<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Need help with Raspberry Pi Gateway]]></title><description><![CDATA[<p dir="auto">I have 4 Nano/NRF24 sensor nodes with NODE-ID's defined in the sketches.<br />
They work just fine with a W5100 MQTT Gateway, all nodes are recognized and messages passed to the MQTT broker.  However when I instead use a Raspberry Pi, configured as a MQTT gateway, only one of the nodes seems to be recognized.  What do I need to do to have all nodes recognized (two sensor nodes have the same 105 NODE_ID)?</p>
<pre><code>mysgw: TSF:MSG:READ,105-105-0,s=133,c=1,t=37,pt=2,l=2,sg=0:3
mysgw: Sending message on topic: my103gw-out/105/133/1/0/37
mysgw: TSF:MSG:READ,105-105-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:FPAR REQ,ID=105
mysgw: TSF:CKU:OK,FCTRL
mysgw: TSF:MSG:GWL OK
mysgw: !TSF:MSG:SEND,0-0-105-105,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
mysgw: TSF:MSG:READ,133-133-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:FPAR REQ,ID=133
mysgw: !TSF:MSG:SEND,0-0-133-133,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
mysgw: TSF:MSG:READ,132-132-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:FPAR REQ,ID=132
mysgw: !TSF:MSG:SEND,0-0-132-132,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=NACK:0
mysgw: TSF:MSG:BC
mysgw: TSF:MSG:READ,105-105-0,s=134,c=1,t=0,pt=7,l=5,sg=0:18
mysgw: Sending message on topic: my103gw-out/105/134/1/0/0
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/6884/need-help-with-raspberry-pi-gateway</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 01:46:26 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6884.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 24 May 2017 21:47:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Need help with Raspberry Pi Gateway on Thu, 25 May 2017 19:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> I missed the * in the wiring of the PA radio and wired it to the GPIO 3.3V pin; I had assumed that since the gateway was getting the one node solidly/all the time and the other nodes not at all, there must have been an issue other than power. I must say, the power issue is mentioned often enough on <a href="http://MySensors.org" rel="nofollow ugc">MySensors.org</a> that I should have tried that solution a long time ago.<br />
Thanks again.</p>
]]></description><link>https://forum.mysensors.org/post/67676</link><guid isPermaLink="true">https://forum.mysensors.org/post/67676</guid><dc:creator><![CDATA[GrantsPi]]></dc:creator><pubDate>Thu, 25 May 2017 19:21:24 GMT</pubDate></item><item><title><![CDATA[Reply to Need help with Raspberry Pi Gateway on Thu, 25 May 2017 15:37:30 GMT]]></title><description><![CDATA[<p dir="auto">If you are using the 3.3v from rpi gpio you would normally need a capacitor and when using the PA radio you would normally use the 5v plus a voltage regulator, since gpio pins usually can't provide enough current</p>
]]></description><link>https://forum.mysensors.org/post/67656</link><guid isPermaLink="true">https://forum.mysensors.org/post/67656</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Thu, 25 May 2017 15:37:30 GMT</pubDate></item><item><title><![CDATA[Reply to Need help with Raspberry Pi Gateway on Thu, 25 May 2017 15:19:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> Thank you!  The RPI is powered from the USB port on my ASUS router (I had powered it from a 2.5 amp USB source in the past with no change in result).  However, I had been using the NRF24L01 with the antenna; I changed the radio to a NRF24L01+ and -- success!  So it must be a power issue after all.  I have used the antenna version on the sensors in the past with no problems.  I haven't used capacitors yet, I'll try those soon.  But for the moment, I'm back in operation.<br />
Thank you!</p>
]]></description><link>https://forum.mysensors.org/post/67653</link><guid isPermaLink="true">https://forum.mysensors.org/post/67653</guid><dc:creator><![CDATA[GrantsPi]]></dc:creator><pubDate>Thu, 25 May 2017 15:19:28 GMT</pubDate></item><item><title><![CDATA[Reply to Need help with Raspberry Pi Gateway on Thu, 25 May 2017 06:24:54 GMT]]></title><description><![CDATA[<p dir="auto">Nack messages mean that it didn't get a response usually due to signal problems or insufficient power. How do you power the nrf24 on the rpi? What cap did you use on the radio?</p>
]]></description><link>https://forum.mysensors.org/post/67618</link><guid isPermaLink="true">https://forum.mysensors.org/post/67618</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Thu, 25 May 2017 06:24:54 GMT</pubDate></item></channel></rss>
