<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mains voltage current sensor?]]></title><description><![CDATA[<p dir="auto">Any advice on sensing current in mains voltage (240V) circuits?</p>
<p dir="auto">What I'm trying to do is to monitor the dishwasher and washing machines, so I can sense when they're done and alert someone to go empty them.</p>
]]></description><link>https://forum.mysensors.org/topic/6757/mains-voltage-current-sensor</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 08:37:59 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6757.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 May 2017 13:18:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mains voltage current sensor? on Wed, 03 May 2017 08:58:16 GMT]]></title><description><![CDATA[<p dir="auto">you can make a dash button that when pressed sets a timer on the controller. With sonoff pow you get energy metering and also a relay tu turn on and off your appliance</p>
]]></description><link>https://forum.mysensors.org/post/65789</link><guid isPermaLink="true">https://forum.mysensors.org/post/65789</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Wed, 03 May 2017 08:58:16 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Wed, 03 May 2017 08:41:38 GMT]]></title><description><![CDATA[<p dir="auto">The sonoff pow looks interesting actually. 10 USD is a really good price.</p>
]]></description><link>https://forum.mysensors.org/post/65788</link><guid isPermaLink="true">https://forum.mysensors.org/post/65788</guid><dc:creator><![CDATA[maghac]]></dc:creator><pubDate>Wed, 03 May 2017 08:41:38 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Wed, 03 May 2017 08:39:31 GMT]]></title><description><![CDATA[<p dir="auto">Exactly, I don't want to modify the appliances in any way :)</p>
<p dir="auto">If I monitor the current drawn by the appliance I can detect both when it starts and when it finishes. With a countdown timer I need to start it myself and if I forget to start it I will not get a reminder when it's done.</p>
]]></description><link>https://forum.mysensors.org/post/65787</link><guid isPermaLink="true">https://forum.mysensors.org/post/65787</guid><dc:creator><![CDATA[maghac]]></dc:creator><pubDate>Wed, 03 May 2017 08:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Wed, 03 May 2017 05:52:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zboblamont" aria-label="Profile: zboblamont">@<bdi>zboblamont</bdi></a> because it's easier to attach a sensor to the power plug instead of hacking the machine's controller 😀. For what is worth, I think that a normal countdown timer will be enough since washing cycles have always the same length.</p>
]]></description><link>https://forum.mysensors.org/post/65784</link><guid isPermaLink="true">https://forum.mysensors.org/post/65784</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Wed, 03 May 2017 05:52:14 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Wed, 03 May 2017 04:51:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maghac" aria-label="Profile: maghac">@<bdi>maghac</bdi></a> Why measure current? It will vary with the program in use, and so will water consumption. Both devices have controllers, both will signal the end of a cycle and go standby, usually triggering a bleeper, these are usually low volt DC. Tap into that?<br />
You must have a distant machine not to hear it, I can hear the washing machine bleep through a wall, the dishwasher is usually quiet until she finishes, then gets noisy again :stuck_out_tongue_winking_eye:</p>
]]></description><link>https://forum.mysensors.org/post/65779</link><guid isPermaLink="true">https://forum.mysensors.org/post/65779</guid><dc:creator><![CDATA[zboblamont]]></dc:creator><pubDate>Wed, 03 May 2017 04:51:11 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Tue, 02 May 2017 18:58:16 GMT]]></title><description><![CDATA[<p dir="auto">Sonoff pow?</p>
]]></description><link>https://forum.mysensors.org/post/65769</link><guid isPermaLink="true">https://forum.mysensors.org/post/65769</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Tue, 02 May 2017 18:58:16 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Tue, 02 May 2017 16:38:19 GMT]]></title><description><![CDATA[<p dir="auto"><a href="http://Www.openenergymonitor.org" rel="nofollow ugc">Www.openenergymonitor.org</a> has a lot of info on current, voltage, and power monitoring. It isnt mysensors specific, but it is detailed and can likely be made to work.</p>
]]></description><link>https://forum.mysensors.org/post/65763</link><guid isPermaLink="true">https://forum.mysensors.org/post/65763</guid><dc:creator><![CDATA[wallyllama]]></dc:creator><pubDate>Tue, 02 May 2017 16:38:19 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Tue, 02 May 2017 16:14:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/henrywhite" aria-label="Profile: HenryWhite">@<bdi>HenryWhite</bdi></a> That would work for the washing machine, but not for the dishwasher I guess as it doesn't move a lot :)</p>
]]></description><link>https://forum.mysensors.org/post/65762</link><guid isPermaLink="true">https://forum.mysensors.org/post/65762</guid><dc:creator><![CDATA[maghac]]></dc:creator><pubDate>Tue, 02 May 2017 16:14:30 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Tue, 02 May 2017 15:56:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maghac" aria-label="Profile: maghac">@<bdi>maghac</bdi></a> said in <a href="/post/65749">Mains voltage current sensor?</a>:</p>
<blockquote>
<p dir="auto">so I can sense when they're done and alert someone to go empty them.</p>
</blockquote>
<p dir="auto">If you just want to do that, you could also use a vibration sensor to determine whether the dryer/ washing machine has finished or not.</p>
]]></description><link>https://forum.mysensors.org/post/65760</link><guid isPermaLink="true">https://forum.mysensors.org/post/65760</guid><dc:creator><![CDATA[HenryWhite]]></dc:creator><pubDate>Tue, 02 May 2017 15:56:31 GMT</pubDate></item><item><title><![CDATA[Reply to Mains voltage current sensor? on Tue, 02 May 2017 14:05:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/maghac" aria-label="Profile: maghac">@<bdi>maghac</bdi></a> - I have just ordered som parts im going to play around with.<br />
I bought the 30A current sensor but there are also som clamps so you dont have to make any cuts into wires:<br />
<a href="https://www.mysensors.org/store/power" rel="nofollow ugc">https://www.mysensors.org/store/power</a></p>
<p dir="auto">I think im going to build a portable Swedish plug standard machine, something looking like a relay but measures current.<br />
<a href="https://ae01.alicdn.com/kf/HTB1WHv.MpXXXXcwXFXXq6xXFXXXA/AC-230V-Digital-16A-LCD-Electric-1W-3680W-Power-Energy-Meter-Voltage-Wattage-font-b-Current.jpg" rel="nofollow ugc">https://ae01.alicdn.com/kf/HTB1WHv.MpXXXXcwXFXXq6xXFXXXA/AC-230V-Digital-16A-LCD-Electric-1W-3680W-Power-Energy-Meter-Voltage-Wattage-font-b-Current.jpg</a></p>
]]></description><link>https://forum.mysensors.org/post/65750</link><guid isPermaLink="true">https://forum.mysensors.org/post/65750</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Tue, 02 May 2017 14:05:34 GMT</pubDate></item></channel></rss>
