<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use SoftwareSerial Library?]]></title><description><![CDATA[<p dir="auto">Hi,<br />
first of all thank you very much for the great forum and all the futures built in mySensors!<br />
Although I ve read up and down the forums and information, I am not really clear how to use the SoftwareSerial instead of AltSoftSerial lib. There are some comparison why the one might be better than the other but I didn't grab a sketch sample to go from there.<br />
The reason why I am asking is that I had established an rs485 network with custom designed nodes on arduino nano with rs485 shield. The system is a little bit like mySensors, it works with the ICSC lib, but unfortunately I came across mySensors too late. So all my PCBs are done and the parts are soldered and the rs485 module is connected like this:<br />
DI = Pin 2<br />
DE/RE = Pin 3<br />
RO = Pin 4<br />
The only option I have now to "upgrade" to my sensors is to get the SoftwareSerial lib running.<br />
Time is not an issue for me, so it would be totally sufficient to run at a speed of 19200 or 57600 Bauds.</p>
<p dir="auto">Is there anyone with a similar problem giving me a hint how to get along with it? That would be very nice.<br />
Best regards,<br />
City</p>
]]></description><link>https://forum.mysensors.org/topic/6502/how-to-use-softwareserial-library</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 08:39:09 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6502.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Mar 2017 21:55:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Tue, 18 Jul 2017 19:32:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi PJR,<br />
now it is working with this code in the MyTransportRS485 without any changes on MySensors.h:</p>
<pre><code>#if defined(MY_RS485_SWSERIAL)
SoftwareSerial&amp; _dev = MY_RS485_SWSERIAL;
#elif defined(__linux__)
SerialPort _dev = SerialPort(MY_RS485_HWSERIAL);
#elif defined(MY_RS485_HWSERIAL)
HardwareSerial&amp; _dev = MY_RS485_HWSERIAL;
#else
AltSoftSerial _dev;
</code></pre>
<p dir="auto">As far as I can interpret the peace of code, the<br />
#include "hal/transport/MyTransportRS485.cpp"<br />
is active as soon as the MY_RS485 layer is defined.</p>
<p dir="auto">This is a great step, I can use all my nodes from now on!<br />
Thank you very much for your support!<br />
By Kduino</p>
]]></description><link>https://forum.mysensors.org/post/71505</link><guid isPermaLink="true">https://forum.mysensors.org/post/71505</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Tue, 18 Jul 2017 19:32:57 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Mon, 17 Jul 2017 05:54:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi PJR,<br />
thanks a lot! This is obvious. Please apologize that I didn't take a look at this site. So the MyTransportRS485.cpp is loaded only in case of defining MY_HWSERIAL... This explains why it was not working after skipping the MY_HWSERIAL definition.<br />
Unfortunately I was not able to run another test now but I hope it will come up soon.<br />
The changes regarding softwareSerial would be a great help for those who are not able to use the altSoftSerial pins.<br />
Once it is running stable I will post a request <a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a> to ask for implementation.<br />
I will come back with more tests.<br />
By kduino</p>
<p dir="auto">PS: It seams that during compilation it loads also the AltSoftSerial.cpp. In case of use of the SoftwareSerial it would be unnecessary overhead, of course. Is there a reason why it is loaded at this stage? I would rather load it at MyTransportXYZ.cpp.</p>
]]></description><link>https://forum.mysensors.org/post/71380</link><guid isPermaLink="true">https://forum.mysensors.org/post/71380</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Mon, 17 Jul 2017 05:54:59 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Fri, 14 Jul 2017 15:07:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kduino" aria-label="Profile: kduino">@<bdi>kduino</bdi></a> said in <a href="/post/71093">How to use SoftwareSerial Library?</a>:</p>
<blockquote>
would you mind explaining me the reason for defining MY_RS485_<strong>H</strong>WSERIAL?<br />
Thank you,<br />
by kduino</p>
</blockquote>
<p dir="auto">Take a look at MySensors.h:</p>
<pre><code>#elif defined(MY_RS485)
  #if !defined(MY_RS485_HWSERIAL)
    #if defined(__linux__)
      #error You must specify MY_RS485_HWSERIAL for RS485 transport
    #include "drivers/AltSoftSerial/AltSoftSerial.cpp"
</code></pre>
<p dir="auto">If I read this correctly it loads also AltSoftSerial if you dont define MY_RS485_HWSERIAL<br />
Of course I can read this wrong..</p>
]]></description><link>https://forum.mysensors.org/post/71199</link><guid isPermaLink="true">https://forum.mysensors.org/post/71199</guid><dc:creator><![CDATA[pjr]]></dc:creator><pubDate>Fri, 14 Jul 2017 15:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Wed, 12 Jul 2017 19:43:40 GMT]]></title><description><![CDATA[<p dir="auto">I did it like this:</p>
<pre><code>#if defined(__linux__)
#elif defined(MY_RS485_SWSERIAL)
#else
AltSoftSerial _dev;
</code></pre>
<p dir="auto">The Arduino code is extended by:</p>
<pre><code>// Enable debug prints to serial monitor
// Enable RS485 transport layer
#define MY_RS485
// Define this to enables DE-pin management on defined pin
#define MY_RS485_DE_PIN 3
// Set RS485 baud rate to use
#define MY_RS485_BAUD_RATE 9600
// Enable this if RS485 is connected to a hardware serial port
//#define MY_RS485_HWSERIAL Serial1
// Enable this if RS485 is connected to Software Serial port:
#include &lt;SoftwareSerial.h&gt;
SoftwareSerial softSerial(4, 2); //rx, tx
#define MY_RS485_SWSERIAL softSerial
#include &lt;MySensors.h&gt;
</code></pre>
]]></description><link>https://forum.mysensors.org/post/71095</link><guid isPermaLink="true">https://forum.mysensors.org/post/71095</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Wed, 12 Jul 2017 19:43:40 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Wed, 12 Jul 2017 19:41:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi PJR,<br />
Thank you,<br />
by kduino</p>
]]></description><link>https://forum.mysensors.org/post/71093</link><guid isPermaLink="true">https://forum.mysensors.org/post/71093</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Wed, 12 Jul 2017 19:41:27 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Tue, 11 Jul 2017 21:11:02 GMT]]></title><description><![CDATA[<p dir="auto">HI PJR,<br />
thank you very much for your reply. I did as you suggested but were not able to test during the last days.<br />
Today I wired it up and it worked. Unfortunately updating some sensor code it is currently not working but as soon as possible I will post the whole sketch together with the adapted MyTransportRS485.ccp.</p>
<p dir="auto">By kduino</p>
]]></description><link>https://forum.mysensors.org/post/71001</link><guid isPermaLink="true">https://forum.mysensors.org/post/71001</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Tue, 11 Jul 2017 21:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Tue, 11 Jul 2017 09:48:05 GMT]]></title><description><![CDATA[<p dir="auto">Just an idea:<br />
I would try adding:</p>
<pre><code>#elif defined(MY_RS485_SWSERIAL)
</code></pre>
<p dir="auto">so it looks like this:</p>
#else
AltSoftSerial _dev;
</code></pre>
<p dir="auto">and in your code define:</p>
<pre><code>#define MY_RS485_HWSERIAL
#define MY_RS485_SWSERIAL mySerial
</code></pre>
<p dir="auto">and see what happens :laughing:</p>
<p dir="auto">ps. the #define of MY_RS485_HWSERIAL is still there since I'm not sure what will be missing for serial communication if that is not defined.</p>
]]></description><link>https://forum.mysensors.org/post/70961</link><guid isPermaLink="true">https://forum.mysensors.org/post/70961</guid><dc:creator><![CDATA[pjr]]></dc:creator><pubDate>Tue, 11 Jul 2017 09:48:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Tue, 04 Jul 2017 15:08:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I think I got to the specific part of code:</p>
<p dir="auto">From Github MySensors/hal/transport/MyTransportRS485.cpp<br />
<a href="https://github.com/mysensors/MySensors/blob/development/hal/transport/MyTransportRS485.cpp#L88" rel="nofollow ugc">https://github.com/mysensors/MySensors/blob/development/hal/transport/MyTransportRS485.cpp#L88</a></p>
#else
AltSoftSerial _dev;
</code></pre>
<p dir="auto">But unfortunately I am not able to change it to the softwareSerial option. How would the code look like if I would make an additional if for the softwareSerial?<br />
Help is very appreciated.</p>
<p dir="auto">By, kduino</p>
]]></description><link>https://forum.mysensors.org/post/70451</link><guid isPermaLink="true">https://forum.mysensors.org/post/70451</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Tue, 04 Jul 2017 15:08:04 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Sun, 23 Apr 2017 14:08:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi Hek,<br />
thank you again for the information. Unfortunately I wasn't able to get it to work like this. Is there a trick in terms of order of the definitions?</p>
<p dir="auto">Thank you so much for your help!</p>
<p dir="auto">kduino</p>
<p dir="auto">Below you will find my sketch:</p>
<pre><code>#include &lt;SoftwareSerial.h&gt;
SoftwareSerial mySerial(4, 2);
#define MY_NODE_ID 80
#define MY_RS485
#define MY_RS485_HWSERIAL mySerial
// Initialize motion message
	sendSketchInfo("Motion Sensor", "1.0");
	present(CHILD_ID, S_MOTION);
	// Read digital motion value
	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
	Serial.println(tripped);
	send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
	sleep(digitalPinToInterrupt(DIGITAL_INPUT_SENSOR), CHANGE, SLEEP_TIME);
</code></pre>
]]></description><link>https://forum.mysensors.org/post/65102</link><guid isPermaLink="true">https://forum.mysensors.org/post/65102</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Sun, 23 Apr 2017 14:08:24 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Sat, 01 Apr 2017 11:09:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
actualy I am still struggling getting the rs485 gateway and the motion sensor example running. for some reason they don't communicate. So I connected them directly over serial output without rs485 module - but still no connection. I will investigate further...<br />
As soon as they are connected I will extend the network....</p>
]]></description><link>https://forum.mysensors.org/post/63743</link><guid isPermaLink="true">https://forum.mysensors.org/post/63743</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Sat, 01 Apr 2017 11:09:10 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Mon, 27 Mar 2017 05:09:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/kduino" aria-label="Profile: kduino">@<bdi>kduino</bdi></a><br />
I think my problem is similar, what I want to do is to send the received sensor data on the serial gateway to a GSM modem for insertion into a Cloud server, but I have no idea of how to capture the data on the serial gateway, IE I can see the sensor values, but how would I trap the data for sending to the GSM modem? Any advice would be appreciated please</p>
]]></description><link>https://forum.mysensors.org/post/63389</link><guid isPermaLink="true">https://forum.mysensors.org/post/63389</guid><dc:creator><![CDATA[esawyja]]></dc:creator><pubDate>Mon, 27 Mar 2017 05:09:25 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Sat, 25 Mar 2017 14:29:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi<br />
Before I was able to go testing I was wondering if the gateway would be much easier (but more dirty) to realize with two stacked arduinos. One is operating the rs485 to serial connection and sends it via serial to the second arduino which in turn is connected to udp or http.<br />
I know it would be neater to go with software but as far as I know this is realized within some hours.<br />
By the way in this case it turns into a good platform adapter since the second arduino can be virtually connected to anything.<br />
What do you think?</p>
<p dir="auto">Have a nice weekend. Kduino</p>
]]></description><link>https://forum.mysensors.org/post/63310</link><guid isPermaLink="true">https://forum.mysensors.org/post/63310</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Sat, 25 Mar 2017 14:29:20 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Tue, 21 Mar 2017 06:33:56 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Thank you very much for the solution <a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a>: this sounds pretty straightforward ;-) and was what I was looking for.<br />
I will check it out this weekend.<br />
It would be fantastic to switch the hole system to mysensors! Since a lot of developing is already done.</p>
<p dir="auto">I will come back to post my results.</p>
<p dir="auto">Best regards<br />
Crty</p>
]]></description><link>https://forum.mysensors.org/post/62920</link><guid isPermaLink="true">https://forum.mysensors.org/post/62920</guid><dc:creator><![CDATA[kduino]]></dc:creator><pubDate>Tue, 21 Mar 2017 06:33:56 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Sun, 19 Mar 2017 22:38:18 GMT]]></title><description><![CDATA[<p dir="auto">No problem,</p>
<p dir="auto">You should be able to use soft serial by defining:</p>
<pre><code>#define MY_RS485_HWSERIAL yoursoftserial
</code></pre>
<p dir="auto">It'll fallback to AltSoftSerial if undefined.</p>
]]></description><link>https://forum.mysensors.org/post/62797</link><guid isPermaLink="true">https://forum.mysensors.org/post/62797</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Sun, 19 Mar 2017 22:38:18 GMT</pubDate></item><item><title><![CDATA[Reply to How to use SoftwareSerial Library? on Sun, 19 Mar 2017 22:33:09 GMT]]></title><description><![CDATA[<p dir="auto">I think there is couple things you need to tweak if you want to use SoftwareSerial instead of AltSoftSerial since its quite well baked in the default solution.</p>
<p dir="auto">See these:</p>
<ul>
<li><a href="https://github.com/mysensors/MySensors/blob/development/MySensors.h#L298" rel="nofollow ugc">https://github.com/mysensors/MySensors/blob/development/MySensors.h#L298</a></li>
<li><a href="https://github.com/mysensors/MySensors/blob/development/core/MyTransportRS485.cpp#L99" rel="nofollow ugc">https://github.com/mysensors/MySensors/blob/development/core/MyTransportRS485.cpp#L99</a></li>
</ul>
]]></description><link>https://forum.mysensors.org/post/62796</link><guid isPermaLink="true">https://forum.mysensors.org/post/62796</guid><dc:creator><![CDATA[pjr]]></dc:creator><pubDate>Sun, 19 Mar 2017 22:33:09 GMT</pubDate></item></channel></rss>
