<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[Solved] Sensebender GW: TSP FAIL]]></title><description><![CDATA[<p dir="auto">Hi Guys,</p>
<p dir="auto">recently i got myself a sensebender GW to replace my current ESP one.</p>
<p dir="auto">ive solderd the connectors on the board and connected everything. but i cant get it to work...</p>
<p dir="auto">i've tried everything, im getting the following in the debug log:</p>
<pre><code>0;255;3;0;9;MCO:BGN:INIT GW,CP=RNNGS--,VER=2.1.1
0;255;3;0;9;TSF:LRT:OK
0;255;3;0;9;TSM:INIT
0;255;3;0;9;TSF:WUR:MS=0
0;255;3;0;9;!TSM:INIT:TSP FAIL
0;255;3;0;9;TSM:FAIL:CNT=1
0;255;3;0;9;TSM:FAIL:PDT
</code></pre>
<p dir="auto">This seems errors with the communication to the RF module. i already tried several module to exclude that. (also from 3 different batches, including one with an external antenna)</p>
<p dir="auto">just to be sure i resolderd all the connections going to the RF module, no luck.</p>
<p dir="auto">As described in the FAQ i also measured the power. i do see that it is a bit low. i'm getting 2.9V on the 3.3 measuring points on the board.<br />
Might this be the issue?<br />
EDIT: i just measured again directly on the RF module. and the power is 3.33V so that is perfect.<br />
still not sure how i can find the issue...</p>
<p dir="auto">could it be that a component on the board is broken? if so could you guys help me with identifying which component it is?</p>
<p dir="auto">PS. i'm using the serialGW sketch with arduino zero as target board.</p>
]]></description><link>https://forum.mysensors.org/topic/7001/solved-sensebender-gw-tsp-fail</link><generator>RSS for Node</generator><lastBuildDate>Sun, 08 Nov 2026 08:26:00 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7001.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 11 Jun 2017 14:44:45 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [Solved] Sensebender GW: TSP FAIL on Sun, 11 Jun 2017 19:17:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> said in <a href="/post/69019">Sensebender GW: TSP FAIL</a>:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nick-van-alst" aria-label="Profile: nick-van-alst">@<bdi>nick-van-alst</bdi></a> You need to install the MySensors Board definitions, please follow the instructions <a href="https://www.mysensors.org/hardware/sensebender-gateway" rel="nofollow ugc">here</a> | section "Other configurations"</p>
</blockquote>
<p dir="auto">you are a life safer! i didn't realize i didn't have that one yet!</p>
]]></description><link>https://forum.mysensors.org/post/69023</link><guid isPermaLink="true">https://forum.mysensors.org/post/69023</guid><dc:creator><![CDATA[nick van alst]]></dc:creator><pubDate>Sun, 11 Jun 2017 19:17:43 GMT</pubDate></item><item><title><![CDATA[Reply to [Solved] Sensebender GW: TSP FAIL on Sun, 11 Jun 2017 17:04:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nick-van-alst" aria-label="Profile: nick-van-alst">@<bdi>nick-van-alst</bdi></a> You need to install the MySensors Board definitions, please follow the instructions <a href="https://www.mysensors.org/hardware/sensebender-gateway" rel="nofollow ugc">here</a> | section "Other configurations"</p>
]]></description><link>https://forum.mysensors.org/post/69019</link><guid isPermaLink="true">https://forum.mysensors.org/post/69019</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 11 Jun 2017 17:04:39 GMT</pubDate></item></channel></rss>
