<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gateway seems to reset?]]></title><description><![CDATA[<p dir="auto">Hi All</p>
<p dir="auto">Just joined forum, trying to get my first project running. Have limited programming skills!</p>
<p dir="auto">My setup:</p>
<p dir="auto">Ethernet Gateway (Uno, WIZNet 5100 Shield, NRF24L01)<br />
OpenHab 2.0<br />
Using latest libraries</p>
<p dir="auto">I have set the node to send temp value every 10 seconds for testing, seems from the gateway log that the gateway is resetting every time a messaged is received. I have setup the sensors in openHab, they all online and seem fine, but I'm not getting any temperature reading, display says -NaN</p>
<p dir="auto">Log from gateway below:<br />
NRF24L01</p>
<p dir="auto">0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGA--,VER=2.1.1<br />
0;255;3;0;9;TSM:INIT<br />
0;255;3;0;9;TSF:WUR:MS=0<br />
0;255;3;0;9;TSM:INIT:TSP OK<br />
0;255;3;0;9;TSM:INIT:GW MODE<br />
0;255;3;0;9;TSM:READY:ID=0,PAR=0,DIS=0<br />
0;255;3;0;9;MCO:REG:NOT NEEDED<br />
IP: 192.168.0.160<br />
0;255;3;0;9;MCO:BGN:STP<br />
0;255;3;0;9;MCO:BGN:INIT OK,TSP=1<br />
0;255;3;0;9;TSF:MSG:READ,24-24-255,s=255,c=3,t=7,pt=0,l=0,sg=0:<br />
0;255;3;0;9;TSF:MSG:BC<br />
0;255;3;0;9;TSF:MSG:FPAR REQ,ID=24<br />
0;255;3;0;9;TSF:CKU:OK,FCTRL<br />
0;255;3;0;9;TSF:MSG:GWL OK<br />
0;255;3;0;9;TSF:MSG:SEND,0-0-24-24,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0<br />
0;255;3;0;9;TSF:MSG:READ,24-24-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1<br />
0;255;3;0;9;TSF:MSG:PINGED,ID=24,HP=1<br />
0;255;3;0;9;!TSF:MSG:SEND,0-0-24-24,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=NACK:1<br />
0;255;3;0;9;TSF:MSG:READ,24-24-0,s=0,c=1,t=0,pt=1,l=1,sg=0:131<br />
0;255;3;0;9;MCO:BGN:INIT OK,TSP=1</p>
<p dir="auto">Would appreciate some assistance.</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mysensors.org/topic/6954/gateway-seems-to-reset</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 06:49:07 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6954.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Jun 2017 12:56:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gateway seems to reset? on Sun, 04 Jun 2017 17:04:57 GMT]]></title><description><![CDATA[<p dir="auto">Found the answer after searching most of the day!!</p>
<p dir="auto"><a href="https://forum.mysensors.org/topic/5716/solved-w5100-ethernet-gateway-with-nrf24-stable-mysensors-2-1-0-problem">https://forum.mysensors.org/topic/5716/solved-w5100-ethernet-gateway-with-nrf24-stable-mysensors-2-1-0-problem</a></p>
]]></description><link>https://forum.mysensors.org/post/68387</link><guid isPermaLink="true">https://forum.mysensors.org/post/68387</guid><dc:creator><![CDATA[sveness]]></dc:creator><pubDate>Sun, 04 Jun 2017 17:04:57 GMT</pubDate></item></channel></rss>
