<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Freezer Temperature Alarm finished]]></title><description><![CDATA[<p dir="auto">I built a temp alarm for my big freezer after I lost about $1k worth of meat and other frozen foods due to a failed thermostat. If the thermostat fails again, I'll build an arduino based one with a screen to set temperatures and a relay to turn it on and off.</p>
<p dir="auto">I modified the example sketch for the temp sensor to support a buzzer and a mute button.  I did this because my ESP8266 gateway doesn't seem to be very reliable, and neither do notifications on the Vera.  At least this way, someone will hear it beeping if there's a problem.  The device uses a button with a pulldown resistor to ensure that the pin stays LOW when the button is not pressed.  When the temperature is &gt;= to the alarmTemp, alarmState goes to true which sounds the buzzer and sets the SLEEP_TIME down to 1 second.  If you press the button, it will mute the alarm.  The alarmState and mute automatically resets when the temp goes below alarmReset.  Note that the temps you set in the sketch will either be F or C depending on what your controller is set up for.  I'm using F, and usually keep my freezer at -20F.  So I set my alarmTemp to 10F and reset at 0F.  If you're using C, you'll want to change this appropriately.</p>
<p dir="auto">I'm always amazed that you can build stuff like this for like $5.</p>
<p dir="auto">Note that drilling holes in a modern freezer can be a risky endeavor, because the hot side of the compressor lines run beneath the sides and/or back of the freezer.  They aren't exposed anymore.  I used my Seek thermal camera to determine exactly where the lines were before I drilled and used a dry erase marker to mark them.</p>
<p dir="auto">Code below,</p>
<p dir="auto">Photos here - <a href="https://goo.gl/photos/4inkTh6GVhCEupLa8" rel="nofollow ugc">https://goo.gl/photos/4inkTh6GVhCEupLa8</a></p>
<pre><code>/**
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Example sketch showing how to send in DS1820B OneWire temperature readings back to the controller
 * http://www.mysensors.org/build/temp
#include &lt;SPI.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;DallasTemperature.h&gt;
#include &lt;OneWire.h&gt;
#define BUZZER 5
const int buttonPin = 7; // Pin where the mute button is connected
DallasTemperature sensors(&amp;oneWire); // Pass the oneWire reference to Dallas Temperature.
int numSensors=0;
int buttonState = 0;
bool alarmState = false;
bool muteAlarm = false;
float alarmTemp = 10; // Temperature where our alarm goes off. Use F if your gateway is imperial, C if metric
float alarmReset = 0; // Temperature where the alarm resets automatically
bool receivedConfig = false;
bool metric = true;
MyMessage msg(0,V_TEMP);
void before()
  sensors.begin();
  pinMode(BUZZER, OUTPUT);
  pinMode(buttonPin, INPUT);
void presentation() {
  sendSketchInfo("Temperature Sensor", "1.1");
  for (int i=0; i&lt;numSensors &amp;&amp; i&lt;MAX_ATTACHED_DS18B20; i++) {
     present(i, S_TEMP);
  if (alarmState == true &amp;&amp; muteAlarm == false) {
    digitalWrite(BUZZER, HIGH);
    delay(1000);
    digitalWrite(BUZZER,LOW);
    buttonState = digitalRead(buttonPin);
    // check if the pushbutton is pressed.
    // if it is, the buttonState is HIGH and we mute the alarm
    if (buttonState == HIGH) {
      muteAlarm = true;
  sleep(conversionTime);
    float temperature = static_cast&lt;float&gt;(static_cast&lt;int&gt;((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
    if (alarmState == false &amp;&amp; temperature &gt;= alarmTemp) {
      alarmState = true;
      SLEEP_TIME = 1000;  // Set our sleep from 30 seconds to 1 second to facilitate buzzer and intensive monitoring
    if (alarmState == true &amp;&amp; temperature &lt;= alarmReset) {
      alarmState = false;
      muteAlarm = false;
      SLEEP_TIME = 30000;
    #if COMPARE_TEMP == 1
    if (lastTemperature[i] != temperature &amp;&amp; temperature != -127.00 &amp;&amp; temperature != 85.00) {
    #else
    if (temperature != -127.00 &amp;&amp; temperature != 85.00) {
      send(msg.setSensor(i).set(temperature,1));
  sleep(SLEEP_TIME);
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/6930/freezer-temperature-alarm-finished</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 10:16:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6930.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 May 2017 03:57:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Freezer Temperature Alarm finished on Wed, 20 Sep 2017 19:36:52 GMT]]></title><description><![CDATA[<p dir="auto">Just wanted to throw this out there as I was revisiting this post today.  This could pretty easily be modified to have a digital display with buttons to adjust temperature, and a 5A solid state relay.  This would allow you to completely replace the mechanical thermostat.</p>
<p dir="auto">My thermostat replacement was nearly $40 after shipping, and it's rated at 5A so those 5A relays should work just fine.  This would be a cheaper replacement for the mechanical thermostat and would give you better temperature control.  Maybe better temp control isn't needed if you're just using for a freezer, but if you're a home brewer and trying to keep fermenters at a constant temperature, this would be very useful.  You could even add PID code to it.</p>
]]></description><link>https://forum.mysensors.org/post/76175</link><guid isPermaLink="true">https://forum.mysensors.org/post/76175</guid><dc:creator><![CDATA[signal15]]></dc:creator><pubDate>Wed, 20 Sep 2017 19:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to Freezer Temperature Alarm finished on Wed, 31 May 2017 09:52:15 GMT]]></title><description><![CDATA[<p dir="auto">Good. I already thought do the same because already  had a similar problem but mine was a bad contact  mains cable(where connects to fridge motor).</p>
<p dir="auto">the question is why all fridges don't come with an alarm from factory!?:angry:<br />
i didn't do mine because i had problems to pass sensor without drill holes on new  fridge</p>
]]></description><link>https://forum.mysensors.org/post/68098</link><guid isPermaLink="true">https://forum.mysensors.org/post/68098</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Wed, 31 May 2017 09:52:15 GMT</pubDate></item></channel></rss>
