<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[433mhz and Serial Gateway combo]]></title><description><![CDATA[<p dir="auto">I have finished and been testing my new build of a 433mhz bridge for a serial gateway for about a week now and I thought I would share.</p>
<p dir="auto"><strong>Hardware:</strong><br />
433mhz radios:<br />
<a href="https://www.amazon.com/gp/product/B017AYH5G0/" rel="nofollow ugc">https://www.amazon.com/gp/product/B017AYH5G0/</a></p>
<p dir="auto">433mhz outlets:<br />
<a href="https://www.amazon.com/gp/product/B00DQELHBS/" rel="nofollow ugc">https://www.amazon.com/gp/product/B00DQELHBS/</a></p>
<p dir="auto">NFR Radio:<br />
<a href="https://www.amazon.com/gp/product/B01IK78PQA/" rel="nofollow ugc">https://www.amazon.com/gp/product/B01IK78PQA/</a></p>
<p dir="auto">A 5v 16mhz Arduino</p>
<p dir="auto"><strong>Software:</strong></p>
<p dir="auto">RC-Switch Library:<br />
<a href="https://github.com/sui77/rc-switch" rel="nofollow ugc">https://github.com/sui77/rc-switch</a></p>
<p dir="auto">Base Gateway code:<br />
<a href="https://github.com/Mihai258/MySensors2-HomeAssistant-MQTT" rel="nofollow ugc">https://github.com/Mihai258/MySensors2-HomeAssistant-MQTT</a></p>
<p dir="auto">Started from this Forum Post:<br />
<a href="https://forum.mysensors.org/topic/2794/connect-sensors-directly-to-the-gateway-again">https://forum.mysensors.org/topic/2794/connect-sensors-directly-to-the-gateway-again</a></p>
<p dir="auto">Rc sniffer:<br />
<a href="https://codebender.cc/sketch:80286#RCSwitch%20-%20Sniffer.ino" rel="nofollow ugc">https://codebender.cc/sketch:80286#RCSwitch - Sniffer.ino</a></p>
<p dir="auto">Antennas:<br />
<a href="http://www.instructables.com/id/433-MHz-Coil-loaded-antenna/" rel="nofollow ugc">http://www.instructables.com/id/433-MHz-Coil-loaded-antenna/</a><br />
<a href="https://www.elektor.nl/Uploads/Forum/Posts/How-to-make-a-Air-Cooled-433MHz-antenna.pdf" rel="nofollow ugc">https://www.elektor.nl/Uploads/Forum/Posts/How-to-make-a-Air-Cooled-433MHz-antenna.pdf</a></p>
<p dir="auto">My Code github:<br />
<a href="https://github.com/jerryrw/mySensors" rel="nofollow ugc">https://github.com/jerryrw/mySensors</a></p>
<p dir="auto"><strong>Physical Connections:</strong></p>
<p dir="auto">Arduino<br />
I am using an older 5V 16mhz Uno in the photographs but the code should also run on a Nano.  I did not include any of the code for the lower clock speed arduinos or home brew boards.</p>
<p dir="auto">NRF24L01+<br />
Connect as per the standard mySensors configuration<br />
My code has CE as  pin 9 and CS as pin 10<br />
I am using a 10uf capacitor across the power supply pins<br />
I did not connect the NRF module interrupt to pin 2 as normal. I used this pin for my 433 receiver module.  If this is necesary for your situation you will need to modify the 433 receiver code to use pin 3 and INT1.</p>
<p dir="auto">Antennas<br />
I built my antennas per the above instructable article and pdf.  You will need to build two, one for the transmitter and one for the receiver.  I used some thin hookup wire for the antennas and a piece of 12 gauge house wire for the form to wrap around.</p>
<p dir="auto"><strong>Making Antennas</strong><br />
<img src="http://i.imgur.com/TvJjFfc.jpg" alt="Antennas" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>Soldering Antennas</strong><br />
<img src="http://i.imgur.com/akRoFBy.jpg" alt="Soldering" class=" img-fluid img-markdown" /></p>
<img src="http://i.imgur.com/4PXkuh2.jpg" alt="soldering" class=" img-fluid img-markdown" /></p>
<p dir="auto">433 Transmitter:<br />
Connect the module's data pin to pin 7 on Arduino<br />
Connect the transmitter's VCC to 5V from the Arduino<br />
Connect the transmitter's GND to common ground</p>
<p dir="auto">433 Receiver:<br />
Connect the receiver's data pin to pin 2 on the Arduino (must be an Arduino interrupt pin)<br />
Connect the receiver's VCC to pin 6 on the Arduino (can be any unused 5v data pin, change source acordingly)<br />
Connect the receiver's GND to common ground<br />
The fourth pin on these modules is not used</p>
<p dir="auto"><em><strong>This photo was of my sniffer configuration NOT the final pin layout.</strong></em><br />
<img src="http://i.imgur.com/J619kAf.jpg" alt="Radios" class=" img-fluid img-markdown" /><br />
<em><strong>This photo was of my sniffer configuration NOT the final pin layout.</strong></em></p>
<p dir="auto">Status LEDs:<br />
Connect leds from pins 3, 4, and 5 to ground using a 220 ohm resistor for each.</p>
<p dir="auto"><strong>All wired up</strong><br />
<img src="http://i.imgur.com/q8l07k7.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
<p dir="auto"><strong>The code</strong><br />
The code basically sets up a standard serial gateway with the 433 mhz radios presenting themselves as locally attached relays.  The tricky bits were in trying to play nicely with the included remote control.  I needed the receiver module to listen for the remote but I needed to turn it off during transmission to avoid entering a loop.  I decided to power the receiver off a digital pin and bring it low during transmission.  The code is commented fairly heavily and should mostly speak for itself.</p>
<pre><code>// Arduino code for a MySensors v2 serial control gateway and bridge for 433MHZ Etekcity power outlets using the RCSwitch library
// Hardware:
// Outlets: http://www.amazon.com/gp/product/B00DQELHBS/
// Generic 433 Module: http://www.amazon.com/gp/product/B00M2CUALS (if you search for the code on the board you can find it in many other retailers)
// not the exact suplier I used but the same boards.  In 2017 I paid $10 US for 6 tx/rx pairs shipped.
// NFR Radio: https://www.amazon.com/gp/product/B01IK78PQA/
// Primary libraries used
// RCSwitch: https://code.google.com/p/rc-switch/
// MySensors: https://www.mysensors.org
// Sniffer to obtain codes available at: https://codebender.cc/sketch:80286
// Transmit original sourcecode available at: https://codebender.cc/sketch:80290
// Thanks to codebender user https://codebender.cc/user/santusmarc
// Initial framework for gateway from: https://github.com/Mihai258/MySensors2-HomeAssistant-MQTT
// Antenna construction: http://www.instructables.com/id/433-MHz-Coil-loaded-antenna/
// https://www.elektor.nl/Uploads/Forum/Posts/How-to-make-a-Air-Cooled-433MHz-antenna.pdf
//-------------------------Standard MySensors Serial Gateway Settings ------------------//
#define MY_RADIO_NRF24  // Enables and select radio type (if attached)
#define MY_RF24_PA_LEVEL RF24_PA_MAX  //RF24_PA_LOW
#define MY_RF24_CHANNEL 125
#define MY_RF24_DATARATE RF24_250KBPS //RF24_1MBPS or RF24_2MBPS
#define MY_GATEWAY_SERIAL  //Enable the Gateway magic
#define MY_BAUD_RATE 115200
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V &amp; SenseBender)
// Strongly not recommended with cheap 433 modules.
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
#define MY_RF24_CE_PIN 9
#define MY_RF24_CS_PIN 10
// Flash leds on rx/tx/err
//#define MY_LEDS_BLINKING_FEATURE // depreciated some kind of sticky anouncement would be nice
#define MY_DEFAULT_LED_BLINK_PERIOD 300  // Set blinking period
#define MY_INCLUSION_MODE_FEATURE  // Enable inclusion mode
//#define MY_INCLUSION_BUTTON_FEATURE  // Enable Inclusion mode button on gateway
#define MY_INCLUSION_MODE_DURATION 60  // Set inclusion mode duration (in seconds)
//#define MY_INCLUSION_MODE_BUTTON_PIN  3 // Digital pin used for inclusion mode button
#define MY_WITH_LEDS_BLINKING_INVERSE  // if sourcing LEDs from Arduino pins to ground
// these pins are for the NRF tx/rx NOT for the 433 tx/rx
#define MY_DEFAULT_ERR_LED_PIN 3  // Error led pin
#define MY_DEFAULT_RX_LED_PIN  4  // Receive led pin
#define MY_DEFAULT_TX_LED_PIN  5  // Transmit pin
#include &lt;MySensors.h&gt;
//-------------------------RCSwitch Related Settings------------------------------------//
#include &lt;RCSwitch.h&gt;
// Array of ON/OFF codes. You must replace these with your codes obtained using a sniffer. This matches the 5 outlet remote.
unsigned long rc_codes[5][2] = {
  // ON     //OFF
  {4216115, 4216124}, /* Outlet 1 */
  {4216259, 4216268}, /* Outlet 2 */
  {4216579, 4216588}, /* Outlet 3 */
  {4218115, 4218124}, /* Outlet 4 */
  {4224259, 4224268}, /* Outlet 5 */
#define RC_PIN_TX 7  // The physical Arduino PIN for 433 transmit data. Change this according to your board layout
#define RC_PROTOCOL 1       // These values are found using the RC Sniffer setup
#define RC_PULSE_LENGTH 185 // 'Delay', if you got the right codes and this isn't working, check that the delay/pulse length from the sniffer matches this
#define RC_BIT_LENGTH 24
#define RC_RX_POWER_PIN 6  // used to selectively power off the receiver when transmitting
RCSwitch sendSwitch = RCSwitch();  // set up the transmitter object
// The interrupt number, On Arduino INT0 is PIN 2. See http://arduino.cc/en/Reference/AttachInterrupt
// if your MySensors code is using INT0 on Pin 2 this can be changes to INT1 on Pin 3
#define INTERRUPT_RX 0
RCSwitch receiveSwitch = RCSwitch();  // set up the reviver object
#define CHILD_ID_REL1 101
#define CHILD_ID_REL2 102
#define CHILD_ID_REL3 103
#define CHILD_ID_REL4 104
#define CHILD_ID_REL5 105
MyMessage msgREL1(CHILD_ID_REL1, V_STATUS);
MyMessage msgREL2(CHILD_ID_REL2, V_STATUS);
MyMessage msgREL3(CHILD_ID_REL3, V_STATUS);
MyMessage msgREL4(CHILD_ID_REL4, V_STATUS);
MyMessage msgREL5(CHILD_ID_REL5, V_STATUS);
const unsigned long tUpdate=60000; //update interval
unsigned long t0;  // update timer counter
int16_t StateREL=0, StateREL1=0, StateREL2=0, StateREL3=0, StateREL4=0, StateREL5=0;
bool initialValueSent = false;  // for Home Assistant wanting a state request during startup
  pinMode (RC_RX_POWER_PIN, OUTPUT);  // yes we are powering the receiver radio using a digital output pin
  digitalWrite (RC_RX_POWER_PIN, HIGH);  // electrically turn on the 433 receiver module
  sendSwitch.enableTransmit(RC_PIN_TX); // set up transmit pin - 433 transmiter datapin on our Arduino
  sendSwitch.setProtocol(RC_PROTOCOL); // protocol defaults to 1 - correct value is found using sniffer
  sendSwitch.setPulseLength(RC_PULSE_LENGTH); // This is critical - correct value is found using sniffer
  receiveSwitch.enableReceive(INTERRUPT_RX);  // Turn on the receiver object interrupt
  // TODO need to fetch the state from the controller here - going to be HA specific probebly
  // for now turn them all off
  enableOutlet (1,StateREL1);
  delay (50); // not completely sure this is necessary but to be safe when firing this many in a row
  enableOutlet (2,StateREL2);
  delay (50);
  enableOutlet (3,StateREL3);
  delay (50);
  enableOutlet (4,StateREL4);
  delay (50);
  enableOutlet (5,StateREL5);
  delay (50);
void presentation() {
  sendSketchInfo("Gateway+433Outlets", "1.0b");
  present(CHILD_ID_REL1, S_BINARY);
  present(CHILD_ID_REL2, S_BINARY);
  present(CHILD_ID_REL3, S_BINARY);
  present(CHILD_ID_REL4, S_BINARY);
  present(CHILD_ID_REL5, S_BINARY);
  if (!initialValueSent) { //this section is for Home Assistant it likes a request of status be made at startup
    Serial.println("Sending initial values");
    ServerUpdate ();
    Serial.println("Requesting initial value from controller");
    request(CHILD_ID_REL1, V_STATUS);
    request(CHILD_ID_REL2, V_STATUS);
    request(CHILD_ID_REL3, V_STATUS);
    request(CHILD_ID_REL4, V_STATUS);
    request(CHILD_ID_REL5, V_STATUS);
    wait(2000, C_SET, V_STATUS);
  if (receiveSwitch.available())
  //this is to handle the remote control that comes with the outlets
  //it's signal should be received by the gateway as well as the outlets when used
  //since sending multiple codes for the same state has no effect on the outlets
  //we can retransmit the same codes when received to no real ill effect - I think :)
  //NOTE this is not the proper code needed to handle things like 433 motion sensors
      int value = receiveSwitch.getReceivedValue();
      byte i, j; //index counters for finging our received switch codes in the array
      int switch_num = 0; //should prolly be a byte to save memory
      bool switch_state = false;
      if (value == 0)
        //TODO not realy sure what to do here yet - need to get better at MySensors error conditions
        Serial.println("Unknown encoding");
      else
      {  // TODO replace hard coded values 5,2
        for (i=0;i&lt;5;i++) { // ugly but should loop over the rc_codes array to find our received value and return a pair for transmission
          for (j=0;j&lt;2;j++) {
            if (rc_codes[i][j] == receiveSwitch.getReceivedValue()) {
              switch_num = (i + 1); // zero based array and a 1 based library
              switch_state = (j ? false:true); //j can only be 0 or 1 so this magic juju should work
            }//end if
          }//end inner for loop
        }//end outer for loop
        enableOutlet(switch_num, switch_state);  // transmit the signal to the switches
        switch (switch_num) {  // a switch statement based on a switch number - inception
          case 1: { StateREL1 = (switch_state ? 1:0);} break; // inverse with the switch_state above
          case 2: { StateREL2 = (switch_state ? 1:0);} break;
          case 3: { StateREL3 = (switch_state ? 1:0);} break;
          case 4: { StateREL4 = (switch_state ? 1:0);} break;
          case 5: { StateREL5 = (switch_state ? 1:0);} break;
        }//end switch
        ServerUpdate (); // update the server with the new status
      }// end else
      receiveSwitch.resetAvailable();
    } //end if receiveSwitch.available
  if ((millis()-t0) &gt; tUpdate) ServerUpdate();  // is it time to update the controller
void ServerUpdate() {
  send(msgREL1.set(StateREL1 ? (int16_t)1:(int16_t)0));  // send our relay status to the controller
  send(msgREL2.set(StateREL2 ? (int16_t)1:(int16_t)0));
  send(msgREL3.set(StateREL3 ? (int16_t)1:(int16_t)0));
  send(msgREL4.set(StateREL4 ? (int16_t)1:(int16_t)0));
  send(msgREL5.set(StateREL5 ? (int16_t)1:(int16_t)0));
  t0=millis();  // and update the time
void receive(const MyMessage &amp;message) {  // Handle the mySensors messages received from the controller
  if (message.type==V_STATUS) {
    if (!initialValueSent) {  //Receiving initial value from controller
      initialValueSent = true;  // Only send initial values until we get our first response
    StateREL = message.getBool();  // Get the state requestes on or off
    switch(message.sensor) { // Get the child node number to act on
      case 101: { //Handle incomming messages for RF switch #1
        StateREL1=StateREL;  // update saved state with requested state
        enableOutlet(1, (StateREL1 ? true:false)); // transmit the 433 signal to change relay status
        send(msgREL1.set(StateREL1 ? (int16_t)1:(int16_t)0));  // confirm new state to controller
      break;
      case 102: { //Handle incomming messages for RF switch #2
        StateREL2=StateREL;
        enableOutlet(2, (StateREL2 ? true:false)); //change light status
        send(msgREL2.set(StateREL2 ? (int16_t)1:(int16_t)0));  // confirm new state to controller
      break;
      case 103: { //Handle incomming messages for RF switch #3
        StateREL3=StateREL;
        enableOutlet(3, (StateREL3 ? true:false)); //change light status
        send(msgREL3.set(StateREL3 ? (int16_t)1:(int16_t)0));  // confirm new state to controller
      break;
      case 104: { //Handle incomming messages for RF switch #4
        StateREL4=StateREL;
        enableOutlet(4, (StateREL4 ? true:false)); //change light status
        send(msgREL4.set(StateREL4 ? (int16_t)1:(int16_t)0));  // confirm new state to controller
      break;
      case 105: { //Handle incomming messages for RF switch #5
        StateREL5=StateREL;
        enableOutlet(5, (StateREL5 ? true:false)); //change light status
        send(msgREL5.set(StateREL5 ? (int16_t)1:(int16_t)0));  // confirm new state to controller
      break;
    }//end switch
   } //end if V_STATUS
}//end recieve
void enableOutlet(int16_t outletNumber, int16_t onOrOff)
// TODO reenable the serial error outputs or better error handling
// for now cut them out
  digitalWrite (RC_RX_POWER_PIN, LOW);  //turn off reciever during transmit
  delay (5); // wait for power down
  if (outletNumber &lt; 1 || outletNumber &gt; 5)
    //Error condition for an out of range outlet number
    //TODO look up MySensors error conditions to send to controller
    //Serial.println("Invalid outlet number");
    return;
  //do the table lookup for the right code to transmit
  unsigned long *onOffCodes = rc_codes[outletNumber - 1];
  unsigned long codeToSend = onOffCodes[onOrOff ? 0 : 1];
  //send it
  sendSwitch.send(codeToSend, RC_BIT_LENGTH);
  char outletNumberString[1];
  int retVal = snprintf(outletNumberString, 1, "%d", outletNumber);
  if (retVal &lt; 0)
    //Serial.println("Log encoding error");
    return;
  //if (onOrOff)
  //  Serial.print("Enabling");
  //else
  //  Serial.print("Disabling");
  //Serial.print(" outlet ");
  //Serial.println(outletNumberString);
  delay (50);  // wait for transmitter to settle
  digitalWrite (RC_RX_POWER_PIN, HIGH);  //turn reciever back on
</code></pre>
<p dir="auto">The code should be able to extend up to a larger number of switches with minor modifications to the codes array and a few badly hardcoded constants in the lookup loops.</p>
<p dir="auto">My next step is to put it onto a breadboard with a Nano and print case for it.</p>
]]></description><link>https://forum.mysensors.org/topic/6459/433mhz-and-serial-gateway-combo</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:22:04 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6459.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Mar 2017 19:22:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 433mhz and Serial Gateway combo on Tue, 14 Mar 2017 19:34:16 GMT]]></title><description><![CDATA[<p dir="auto">Wow, welcome and great first post!</p>
]]></description><link>https://forum.mysensors.org/post/62304</link><guid isPermaLink="true">https://forum.mysensors.org/post/62304</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Tue, 14 Mar 2017 19:34:16 GMT</pubDate></item><item><title><![CDATA[Reply to 433mhz and Serial Gateway combo on Tue, 14 Mar 2017 19:34:15 GMT]]></title><description><![CDATA[<p dir="auto">Nice project! I have just build a seperate bridge <a href="https://www.openhardware.io/view/351/OH-433Mhz-Mysensors-Bridge" rel="nofollow ugc">here</a>. Yours looks very nice though with the antenna. As I also wanted to add PLNA+ to my serial gateway in the near future I might just use your sketches :+1:</p>
]]></description><link>https://forum.mysensors.org/post/62303</link><guid isPermaLink="true">https://forum.mysensors.org/post/62303</guid><dc:creator><![CDATA[LastSamurai]]></dc:creator><pubDate>Tue, 14 Mar 2017 19:34:15 GMT</pubDate></item></channel></rss>
