<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Cutting the voltage regulator]]></title><description><![CDATA[<p dir="auto">It's not clear to me how to properly cut the regulator. According to <a href="https://www.mysensors.org/build/battery" rel="nofollow ugc">this documentation</a> it should suffice to cut one leg but then I don't see how this could work?</p>
<p dir="auto">This is <a href="https://nl.aliexpress.com/store/product/2pcs-ATMEGA328P-Pro-Mini-328-Mini-ATMEGA328-3-3-V-16-MHz-for-Arduino-3-3/1983387_32774241482.html" rel="nofollow ugc">the board I'm using</a>:<br />
<img src="https://ae01.alicdn.com/kf/HTB10ACZPXXXXXXLXFXXq6xXFXXXw/2pcs-ATMEGA328P-Pro-Mini-328-Mini-ATMEGA328-3-3V-8-MHz-for-Arduino-3-3V-8Mt.jpg" alt="This is the board I'm using." class=" img-fluid img-markdown" /></p>
<p dir="auto">Should I completely remove the regulator? Or how will it work if I only cut the lower right leg?</p>
<p dir="auto">I tried cutting the wire just before the circle as marked on the image but then I couldn't program the board anymore. Perhaps I cut it in the wrong place or I'm feeding it gnd/vcc wrongly?</p>
]]></description><link>https://forum.mysensors.org/topic/6901/cutting-the-voltage-regulator</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 17:19:54 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6901.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 May 2017 13:36:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Cutting the voltage regulator on Tue, 30 May 2017 18:39:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mpp" aria-label="Profile: mpp">@<bdi>mpp</bdi></a> - No, the voltage regulator is engaged when providing power to RAW and regulates the voltages down from whatever you input to 5v. Therefore you can remove it when providing a stable power source to VCC. What happens though is that there is a drain/leakage of current even when you provide power to VCC. Therefore its good to remove it.</p>
<p dir="auto">Edit: Therefore... I love my Swedenglish...</p>
]]></description><link>https://forum.mysensors.org/post/68043</link><guid isPermaLink="true">https://forum.mysensors.org/post/68043</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Tue, 30 May 2017 18:39:58 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Tue, 30 May 2017 18:09:08 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for the tips.</p>
<blockquote>
<p dir="auto">No, you need to feed a regulated voltage to VCC. The "easy" explanation is that the voltage regulator is only engaged when providing a powersource to RAW.</p>
</blockquote>
<p dir="auto">I don't get this, I never use RAW so there's no advantage in removing the regulator.. ?</p>
<p dir="auto">Isn't it the other way round, that the regulator is only engaged when using VCC?</p>
]]></description><link>https://forum.mysensors.org/post/68036</link><guid isPermaLink="true">https://forum.mysensors.org/post/68036</guid><dc:creator><![CDATA[mpp]]></dc:creator><pubDate>Tue, 30 May 2017 18:09:08 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Tue, 30 May 2017 17:49:55 GMT]]></title><description><![CDATA[<p dir="auto">Great <a class="plugin-mentions-user plugin-mentions-a" href="/user/nca78" aria-label="Profile: Nca78">@<bdi>Nca78</bdi></a>, I added the video here:<br />
<a href="https://www.mysensors.org/build/battery" rel="nofollow ugc">https://www.mysensors.org/build/battery</a></p>
]]></description><link>https://forum.mysensors.org/post/68030</link><guid isPermaLink="true">https://forum.mysensors.org/post/68030</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Tue, 30 May 2017 17:49:55 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Mon, 29 May 2017 06:07:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a> yes you are right, and resistors heat up more easily also so it might be a 2 seconds job, I'll do it next time.<br />
And in any case it would be better to remove regulator first.</p>
]]></description><link>https://forum.mysensors.org/post/67900</link><guid isPermaLink="true">https://forum.mysensors.org/post/67900</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Mon, 29 May 2017 06:07:19 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Mon, 29 May 2017 06:03:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nca78" aria-label="Profile: Nca78">@<bdi>Nca78</bdi></a> - great informative video!<br />
I remove the regulator to the right (marked 102) since this is connected in series (same result as removing the led) with the led and easier to get to. The led is cramped in between the regulator and the capacitor so might be easier if the setup is the same on your boards...</p>
]]></description><link>https://forum.mysensors.org/post/67899</link><guid isPermaLink="true">https://forum.mysensors.org/post/67899</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Mon, 29 May 2017 06:03:53 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Mon, 29 May 2017 05:42:11 GMT]]></title><description><![CDATA[<p dir="auto">I agree with <a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a> it's much easier to unsolder it than butchering the PCB :)</p>
<p dir="auto">Check the video here, not good quality but you will get the point<br />
<a href="https://www.youtube.com/watch?v=7qujkC72dYs" rel="nofollow ugc">https://www.youtube.com/watch?v=7qujkC72dYs</a></p>
]]></description><link>https://forum.mysensors.org/post/67898</link><guid isPermaLink="true">https://forum.mysensors.org/post/67898</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Mon, 29 May 2017 05:42:11 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Sun, 28 May 2017 13:57:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mpp" aria-label="Profile: mpp">@<bdi>mpp</bdi></a></p>
<blockquote>
<p dir="auto">How can the board keep working when it is completely removed, don't you need to bridge some pads?</p>
</blockquote>
<blockquote>
<p dir="auto">What pins should I use to program it (There's only one VCC pint but some arduino clones seem indicate several GND pins where some other indicate blk or dtr)</p>
</blockquote>
<p dir="auto">On the short side there are the ftdi header you use to program the board with. Check <a href="https://www.byggahus.se/forum/villalarm-hemautomation/262039-att-hemmasnickra-ett-hemautomationsystem-domoticz-mysensors-org-9.html?perpage=15#post2591492" rel="nofollow ugc">here</a> (swedish but you see the pictures)</p>
<blockquote>
<p dir="auto">What voltage do I supply without the regulator (I assume 3.3)?</p>
</blockquote>
<p dir="auto">You need to regulate to voltage to a stable 3.3v (or below depending on BOD/fuses) and provide it to VCC.</p>
]]></description><link>https://forum.mysensors.org/post/67841</link><guid isPermaLink="true">https://forum.mysensors.org/post/67841</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sun, 28 May 2017 13:57:02 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Sun, 28 May 2017 13:42:39 GMT]]></title><description><![CDATA[<p dir="auto">thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a>, seems like I broke mine as well. Some questions remain:</p>
<ul>
<li>How can the board keep working when it is completely removed, don't you need to bridge some pads?</li>
<li>What pins should I use to program it (There's only one VCC pint but some arduino clones seem indicate several GND pins where some other indicate blk or dtr)</li>
<li>What voltage do I supply without the regulator (I assume 3.3)?</li>
</ul>
]]></description><link>https://forum.mysensors.org/post/67839</link><guid isPermaLink="true">https://forum.mysensors.org/post/67839</guid><dc:creator><![CDATA[mpp]]></dc:creator><pubDate>Sun, 28 May 2017 13:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Cutting the voltage regulator on Sun, 28 May 2017 13:39:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mpp" aria-label="Profile: mpp">@<bdi>mpp</bdi></a> - i find it much harder to cut a leg/trace then desolder everything. I put my soldering iron on one side over all pins and bend gently upp. When they are free from the pads i desolder the other side and it comes off. Same with led/resistor. I never cut, always desolder. I have broken to many trying to cut.</p>
]]></description><link>https://forum.mysensors.org/post/67837</link><guid isPermaLink="true">https://forum.mysensors.org/post/67837</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sun, 28 May 2017 13:39:33 GMT</pubDate></item></channel></rss>
