Nexa smoke alarm hack
  • Note, I take no responsibilities for modifications you do to your smoke alarm. Use a back up for safety.
    I have a few Nexa KD-101Lx smoke detektors with a built in 433MHz radio that just eats batteries so I had the idea to modify them to talk with a simple MySensors node.
    The construction is actually a alarm and a radio on the same PCB. Looking at the PCB and a bit of testing I found the connection between the smoke alarm and the radio part.
    When the alarm triggers the pin is pulled high and since there already is a 10k pull-up resistor in place all that is needed is to add a cable to my sensor. The "learn" button is re-used for triggering reset and providing ground.
    The original radio is powered by 3xAA so I just cut the cable and re-soldered the cables to use only 2xAA's.
    I will use the newbiePCB for hooking things up and everything's seems to fit inside the case just fine.
    Here is the code that will run for the next couple of days.
     * Simple fire alarm example modifying a Nexa KD-101L fire alarm
     * Connect digitial I/O pin 3 (FIRE_PIN below) with a 10K resistor to GND.
     * Also connect the FIRE_PIN between the IC and R16 (SMD103=10K).
    #include <Vcc.h>
    const float VccMin        = 2.0*0.6;  // Minimum expected Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccMax        = 2.0*1.5;  // Maximum expected Vcc level, in Volts. Example for 2xAA Alkaline.
    const float VccCorrection = 1.0/1.0;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    // Pin connected to the alarm
    #define FIRE_PIN 3
    // Id of the sensor child
    #define CHILD_ID 0
    // Sleep time in ms        min     s      ms
    unsigned long SLEEP_TIME = 120UL * 60UL * 1000UL;
      // Setup the alarm
      pinMode(FIRE_PIN, INPUT);
    void presentation()  {
      // Send the sketch version information
      sendSketchInfo("Fire Alarm", "1.0");
      // Register sensor
      present(CHILD_ID, S_SMOKE, "Alarm tripped", true);
      // Send the current state
      //send(msg.set("0"));
      bool tripped = digitalRead(FIRE_PIN) == HIGH;
      if(tripped) {
        Serial.println("Fire!");
        send(msg.set(1), true);
        wait(1000);
      } else {
        Serial.println("All ok");
        send(msg.set(0), true);
        // Measure battery level
        uint8_t batteryPcnt = static_cast<uint8_t>(0.5 + vcc.Read_Perc(VccMin, VccMax));
        // Send battery level, used as heartbeat of the sensor
      // Sleep until fire
      sleep(digitalPinToInterrupt(FIRE_PIN), HIGH, SLEEP_TIME);
  • Mod
    @Efflon How is this working out for you?
    I have to add a couple of smoke detectors soon and want to do the same thing as you...
  • @marceltrapman It's working just fine except the battery level messages seems to be lost (this happens to all my sensors). Just as a precaution I pushed the test button this morning and got a proper response and a battery level.
  • Mod
    @Efflon Nice to know 🙂
    The battery level thing concerns me though.
    I would think this is (sort of) essential...
  • @marceltrapman Yes, I'll check if adding a ack request will help..
  • Mod
    @Efflon Any news? Before I buy a couple of these 🙂
  • @marceltrapman Haven't had the time to add an ack to the battery request, but the sensor is working just fine. I don't know if it's my home assistant setup or something else causing the battery levels to get lost but I'm sure it's not part of the smoke alarm hack. Since the sensor drain is almost nothing, the battery levels are not moving much.
    I cant guarantee the pcb layout is the same on newer versions of this smoke alarm..
  • 8
  • 29
  • 1
  • 90
  • 1
