<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[servo on arduino uno works , but not with nano]]></title><description><![CDATA[<p dir="auto">Hello all,</p>
<p dir="auto">I have an arduino uno with a servo succesfully installed, but the arduino was just for testing purposes.</p>
<p dir="auto">Ijust recieved my 2 nano's ( <a href="http://www.ebay.de/itm/291244948748?_trksid=p2060778.m2749.l2649&amp;ssPageName=STRK%3AMEBIDX%3AIT" rel="nofollow ugc">http://www.ebay.de/itm/291244948748?_trksid=p2060778.m2749.l2649&amp;ssPageName=STRK%3AMEBIDX%3AIT</a> )</p>
<p dir="auto">installed everything and uploaded the sketch , just to be sure I deleted the 2 devices I allready had ( the arduino node and the arduino win covering) .   I press start to include , nothing happends.</p>
<p dir="auto">Tried the second nano, exactly the same , tried to upload the sketch with  "#define CHILD_ID 11   // Id of the sensor child "  instead of 10 ( maybe an issue since the uno used 10 ).</p>
<p dir="auto">But still the same .</p>
<p dir="auto">Deleted the whole my sensnor plugin and tried all again...... no luck with the nano's.</p>
<p dir="auto">My last resort was to use again the uno , I press start to include , and yes , almost immediately the 2 devices were found.</p>
<p dir="auto">What can be wrong??!</p>
<p dir="auto">Attached 2 pictures of the connection , but I don't think I did that part wrong.</p>
<p dir="auto">Hopefully someone can help,</p>
<p dir="auto">Thanks,<br />
Cor<br />
<a href="/uploads/upload-5f30344c-fbfd-4d48-abaa-7d38a8f06cfd.jpg">20141209_014658.jpg</a> <img src="/uploads/upload-35abbfe0-8ccd-45ca-93e5-fae2bd72398c.jpg" alt="20141209_014645.jpg" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.mysensors.org/topic/698/servo-on-arduino-uno-works-but-not-with-nano</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 05:08:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/698.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Dec 2014 00:45:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to servo on arduino uno works , but not with nano on Tue, 09 Dec 2014 13:09:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corvl" aria-label="Profile: Corvl">@<bdi>Corvl</bdi></a> your wellcome ;)</p>
]]></description><link>https://forum.mysensors.org/post/7575</link><guid isPermaLink="true">https://forum.mysensors.org/post/7575</guid><dc:creator><![CDATA[korttoma]]></dc:creator><pubDate>Tue, 09 Dec 2014 13:09:09 GMT</pubDate></item><item><title><![CDATA[Reply to servo on arduino uno works , but not with nano on Tue, 09 Dec 2014 11:03:21 GMT]]></title><description><![CDATA[<p dir="auto">On MCV forum someone came with the solution. it seems that this nano I have does not have enough output on the 3.3v pin for the shield with external antenna I wanted to use.</p>
<p dir="auto">It is working with the shield without external antenna.   Checking now if it is possible to have the full output with external antenna on 5v with a 3.3v regulator in between.</p>
Cor</p>
]]></description><link>https://forum.mysensors.org/post/7573</link><guid isPermaLink="true">https://forum.mysensors.org/post/7573</guid><dc:creator><![CDATA[Corvl]]></dc:creator><pubDate>Tue, 09 Dec 2014 11:03:21 GMT</pubDate></item><item><title><![CDATA[Reply to servo on arduino uno works , but not with nano on Tue, 09 Dec 2014 00:55:34 GMT]]></title><description><![CDATA[<p dir="auto">Thanks , I will use a seperate power source for the servo , as soon as I can include the device on my vera.</p>
<p dir="auto">What do you mean , clear eprom ? , I used my UNO get a bootloader in the nano : <a href="http://www.instructables.com/id/How-To-Burn-a-Bootloader-to-Clone-Arduino-Nano-30/step3/Simple-few-steps/" rel="nofollow ugc">http://www.instructables.com/id/How-To-Burn-a-Bootloader-to-Clone-Arduino-Nano-30/step3/Simple-few-steps/</a></p>
<p dir="auto">That's not good enough?</p>
<p dir="auto">Thanks for your help ,<br />
Cor</p>
]]></description><link>https://forum.mysensors.org/post/7553</link><guid isPermaLink="true">https://forum.mysensors.org/post/7553</guid><dc:creator><![CDATA[Corvl]]></dc:creator><pubDate>Tue, 09 Dec 2014 00:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to servo on arduino uno works , but not with nano on Tue, 09 Dec 2014 00:47:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/corvl" aria-label="Profile: Corvl">@<bdi>Corvl</bdi></a> be careful i lost 4 nanos with servo :+1:<br />
dont give power from nano to servo</p>
<ul>
<li>try clear eeprom before uploding a sketch</li>
</ul>
]]></description><link>https://forum.mysensors.org/post/7552</link><guid isPermaLink="true">https://forum.mysensors.org/post/7552</guid><dc:creator><![CDATA[C.r.a.z.y.]]></dc:creator><pubDate>Tue, 09 Dec 2014 00:47:45 GMT</pubDate></item></channel></rss>
