluid img-markdown" /><br />
As you might see in the last pic I have encircled the two comps added so far: connector for A&amp;B and a resistor (small circle) in the trace of B. As you know connection A is just L in order to feed the other switches.</p>
<p dir="auto">I connect them and tray to synchro with no results, the slave one just show intermitent the blue and red leds and the master did nothing when touching it the 5 seconds required. I have to add a buzzer to the PCB to make sure there is no audio signaling.<br />
I did not have too much time yet to keep investigating but firstly  I want to reduce the added resistor since I guess is to high for a logic level to be reached, from 22K to at least 1K. Also trace B connection injecting low freq signal, in order to find out if it reachs the PIC and add the buzzer. I want to backup the firm also just in case......<br />
Any suggestion or help is always welcome. Anyone who has this switch but being 2 way etc.</p>
]]></description><link>https://forum.mysensors.org/topic/5697/livolo-alike-switch-mod</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 02:50:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5697.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 04 Jan 2017 13:04:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LIVOLO alike switch mod on Fri, 06 Jan 2017 11:25:29 GMT]]></title><description><![CDATA[<p dir="auto"><a href="https://forum.mysensors.org/topic/5719/livolo-eu-switch-mysensors-integration">https://forum.mysensors.org/topic/5719/livolo-eu-switch-mysensors-integration</a> might be useful</p>
]]></description><link>https://forum.mysensors.org/post/56286</link><guid isPermaLink="true">https://forum.mysensors.org/post/56286</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Fri, 06 Jan 2017 11:25:29 GMT</pubDate></item><item><title><![CDATA[Reply to LIVOLO alike switch mod on Wed, 04 Jan 2017 17:14:27 GMT]]></title><description><![CDATA[<p dir="auto">All those connectors everywhere look messy. Soldering on the main connectors looks pretty low standard too :o</p>
<p dir="auto">Are you sure it would not be a better idea to "invest" 14$/13€ in real Livolo double switches  (discounted price for white one right now on aliexpress) which are of much better quality ? Then you can make a clean PCB board (or upgrade as seen in other thread) to replace the original livolo one to have a MySensors version.</p>
]]></description><link>https://forum.mysensors.org/post/56090</link><guid isPermaLink="true">https://forum.mysensors.org/post/56090</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Wed, 04 Jan 2017 17:14:27 GMT</pubDate></item></channel></rss>
