<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors?]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have a problem which has been bothering me two evenings now; and I am just wondering if someone has a clever idea to get closer to the solution, or have a solution in general.</p>
<p dir="auto">I have a NodeMCU ESP8266 setup as MQTT gateway using the default pin layout as described on <a href="https://www.mysensors.org/build/connect_radio" rel="nofollow ugc">https://www.mysensors.org/build/connect_radio</a>. This works perfect, and have been doing various tests now with battery based sensors.</p>
<p dir="auto">But, now I also want to create a backup system to a MicroSD card on this gateway using an <a href="https://www.aliexpress.com/item/1pcs-lot-Micro-SD-card-mini-TF-card-reader-module-SPI-interfaces-with-level-converter-chip/32735273502.html" rel="nofollow ugc">MicroSD adapter</a>. My <strong>receive()</strong> function will do these activities. Now the only problem is that I just <em>cannot</em> get the radio and SD card work together.</p>
<p dir="auto">Even not when <strong>not</strong> including the SD.h (or other related) libraries. The moment the CS pin is removed from the breadboard, the NodeMCU almost instantly continues and the radio turns on.</p>
<p dir="auto">These two evenings have been quite educational, but now it's time to get this to work :-). I also tested on another NodeMCU, which has the same issue. The SD card works standalone perfectly. Also with the radio connected it works perfect. It's just the radio that refuses to work and continues to give:</p>
<pre><code>0;255;3;0;9;TSM:INIT
0;255;3;0;9;RF24:write register, reg=0, value=14
0;255;3;0;9;RF24:write register, reg=3, value=3
0;255;3;0;9;RF24:write register, reg=4, value=95
0;255;3;0;9;RF24:write register, reg=5, value=76
0;255;3;0;9;RF24:write register, reg=6, value=39
0;255;3;0;9;RF24:write register, reg=16, value=115
0;255;3;0;9;RF24:write register, reg=29, value=6
0;255;3;0;9;RF24:read register, reg=6, value=0
0;255;3;0;9;RF24:read register, reg=5, value=0
0;255;3;0;9;!RF24:INIT:SANCHK FAIL
0;255;3;0;9;!TSM:INIT:TSP FAIL
0;255;3;0;9;TSM:FAIL:CNT=7
0;255;3;0;9;TSM:FAIL:PDT
0;255;3;0;9;RF24:write register, reg=0, value=12
</code></pre>
<p dir="auto">The CS of the <em>radio</em> is on <strong>D8</strong> and the CS of the <em>SD reader</em> is <strong>D4</strong>. This matches with the pins as seen below (according to: <a href="https://pradeepsinghblog.files.wordpress.com/2016/04/nodemcu_pins.png?w=616" rel="nofollow ugc">https://pradeepsinghblog.files.wordpress.com/2016/04/nodemcu_pins.png?w=616</a>)</p>
<p dir="auto">This results from the <strong>before()</strong> function (serial print from the program):</p>
<pre><code>RF 24 CS PIN
SD CS PIN
pins low
SD_CS_PIN is HIGH - GOOD
MY_RF24_CS_PIN is LOW - GOOD
</code></pre>
<p dir="auto">The SD_CS pin is put to HIGH in the before() and pinmode are set in the before function:</p>
<pre><code>pinMode (SD_CS_PIN, OUTPUT);
digitalWrite (SD_CS_PIN, HIGH);
pinMode (MY_RF24_CS_PIN, OUTPUT);
digitalWrite (MY_RF24_CS_PIN, LOW );
</code></pre>
<p dir="auto"><strong>Remember</strong>: The SD libraries are not used at all. No <strong>begin()</strong> functions of any kind are called.</p>
<p dir="auto">This is what I have learned over the evenings, and I think this is all what it should be. The only thing I can think of is that the SD module just ignores the CS value.</p>
<p dir="auto">Hope that someone has a clue what could solve this issue. I am out of ideas right now.</p>
]]></description><link>https://forum.mysensors.org/topic/6724/solved-nodemcu-esp8266-and-spi-with-nrf24l01-sd-card-module-sanity-errors</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 19:55:27 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6724.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Apr 2017 20:53:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Fri, 28 Apr 2017 17:33:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> Indeed... See e.g. my experience here: <a href="https://forum.mysensors.org/topic/2890/chinese-rubbish-or-is-it">https://forum.mysensors.org/topic/2890/chinese-rubbish-or-is-it</a></p>
]]></description><link>https://forum.mysensors.org/post/65439</link><guid isPermaLink="true">https://forum.mysensors.org/post/65439</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Fri, 28 Apr 2017 17:33:05 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Fri, 28 Apr 2017 10:37:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/yveaux" aria-label="Profile: Yveaux">@<bdi>Yveaux</bdi></a> sometimes I just wonder if the designer of a module just copied another one just by looking at it and then put it to production without even testing it.</p>
]]></description><link>https://forum.mysensors.org/post/65427</link><guid isPermaLink="true">https://forum.mysensors.org/post/65427</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 28 Apr 2017 10:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Thu, 27 Apr 2017 15:20:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kokosnoot" aria-label="Profile: Kokosnoot">@<bdi>Kokosnoot</bdi></a> great to hear you solved it!<br />
Crappy design module once more...<br />
Usually I always start googling schematics of any new modules I buy, just to prevent surprises like this!</p>
]]></description><link>https://forum.mysensors.org/post/65402</link><guid isPermaLink="true">https://forum.mysensors.org/post/65402</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Thu, 27 Apr 2017 15:20:05 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Thu, 27 Apr 2017 15:05:21 GMT]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/6724/nodemcu-esp8266-and-spi-with-nrf24l01-sd-card-module-sanity-errors">NodeMCU ESP8266 and SPI with NRF24L01 + SD card module - sanity errors?</a></p>
<p dir="auto">Separate reply just for searching purposes:</p>
<p dir="auto">It worked :-)! Now it's working perfect <em><strong>without changing a single line of code or changing wires</strong></em>. I took the risk of destroying the module, but otherwise it's useless anyway for my project. I managed to use a knife to take a few mm's of pin 13 up and then to solder a wire to pin 8 and pin 13. As described in the linked topic.</p>
<p dir="auto"><img src="/assets/uploads/files/1493305336050-sdcardfix.jpeg" alt="0_1493305335364_sdcardfix.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">My SD backup system one step closer! :D</p>
]]></description><link>https://forum.mysensors.org/post/65400</link><guid isPermaLink="true">https://forum.mysensors.org/post/65400</guid><dc:creator><![CDATA[Kokosnoot]]></dc:creator><pubDate>Thu, 27 Apr 2017 15:05:21 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Thu, 27 Apr 2017 14:20:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Yveaux,</p>
<p dir="auto">I don't know what comes after quadruple (quintuble? :)) but I checked the wires many times. Radio works perfect without SD card reader. SD card worked with radio connected - but then the radio does not work anymore.</p>
<p dir="auto">I made a fritzing of my setup, just to spot any errors, just to go check each connection once more.</p>
<p dir="auto"><img src="/assets/uploads/files/1493301509855-fritzing-sketches_sd_nrf-small.png" alt="0_1493301509222_fritzing-sketches_sd_nrf-small.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">One thing I can think of is that the GPIO15 is a hardware CS (HCS), while my D4 is not. But every example I see on the internet says that practically any pin can be the CS pin?</p>
<p dir="auto"><strong>Update</strong></p>
<p dir="auto">More searching let me to this topic: <a href="https://forum.arduino.cc/index.php?topic=360718.0" rel="nofollow ugc">https://forum.arduino.cc/index.php?topic=360718.0</a> which I think might be the case. Unfortunately, I do not have the tools to apply this fix I think. <img src="https://s22.postimg.org/gagrblv35/mod.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/65398</link><guid isPermaLink="true">https://forum.mysensors.org/post/65398</guid><dc:creator><![CDATA[Kokosnoot]]></dc:creator><pubDate>Thu, 27 Apr 2017 14:20:22 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] NodeMCU ESP8266 and SPI with NRF24L01 + SD card module  - sanity errors? on Thu, 27 Apr 2017 06:18:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kokosnoot" aria-label="Profile: Kokosnoot">@<bdi>Kokosnoot</bdi></a> I guess you quadruple checked the miso, mosi and clk connections, right?</p>
]]></description><link>https://forum.mysensors.org/post/65376</link><guid isPermaLink="true">https://forum.mysensors.org/post/65376</guid><dc:creator><![CDATA[Yveaux]]></dc:creator><pubDate>Thu, 27 Apr 2017 06:18:40 GMT</pubDate></item></channel></rss>
