<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New to MySensors - how to get started]]></title><description><![CDATA[<p dir="auto">I am using openHAB Home Automation, and there I saw a binding to MySensors. I decided to look closer into how I could benefit from MySensors. My first idea was to use a ESP8266,a nd I have played around with that. The problem is that I have some PIR sensors, and there seems to be a problem when they ar only supplied with 3.3V. Else it seems that MySensors as concept is great! To get the PIR sensor up and running I turned towards amy Raspberry Pi's acting as ZoneMinder cameras, they are Raspberry Pi 3 and Raspberry Pi 2 (with an EdiMax Wifi dongle).<br />
I have tried to get a gateway up and runnign, both Ethernet and MQTT, with no luck. It seems to fail on radio initialisation (becasue it is just a plain Raspberry Pi, with no custom RF module attached). I have thus been looking for a guide on how to use the plain wifi to connect to the controller in openHAB, with no luck.</p>
<p dir="auto">Is there any possibility to configure a Raspberry Pi 3 as a gateway that connects to a openHAB controller, without attaching an extra radio? I just want to monitor a couple of GPIO pins in my Raspberry Pi. Is it possible or have I misunderstood the concept?</p>
]]></description><link>https://forum.mysensors.org/topic/6537/new-to-mysensors-how-to-get-started</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 06:10:38 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6537.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Mar 2017 12:29:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New to MySensors - how to get started on Sat, 25 Mar 2017 20:02:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/63323">New to MySensors - how to get started</a>:</p>
<blockquote>
<p dir="auto">Start reading around the site <a href="https://www.mysensors.org/build" rel="nofollow ugc">https://www.mysensors.org/build</a></p>
</blockquote>
<p dir="auto">Thx, seems like there is some help there :-)</p>
]]></description><link>https://forum.mysensors.org/post/63324</link><guid isPermaLink="true">https://forum.mysensors.org/post/63324</guid><dc:creator><![CDATA[mr.eskildsen]]></dc:creator><pubDate>Sat, 25 Mar 2017 20:02:12 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Sat, 25 Mar 2017 19:52:08 GMT]]></title><description><![CDATA[<p dir="auto">Start reading around the site <a href="https://www.mysensors.org/build" rel="nofollow ugc">https://www.mysensors.org/build</a><br />
PIR Sensor would need to be connected to another arduino board with another radio; the arduino node will be talking to raspberry via the radio modules.</p>
]]></description><link>https://forum.mysensors.org/post/63323</link><guid isPermaLink="true">https://forum.mysensors.org/post/63323</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Sat, 25 Mar 2017 19:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Sat, 25 Mar 2017 19:46:12 GMT]]></title><description><![CDATA[<p dir="auto">Ok, but I think I am lacking the basic understanding of Gateways, Sensor node etc.<br />
Is there somewhere where I can read about the different objects (eg. Gateway, Sensor Nodes)?<br />
I think MySensors has a big potential in my setup, but I am unsure how to get started. If I buy a radio to the Raspberry Pi's where I want to attach my PIR sensors would it then work?</p>
]]></description><link>https://forum.mysensors.org/post/63322</link><guid isPermaLink="true">https://forum.mysensors.org/post/63322</guid><dc:creator><![CDATA[mr.eskildsen]]></dc:creator><pubDate>Sat, 25 Mar 2017 19:46:12 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Sat, 25 Mar 2017 00:42:43 GMT]]></title><description><![CDATA[<p dir="auto">Esp8266 has to be considered as a gateway on its own that you can use together with supported radios</p>
]]></description><link>https://forum.mysensors.org/post/63294</link><guid isPermaLink="true">https://forum.mysensors.org/post/63294</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Sat, 25 Mar 2017 00:42:43 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 21:54:30 GMT]]></title><description><![CDATA[<p dir="auto">I things is starting to get a little more clear to me. So in MySensors world we have:</p>
<ul>
<li>Controller</li>
<li>Gateway(s)</li>
<li>Sensors</li>
</ul>
<p dir="auto">So I guess the purpose of the radio on the Gateway (in my example the Raspberry Pi), is to communicate with the Sensor nodes? Where a Sensor node is a Arduino, ESP8622?<br />
I still think that I can have some beneft from this great framework, I just have to understand it :-)<br />
Is there some explanation / overview of how things is put together ?</p>
]]></description><link>https://forum.mysensors.org/post/63293</link><guid isPermaLink="true">https://forum.mysensors.org/post/63293</guid><dc:creator><![CDATA[mr.eskildsen]]></dc:creator><pubDate>Fri, 24 Mar 2017 21:54:30 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 18:55:05 GMT]]></title><description><![CDATA[<p dir="auto">I don't think you would benefit much from mysensors in this situation. This framework is more focused on small Arduino based sensors nodes that talk to a gateway and the gateway talks to a home automation controller. But maybe developers know some hack on the code</p>
]]></description><link>https://forum.mysensors.org/post/63285</link><guid isPermaLink="true">https://forum.mysensors.org/post/63285</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 24 Mar 2017 18:55:05 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 13:20:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/63271">New to MySensors - how to get started</a>:</p>
<blockquote>
<p dir="auto">I think you are mixing things. If you want to read gpio from raspberry where openhab is installed, you don't need mysensors. If you have wireless pir sensors then you need a radio also for raspberry</p>
</blockquote>
<p dir="auto">I don't want to  read GPIO from the Raspberry where openHAB is installed. My question is more to understand if MySensors framework can help me. As an example I have some Raspberry Pi's (they are used as ZoneMinder cameras), they are connected to my network via either LAN cable or Wifi.<br />
If I attach a sensor to that Raspberry,  is it then possible to install a MySensor Gateway on that particular Raspberry Pi and via <strong>existing</strong> network connection connect to the MySensor Controller hosted in my openHAB instance?</p>
]]></description><link>https://forum.mysensors.org/post/63273</link><guid isPermaLink="true">https://forum.mysensors.org/post/63273</guid><dc:creator><![CDATA[mr.eskildsen]]></dc:creator><pubDate>Fri, 24 Mar 2017 13:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 13:10:43 GMT]]></title><description><![CDATA[<p dir="auto">I think you are mixing things. If you want to read gpio from raspberry where openhab is installed, you don't need mysensors. If you have wireless pir sensors then you need a radio also for raspberry</p>
]]></description><link>https://forum.mysensors.org/post/63271</link><guid isPermaLink="true">https://forum.mysensors.org/post/63271</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 24 Mar 2017 13:10:43 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 12:58:25 GMT]]></title><description><![CDATA[<p dir="auto">I am interested to know if I can use a Raspberry Pi 3 as gateway, <strong>without</strong>  adding any extra hardware to communicate to the controller (eg. can I use either LAN connection or WiFi)?</p>
]]></description><link>https://forum.mysensors.org/post/63268</link><guid isPermaLink="true">https://forum.mysensors.org/post/63268</guid><dc:creator><![CDATA[mr.eskildsen]]></dc:creator><pubDate>Fri, 24 Mar 2017 12:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to New to MySensors - how to get started on Fri, 24 Mar 2017 12:54:08 GMT]]></title><description><![CDATA[<p dir="auto">There is another thread open about 5V pir sensor problems: you need to supply voltage with 3 AA batteries if you removed the voltage regulator</p>
]]></description><link>https://forum.mysensors.org/post/63267</link><guid isPermaLink="true">https://forum.mysensors.org/post/63267</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 24 Mar 2017 12:54:08 GMT</pubDate></item></channel></rss>
