<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Distance+Humidity, Vera Registration Issue]]></title><description><![CDATA[<p dir="auto">I have mashed code together to run a temp/humidity sensor as well as distance sensor off of the same Arduino. I have the unit functioning properly, where I am getting temp, distance and humidity readings off of the serial monitor.</p>
<p dir="auto">I have included the device in my vera, and 3 devices are recognized.</p>
<ul>
<li>Temp</li>
<li>Humidity</li>
<li>"Arduino Node 1"</li>
</ul>
<p dir="auto">The first 2 are correct, and are reporting correctly. The last one should be distance, but it is not, and is not reporting correctly. Below is the code, as well as a snap of the vera interface. Any assistance would be appreciated!</p>
<p dir="auto">I think the issue is in how I modified the void setup, adding two gw.sendSketchInfo? If I just add the native distance sensor code, vera reports the correct distance device. However, it still reports that "Arduino Node 1" device.</p>
<p dir="auto"><a href="http://imgur.com/DThOePT" rel="nofollow ugc">http://imgur.com/DThOePT</a></p>
<p dir="auto"><a href="/uploads/upload-798a4367-1e0d-4c57-a548-059e74d93c19.ino">Distance_Temp_Humid.ino</a></p>
]]></description><link>https://forum.mysensors.org/topic/69/distance-humidity-vera-registration-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 05:32:14 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/69.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Apr 2014 02:11:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Distance+Humidity, Vera Registration Issue on Sun, 27 Apr 2014 02:44:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notyetrated" aria-label="Profile: NotYetRated">@<bdi>NotYetRated</bdi></a></p>
<p dir="auto">I've been doing the same stuff, creating multi-sensors, making mistakes like that are part of it.</p>
<p dir="auto">I'll post some when I'm back.</p>
<p dir="auto">Fun stuff.</p>
]]></description><link>https://forum.mysensors.org/post/362</link><guid isPermaLink="true">https://forum.mysensors.org/post/362</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Sun, 27 Apr 2014 02:44:48 GMT</pubDate></item><item><title><![CDATA[Reply to Distance+Humidity, Vera Registration Issue on Sun, 27 Apr 2014 02:35:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bulldoglowell" aria-label="Profile: BulldogLowell">@<bdi>BulldogLowell</bdi></a></p>
<p dir="auto">Quick fix. Thanks so much for the quick response! Stupid mistake.</p>
]]></description><link>https://forum.mysensors.org/post/361</link><guid isPermaLink="true">https://forum.mysensors.org/post/361</guid><dc:creator><![CDATA[NotYetRated]]></dc:creator><pubDate>Sun, 27 Apr 2014 02:35:42 GMT</pubDate></item><item><title><![CDATA[Reply to Distance+Humidity, Vera Registration Issue on Sun, 27 Apr 2014 02:21:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/notyetrated" aria-label="Profile: NotYetRated">@<bdi>NotYetRated</bdi></a></p>
<p dir="auto">You are presenting two sensors as child number 0</p>
<p dir="auto">gw.sendSensorPresentation(CHILD_ID_HUM, S_HUM);</p>
]]></description><link>https://forum.mysensors.org/post/360</link><guid isPermaLink="true">https://forum.mysensors.org/post/360</guid><dc:creator><![CDATA[BulldogLowell]]></dc:creator><pubDate>Sun, 27 Apr 2014 02:21:38 GMT</pubDate></item></channel></rss>
