<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[My first working Switch with Battery and Temperature ..]]></title><description><![CDATA[<p dir="auto">Hi all.</p>
<p dir="auto">I make my first project (thanks to all for help) Switch , with battery and temperature monitoring..</p>
<p dir="auto">here is my node PCB :<br />
<img src="/uploads/upload-5bba35d7-78fc-4779-94e1-196161e3289d.jpg" alt="NodePCB.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">and here is schematic :<br />
<img src="/uploads/upload-4fb03b3f-f051-433d-8cd6-8836d35b9974.png" alt="nodeSchematic.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">and project :<br />
<a href="/uploads/upload-2820cd1f-631b-4f7b-94e6-712d50c842e9.zip">BinSwitchBatSleep_ACK.zip</a></p>
<p dir="auto">This project use two button INT0 and INT1 . if change state then send packet with ACK request .<br />
if no ACK received then generate sound .. from piezoelectric generator .<br />
Battery is in volate *10 - if received value is for example 28 it s 2.8V .</p>
<p dir="auto">now working good .. power consumption is 7uA .</p>
<p dir="auto">PS&gt; I need help with pin change interupt .. I now use two button only .. but want support 4x button.. then need litle help how to  use it ..</p>
<p dir="auto">regards..</p>
]]></description><link>https://forum.mysensors.org/topic/652/my-first-working-switch-with-battery-and-temperature</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 17:50:33 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/652.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 29 Nov 2014 17:12:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to My first working Switch with Battery and Temperature .. on Sun, 30 Nov 2014 18:43:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dzairo" aria-label="Profile: dzairo">@<bdi>dzairo</bdi></a></p>
<p dir="auto">there is a nice <a href="http://forum.arduino.cc/index.php?topic=87195.60" rel="nofollow ugc">PinChangeInterrupt library</a> that you may want to look at.</p>
]]></description><link>https://forum.mysensors.org/post/7238</link><guid isPermaLink="true">https://forum.mysensors.org/post/7238</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Sun, 30 Nov 2014 18:43:03 GMT</pubDate></item><item><title><![CDATA[Reply to My first working Switch with Battery and Temperature .. on Sun, 30 Nov 2014 18:19:12 GMT]]></title><description><![CDATA[<p dir="auto">I know how to do it by diode.. but I want by interrupt only.. I do it my self..</p>
]]></description><link>https://forum.mysensors.org/post/7228</link><guid isPermaLink="true">https://forum.mysensors.org/post/7228</guid><dc:creator><![CDATA[dzairo]]></dc:creator><pubDate>Sun, 30 Nov 2014 18:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to My first working Switch with Battery and Temperature .. on Sun, 30 Nov 2014 17:47:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dzairo" aria-label="Profile: dzairo">@<bdi>dzairo</bdi></a></p>
<p dir="auto">Nick Gammon did an <a href="http://www.gammon.com.au/forum/?id=11091" rel="nofollow ugc">example</a> of four pins 'sharing' one interrupt pin.  Perhaps this will be workable for you.</p>
<p dir="auto">It may be tough to squeeze the 4 diodes onto your board, though!</p>
]]></description><link>https://forum.mysensors.org/post/7219</link><guid isPermaLink="true">https://forum.mysensors.org/post/7219</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Sun, 30 Nov 2014 17:47:53 GMT</pubDate></item><item><title><![CDATA[Reply to My first working Switch with Battery and Temperature .. on Sun, 30 Nov 2014 17:27:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dzairo" aria-label="Profile: dzairo">@<bdi>dzairo</bdi></a>: Nice piece of work and looking at the schematics with enough attention to decoupling and powering the device!</p>
<blockquote>
<p dir="auto">power consumption is 7uA .</p>
</blockquote>
<p dir="auto">I assume that is sleep current. Do you know anything about the average consumption over say one hour?</p>
<blockquote>
<p dir="auto">but want support 4x button.. then need litle help how to use it ..</p>
</blockquote>
<p dir="auto">I think I can not directly help you with this but it would be good to know to which pins the buttons are connected, that is not readable from the schematics above.</p>
]]></description><link>https://forum.mysensors.org/post/7217</link><guid isPermaLink="true">https://forum.mysensors.org/post/7217</guid><dc:creator><![CDATA[daulagari]]></dc:creator><pubDate>Sun, 30 Nov 2014 17:27:22 GMT</pubDate></item></channel></rss>
