<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[LED Strip Dimmer with 2 power supply&#x27;s killed my arduino]]></title><description><![CDATA[<p dir="auto">I'm trying to do the same as an example on <a href="http://mysensors.org" rel="nofollow ugc">mysensors.org</a></p>
<p dir="auto"><a href="https://www.mysensors.org/build/dimmer" rel="nofollow ugc">https://www.mysensors.org/build/dimmer</a></p>
<p dir="auto">But have expanded it to 2 power supply's and 2 led strips as it draws more power than one power supply can handle.</p>
<p dir="auto">It's been working with 1 power supply and 1 LED strip connected for some months now, but then I wanted to connect the other LED strip and the other power supply and my Arduino burned :(. Can anyone spot an error in my setup? I have attached an image of the Breadboard setup (without the radio and so) does that look right?</p>
<p dir="auto">I might add that at first I when adding the 2nd power supply and 2nd LED strip, there was no light in the second, so I disconnected the power and connected it to my USB on my laptop to debug the output and connected the 2 power supplies again and then it happened. Is it bad to have both USB power and external VCC 12v power? Think it happened when I turned up the power on the gain to make the LEDs light up.</p>
<p dir="auto">Anyway here is the setup:</p>
<p dir="auto"><img src="/uploads/files/1485292905429-selection_179-resized.png" alt="0_1485292847731_Selection_179.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Any good ideas?</p>
<p dir="auto">PS: The MOSFETs are IRL Z44N</p>
]]></description><link>https://forum.mysensors.org/topic/5916/led-strip-dimmer-with-2-power-supply-s-killed-my-arduino</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 09:07:55 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/5916.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 24 Jan 2017 21:22:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to LED Strip Dimmer with 2 power supply&#x27;s killed my arduino on Tue, 24 Jan 2017 22:25:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Ok thanks for your answer. Glad to hear the setup looks ok (almost :) ) and I'll remove the 12V from the VCC and do some testing with 5v power through USB to start with.</p>
<p dir="auto">Thanks :)</p>
]]></description><link>https://forum.mysensors.org/post/58209</link><guid isPermaLink="true">https://forum.mysensors.org/post/58209</guid><dc:creator><![CDATA[kajhoej]]></dc:creator><pubDate>Tue, 24 Jan 2017 22:25:00 GMT</pubDate></item><item><title><![CDATA[Reply to LED Strip Dimmer with 2 power supply&#x27;s killed my arduino on Tue, 24 Jan 2017 21:53:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kajhoej" aria-label="Profile: kajhoej">@<bdi>kajhoej</bdi></a> the setup looks fine to me, except that 12V burns most clones - sooner or later.</p>
]]></description><link>https://forum.mysensors.org/post/58207</link><guid isPermaLink="true">https://forum.mysensors.org/post/58207</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 24 Jan 2017 21:53:45 GMT</pubDate></item><item><title><![CDATA[Reply to LED Strip Dimmer with 2 power supply&#x27;s killed my arduino on Tue, 24 Jan 2017 21:51:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Thanks for your quick answer. No, it's a cheap Chinese one 😀. It been running fine for months with only the one 12v power supply that drives the arduino and 1 led strip. Only when I was trying to add the other power supply and the 2nd led strip it burned. Had my laptop connected to usb at the same time for debug.</p>
<p dir="auto">Before trying again I would like to know if the hw setup looks OK so that I don't burn another because of it. I could replace it with an original Nano but I don't dare until I'm sure that my setup does not cause the problem 😀</p>
]]></description><link>https://forum.mysensors.org/post/58206</link><guid isPermaLink="true">https://forum.mysensors.org/post/58206</guid><dc:creator><![CDATA[kajhoej]]></dc:creator><pubDate>Tue, 24 Jan 2017 21:51:39 GMT</pubDate></item><item><title><![CDATA[Reply to LED Strip Dimmer with 2 power supply&#x27;s killed my arduino on Tue, 24 Jan 2017 21:37:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kajhoej" aria-label="Profile: kajhoej">@<bdi>kajhoej</bdi></a> is this a genuine Arduino? Most chinese clones can't handle 12V. A lot of people on the forum have burned their clones this way, you are not alone :)</p>
]]></description><link>https://forum.mysensors.org/post/58204</link><guid isPermaLink="true">https://forum.mysensors.org/post/58204</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Tue, 24 Jan 2017 21:37:40 GMT</pubDate></item></channel></rss>
