<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working !]]></title><description><![CDATA[<p dir="auto">hi friends<br />
i have a raspberry gateway with domoticz controller.<br />
i use nrf+pa for gateway and one relay device (far away from gateway) and use usual nrf for some devices near same relay device (with nrf+pa) . this device is repeater for other devices. so all devices use a relay device with nrf+pa for connect to gateway.<br />
but i have problem . first all is ok and speed of run command is very much (Specially , relay device that is repeater) . but after days (without any change and move devices and controller) speed of run command is very low (Specially , relay device that is repeater) and other devices dont work well or failed in communicate .<br />
i use a ams1117 reg with a 100u cap for radio. and use a 5v 40A power supply for all devices (5 devices) and relay device (repeater).<br />
with a reset for controller or repeater and again work well but aftr days again...<br />
any body have same problem and have a idea or solution for this problem ?<br />
is that related to arduino or radio ? perhaps these is made in china.(but first time have good communicate !</p>
]]></description><link>https://forum.mysensors.org/topic/6964/communicate-is-good-for-first-time-for-relays-and-sensors-but-after-some-days-will-be-weak-and-some-time-stop-working</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 17:08:47 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/6964.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 06 Jun 2017 12:12:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Tue, 13 Jun 2017 12:36:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> yes . i change raspberrypi gateway to latest 2.2.0 beta</p>
]]></description><link>https://forum.mysensors.org/post/69165</link><guid isPermaLink="true">https://forum.mysensors.org/post/69165</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Tue, 13 Jun 2017 12:36:30 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Tue, 13 Jun 2017 12:35:31 GMT]]></title><description><![CDATA[<p dir="auto">are you using latest code from development branch ?</p>
]]></description><link>https://forum.mysensors.org/post/69164</link><guid isPermaLink="true">https://forum.mysensors.org/post/69164</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Tue, 13 Jun 2017 12:35:31 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Tue, 13 Jun 2017 12:15:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> hi<br />
again happen this problem . i test relay with repeater and test relay that connect to gateway directly. i see both have problem so i think this related to transmitter of controller and gateway. What do you think?</p>
]]></description><link>https://forum.mysensors.org/post/69162</link><guid isPermaLink="true">https://forum.mysensors.org/post/69162</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Tue, 13 Jun 2017 12:15:40 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Sat, 10 Jun 2017 20:23:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a><br />
for test first i change my regulator in controller and repeater,use LF33 instead of<br />
ams1117. but problem dont solve.now i put some relay near controller and connect directly to controller and i will test when there is problem and relay with repeater dont work, so relay that directly connect to controller have same problem or not !</p>
]]></description><link>https://forum.mysensors.org/post/68981</link><guid isPermaLink="true">https://forum.mysensors.org/post/68981</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Sat, 10 Jun 2017 20:23:39 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 20:50:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/68905">communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !</a>:</p>
<blockquote>
<p dir="auto">to test it out you would need at least 2 nodes connected to gateway and 2 to the repeater and test where the node to node communication between all nodes and see which is having problems. The best solution would be to use more than the 2 parts you currently have just to exclude both of them being faulty. I am really running out of options.</p>
</blockquote>
<p dir="auto">ok thank you . i will test this .</p>
]]></description><link>https://forum.mysensors.org/post/68906</link><guid isPermaLink="true">https://forum.mysensors.org/post/68906</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 20:50:02 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 20:48:20 GMT]]></title><description><![CDATA[<p dir="auto">to test it out you would need at least 2 nodes connected to gateway and 2 to the repeater and test where the node to node communication between all nodes and see which is having problems. The best solution would be to use more than the 2 parts you currently have just to exclude both of them being faulty. I am really running out of options.</p>
]]></description><link>https://forum.mysensors.org/post/68905</link><guid isPermaLink="true">https://forum.mysensors.org/post/68905</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 20:48:20 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 20:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a><br />
sorry i didn't get you. if swapping between repeater and gateway have problem so sensors can not send parameter to gateway. just problem is related to transfer from controller to relay node and repeater, that is right ?</p>
]]></description><link>https://forum.mysensors.org/post/68903</link><guid isPermaLink="true">https://forum.mysensors.org/post/68903</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 20:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 20:31:26 GMT]]></title><description><![CDATA[<p dir="auto">also swapping things between gateway and repeater and see if problem follows the part or not.</p>
]]></description><link>https://forum.mysensors.org/post/68902</link><guid isPermaLink="true">https://forum.mysensors.org/post/68902</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 20:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 16:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> said in <a href="/post/68881">communicate is good for first time for relays and sensors but after some days will be weak and some time stop working !</a>:</p>
<blockquote>
<p dir="auto">maybe the voltage regulator? try to swap that too. It is all a matter of trial and error.</p>
</blockquote>
<p dir="auto">thank you . i will change the regulator with a better regulator.and i test again . thank you</p>
]]></description><link>https://forum.mysensors.org/post/68886</link><guid isPermaLink="true">https://forum.mysensors.org/post/68886</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 16:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 16:29:17 GMT]]></title><description><![CDATA[<p dir="auto">maybe the voltage regulator? try to swap that too. It is all a matter of trial and error.</p>
]]></description><link>https://forum.mysensors.org/post/68881</link><guid isPermaLink="true">https://forum.mysensors.org/post/68881</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 16:29:17 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 16:21:34 GMT]]></title><description><![CDATA[<p dir="auto">after reboot raspberry again work well for a time .but again...</p>
]]></description><link>https://forum.mysensors.org/post/68880</link><guid isPermaLink="true">https://forum.mysensors.org/post/68880</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 16:21:34 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 15:08:16 GMT]]></title><description><![CDATA[<p dir="auto">this is strange for me, why sensors can send to gateway. but gateway can not send to relay node. is not related to power of radio ?<br />
both "transfer" and "receive" need to same power ? i use regulator ams1117 and 100u cap but perhaps this modules is fake !?</p>
]]></description><link>https://forum.mysensors.org/post/68869</link><guid isPermaLink="true">https://forum.mysensors.org/post/68869</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 15:08:16 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 14:59:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a><br />
i tested before. but test with similar radio from same Producer. other radios have support 5-6 meter distance for me. but this model support 15 <a href="http://meter.so" rel="nofollow ugc">meter.so</a> i am using this for controller and repeater. do you think this is related to this model of radio ?</p>
]]></description><link>https://forum.mysensors.org/post/68868</link><guid isPermaLink="true">https://forum.mysensors.org/post/68868</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 14:59:16 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 14:54:42 GMT]]></title><description><![CDATA[<p dir="auto">don't you have any other radio modules to try, right?</p>
]]></description><link>https://forum.mysensors.org/post/68867</link><guid isPermaLink="true">https://forum.mysensors.org/post/68867</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 14:54:42 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 14:52:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a><br />
again i have this error after 3 hours.<br />
i test repeater, in this state (error in communicate) i reset repeater. but problem is related to controller or gateway . because after reset , repeater can not connect to gateway, or very hard and bad connect.</p>
]]></description><link>https://forum.mysensors.org/post/68866</link><guid isPermaLink="true">https://forum.mysensors.org/post/68866</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 14:52:15 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 11:57:42 GMT]]></title><description><![CDATA[<p dir="auto">No, do one change at a time or you will not be able to pinpoint the problem</p>
]]></description><link>https://forum.mysensors.org/post/68849</link><guid isPermaLink="true">https://forum.mysensors.org/post/68849</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 11:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 11:25:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> i change this . do i need change pa_max in repeater node?i will test in next 3 days .thank you</p>
]]></description><link>https://forum.mysensors.org/post/68846</link><guid isPermaLink="true">https://forum.mysensors.org/post/68846</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 11:25:01 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 11:22:29 GMT]]></title><description><![CDATA[<p dir="auto">I just clone the repository, stop the mysgw service,  compile and run the install process if it doesn't start automatically on boot (maybe there is a better way to do it)</p>
]]></description><link>https://forum.mysensors.org/post/68845</link><guid isPermaLink="true">https://forum.mysensors.org/post/68845</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 11:22:29 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 11:08:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> sorry friend but how i can remove old version and install new update?</p>
]]></description><link>https://forum.mysensors.org/post/68842</link><guid isPermaLink="true">https://forum.mysensors.org/post/68842</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 11:08:44 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 10:53:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> thank you i will try update and change to pa_high</p>
]]></description><link>https://forum.mysensors.org/post/68840</link><guid isPermaLink="true">https://forum.mysensors.org/post/68840</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 10:53:38 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 10:43:40 GMT]]></title><description><![CDATA[<p dir="auto">try update to latest libray first thing, then try also power other power levels pa_low and pa_high (some modules don't work well with pa_max)</p>
]]></description><link>https://forum.mysensors.org/post/68837</link><guid isPermaLink="true">https://forum.mysensors.org/post/68837</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Fri, 09 Jun 2017 10:43:40 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Fri, 09 Jun 2017 08:41:34 GMT]]></title><description><![CDATA[<p dir="auto">i see communicate operation carefully for 3 days. because i can not use arduino serial monitor for 3 days (power on pc for 72 hours). so i see just T LED (transmit) on arduino in nodes (relay and repeater).<br />
as I said before i use a relay for repeater and some sensors and other relay connect to gateway from this repeater node(because radio in repeater is strong).<br />
so now i see, sensors is ok and send command from node to gateway with repeater.<br />
but when i send a command from controller to repeater or other relay node(that use same repeater) i have error, i see LED in repeater dont blink when i send command from controller .</p>
<p dir="auto">generally when node want send command to controller connection between repeater and gateway is ok but when controller want send command to node (repeater node and other relay nodes) i have error. the T led on arduino in repeater and other relay node dont blink ( not always. but most time, for example every 20 or 30 command one command is send but with a most delay for exapmle 5 or 10 second.) this is strange because first days work well !</p>
<p dir="auto">for controller i use a nrf+pa and use pa_max for all node and gateway.<br />
i use 5v pinout on raspberry for radio . and use a regulator adapter (ams1117) with 100u cap for radio.</p>
<p dir="auto">can you help me to found problem ? is this related to gateway (v2.2.0 for 5 month ago) or repeater (sketch) or chinese devices(hardware) ?</p>
<p dir="auto">thank you</p>
]]></description><link>https://forum.mysensors.org/post/68822</link><guid isPermaLink="true">https://forum.mysensors.org/post/68822</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Fri, 09 Jun 2017 08:41:34 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Tue, 06 Jun 2017 20:05:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> i see now. i am using v 2.2.0 for gateway . but 2.2.0 for 4-5 month ago. i need to update to last changes in v 2.2.0 ? ?</p>
]]></description><link>https://forum.mysensors.org/post/68596</link><guid isPermaLink="true">https://forum.mysensors.org/post/68596</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Tue, 06 Jun 2017 20:05:34 GMT</pubDate></item><item><title><![CDATA[Reply to communicate is good for first time for relays and sensors but after some days will be weak and  some time stop working ! on Tue, 06 Jun 2017 19:54:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> ok thank you. i will update this and come back tomorrow :rose:</p>
]]></description><link>https://forum.mysensors.org/post/68592</link><guid isPermaLink="true">https://forum.mysensors.org/post/68592</guid><dc:creator><![CDATA[Reza]]></dc:creator><pubDate>Tue, 06 Jun 2017 19:54:46 GMT</pubDate></item></channel></rss>
