<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MySensors node doesn’t appear in Jeedom]]></title><description><![CDATA[<p dir="auto">Hi,<br />
After installing MySenor plugin on Jeedom, I switched a serial gateway arduino on my raspberry, and send messages by an arduino (value 1 and 0 every 10 seconds).</p>
<p dir="auto">I see it in MySensorsLog in my plugin jeedom interface :<br />
<em>Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - Jeedom url : <a href="http://192.168.0.49:80/plugins/mySensors/core/api/jeeSensors.php?apikey=(...)" rel="nofollow ugc">http://192.168.0.49:80/plugins/mySensors/core/api/jeeSensors.php?apikey=(...)</a>, gwAddress : /dev/ttyUSB0<br />
DEPRECATION: Please use <code>require('serialport')</code> instead of <code>require('serialport').SerialPort</code><br />
Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - server bound on 8019<br />
Thu Jan 05 2017 11:05:54 GMT+0000 (UTC) - connected to serial gateway at /dev/ttyUSB0<br />
Thu Jan 05 2017 11:05:55 GMT+0000 (UTC) : 0;0;3;0;9;gateway started, id=0, parent=0, distance=0<br />
Thu Jan 05 2017 11:05:55 GMT+0000 (UTC) : 0;0;3;0;14;Gateway startup complete.<br />
Thu Jan 05 2017 11:05:59 GMT+0000 (UTC) : 0;0;3;0;9;read: 0-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0:1<br />
Thu Jan 05 2017 11:06:00 GMT+0000 (UTC) : 0;3;1;0;16;1<br />
Thu Jan 05 2017 11:06:10 GMT+0000 (UTC) : 0;0;3;0;9;read: 0-0-0 s=3,c=1,t=16,pt=2,l=2,sg=0:0<br />
Thu Jan 05 2017 11:06:10 GMT+0000 (UTC) : 0;3;1;0;16;0</em></p>
<p dir="auto">But not any mySensor node appears in Jeedom with inclusion mode !<br />
Thanks</p>
]]></description><link>https://forum.mysensors.org/topic/5711/mysensors-node-doesn-t-appear-in-jeedom</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 06:14:56 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5711.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Jan 2017 12:38:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MySensors node doesn’t appear in Jeedom on Fri, 10 Feb 2017 21:29:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">Hallelujah, I managed to get everything working perfect. Shame on me :kissing_closed_eyes:</p>
<p dir="auto">The main problem came from a bad definition of the internal address (Network configuration section), in particular the "complementary" part of the address (/jeedom) which was not to be defined for me (check your URL Jeedom access to be sure).</p>
<p dir="auto">So I have : <a href="http://jeedom:80" rel="nofollow ugc">http://jeedom:80</a> where "jeedom" is 127.0.1.1 (as to be defined in /etc/hosts).</p>
<p dir="auto">Hope this help.</p>
<p dir="auto">Eric.</p>
]]></description><link>https://forum.mysensors.org/post/59539</link><guid isPermaLink="true">https://forum.mysensors.org/post/59539</guid><dc:creator><![CDATA[rickyguff]]></dc:creator><pubDate>Fri, 10 Feb 2017 21:29:43 GMT</pubDate></item><item><title><![CDATA[Reply to MySensors node doesn’t appear in Jeedom on Fri, 10 Feb 2017 16:22:09 GMT]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I've just installed a sensor node and a serial gateway with the last version of MySensors Library, 2.1.1 and nRF24L01+ network devices. The serial gateway is connected (/dev/ttyACM0) to my Jeedom box running the last software version (2.4.6.).<br />
The sensor node is running the Air Humidity sketch (with DHT22 device) found <a href="https://github.com/mysensors/MySensorsArduinoExamples/blob/master/examples/DhtTemperatureAndHumiditySensor/DhtTemperatureAndHumiditySensor.ino" rel="nofollow ugc">here</a> and the serial gateway with the adequate sketch found <a href="https://github.com/mysensors/MySensors/blob/master/examples/GatewaySerial/GatewaySerial.ino" rel="nofollow ugc">here</a>on this web site.</p>
<p dir="auto">Communication between them seems to work correctly, the serial gateway seems also to be recognized by the Jeedom box via the MySensors Plugin (latest stable version), but Jeedom cannot see any sensor node, even with inclusion mode and after reconnecting the sensor node itself (off/on).</p>
<p dir="auto">Here is an extract of the  the Jeedom plugin MySensors_node log.<br />
Thank you in advance.</p>
<pre><code>...
Fri Feb 10 2017 17:15:04 GMT+0100 (CET) - connected to serial gateway at /dev/ttyACM0
2/10/2017, 5:15:04 PM null
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSF:WUR:MS=0
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT:TSP OK
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:INIT:GW MODE
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:REG:NOT NEEDED
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;14;Gateway startup complete.
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;0;0;18;2.1.1
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:STP
Fri Feb 10 2017 17:15:05 GMT+0100 (CET) : 0;255;3;0;9;MCO:BGN:INIT OK,TSP=1
2/10/2017, 5:15:05 PM null
Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 0;255;3;0;9;TSF:MSG:READ,3-3-0,s=1,c=1,t=0,pt=7,l=5,sg=0:20.0
Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 3;1;1;0;0;20.0
Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 0;255;3;0;9;TSF:MSG:READ,3-3-0,s=0,c=1,t=1,pt=7,l=5,sg=0:37.4
Fri Feb 10 2017 17:15:56 GMT+0100 (CET) : 3;0;1;0;1;37.4
2/10/2017, 5:15:56 PM null
2/10/2017, 5:15:56 PM null```</code></pre>
]]></description><link>https://forum.mysensors.org/post/59516</link><guid isPermaLink="true">https://forum.mysensors.org/post/59516</guid><dc:creator><![CDATA[rickyguff]]></dc:creator><pubDate>Fri, 10 Feb 2017 16:22:09 GMT</pubDate></item><item><title><![CDATA[Reply to MySensors node doesn’t appear in Jeedom on Thu, 19 Jan 2017 06:20:23 GMT]]></title><description><![CDATA[<p dir="auto">It works now.<br />
I just added gw.sendSketchInfo command in the setup of my sketch script.</p>
]]></description><link>https://forum.mysensors.org/post/57562</link><guid isPermaLink="true">https://forum.mysensors.org/post/57562</guid><dc:creator><![CDATA[philoudumdum]]></dc:creator><pubDate>Thu, 19 Jan 2017 06:20:23 GMT</pubDate></item><item><title><![CDATA[Reply to MySensors node doesn’t appear in Jeedom on Wed, 18 Jan 2017 18:23:44 GMT]]></title><description><![CDATA[<p dir="auto">I have the same problem, and i did a restart of my node when jeedom was in inclusion mode.</p>
<pre><code>Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - Jeedom url : http://:80/plugins/mySensors/core/api/jeeSensors.php?apikey=KN3AxPW64r0xrnjGckMD5E9bD4TV6DZcZvCj3xgJZrmykMT1&amp;gateway=master, gwAddress : /dev/ttyUSB020
DEPRECATION: Please use `require('serialport')` instead of `require('serialport').SerialPort`
Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - server bound on 8019
Wed Jan 18 2017 19:22:03 GMT+0100 (CET) - connected to serial gateway at /dev/ttyUSB020
1/18/2017, 7:22:03 PM { [Error: socket hang up] code: 'ECONNRESET' }
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;0;0;17;2.1.0
-&gt; 105;255;3;0;6;M
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;6;0
1/18/2017, 7:22:22 PM { [Error: socket hang up] code: 'ECONNRESET' }
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;11;TemperatureAndHumidity
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;255;3;0;12;1.1
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;1;0;0;6;
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;1;1;0;0;20.0
Wed Jan 18 2017 19:22:22 GMT+0100 (CET) : 105;0;1;0;1;21.0
</code></pre>
]]></description><link>https://forum.mysensors.org/post/57511</link><guid isPermaLink="true">https://forum.mysensors.org/post/57511</guid><dc:creator><![CDATA[gregaou]]></dc:creator><pubDate>Wed, 18 Jan 2017 18:23:44 GMT</pubDate></item><item><title><![CDATA[Reply to MySensors node doesn’t appear in Jeedom on Wed, 11 Jan 2017 11:24:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/philoudumdum" aria-label="Profile: philoudumdum">@<bdi>philoudumdum</bdi></a><br />
did you restart any node when your are in inclusion mode?</p>
]]></description><link>https://forum.mysensors.org/post/56722</link><guid isPermaLink="true">https://forum.mysensors.org/post/56722</guid><dc:creator><![CDATA[denisvdb]]></dc:creator><pubDate>Wed, 11 Jan 2017 11:24:22 GMT</pubDate></item></channel></rss>
