<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] BME280 power consumtion]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
I'm using this library:<br />
<a href="https://github.com/finitespace/BME280" rel="nofollow ugc">https://github.com/finitespace/BME280</a><br />
to comunicate with this module:<br />
<a href="http://www.ebay.com.au/itm/I2C-SPI-Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-/191736124959" rel="nofollow ugc">http://www.ebay.com.au/itm/I2C-SPI-Breakout-Temperature-Humidity-Barometric-Pressure-BME280-Digital-Sensor-/191736124959</a></p>
<p dir="auto">in my sketch i create the driver with this statement:<br />
BME280I2C bme;</p>
<p dir="auto">which acording to example sketch BME280_Modes.ino should result in 0.16 μA power consumtion but my bme280 module consumes almost 0.5mA in this mode ...</p>
<p dir="auto">has anyone any expirience with bme280 and know how much power it realy should consume ?</p>
]]></description><link>https://forum.mysensors.org/topic/7046/solved-bme280-power-consumtion</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 08:16:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7046.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Jun 2017 11:51:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Sat, 10 Nov 2018 19:00:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickecarlsson" aria-label="Profile: mickecarlsson">@<bdi>mickecarlsson</bdi></a> I believe <strong>BME280.writeMode(smSleep);</strong>  is not necessary.<br />
Forced mode must be used.  I think after taking the measurement the sensor goes back to sleep.</p>
<pre><code>BME280.writeMode(smForced);
</code></pre>
]]></description><link>https://forum.mysensors.org/post/94957</link><guid isPermaLink="true">https://forum.mysensors.org/post/94957</guid><dc:creator><![CDATA[alexsh1]]></dc:creator><pubDate>Sat, 10 Nov 2018 19:00:43 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Wed, 13 Dec 2017 18:03:37 GMT]]></title><description><![CDATA[<p dir="auto">I am using this:</p>
<pre><code>// Bosch BME280 Embedded Adventures MOD-1022 weather multi-sensor Arduino code,
// written originally by Embedded Adventures.
// https://github.com/embeddedadventures/BME280
#include &lt;BME280_MOD-1022.h&gt;```</code></pre>
]]></description><link>https://forum.mysensors.org/post/81818</link><guid isPermaLink="true">https://forum.mysensors.org/post/81818</guid><dc:creator><![CDATA[mickecarlsson]]></dc:creator><pubDate>Wed, 13 Dec 2017 18:03:37 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Wed, 13 Dec 2017 13:20:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mickecarlsson" aria-label="Profile: mickecarlsson">@<bdi>mickecarlsson</bdi></a> What BME280 library are you using?</p>
]]></description><link>https://forum.mysensors.org/post/81804</link><guid isPermaLink="true">https://forum.mysensors.org/post/81804</guid><dc:creator><![CDATA[peerv]]></dc:creator><pubDate>Wed, 13 Dec 2017 13:20:25 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Thu, 07 Dec 2017 20:48:35 GMT]]></title><description><![CDATA[<p dir="auto">Just add:</p>
<pre><code>BME280.writeMode(smSleep);                 // go to sleep, save battery
</code></pre>
<p dir="auto">After your have read the bme280, just before you call sleep().</p>
]]></description><link>https://forum.mysensors.org/post/81430</link><guid isPermaLink="true">https://forum.mysensors.org/post/81430</guid><dc:creator><![CDATA[mickecarlsson]]></dc:creator><pubDate>Thu, 07 Dec 2017 20:48:35 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Tue, 28 Nov 2017 20:31:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rozpruwacz" aria-label="Profile: rozpruwacz">@<bdi>rozpruwacz</bdi></a> Thanks, very impressive solution!</p>
]]></description><link>https://forum.mysensors.org/post/80541</link><guid isPermaLink="true">https://forum.mysensors.org/post/80541</guid><dc:creator><![CDATA[peerv]]></dc:creator><pubDate>Tue, 28 Nov 2017 20:31:35 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Mon, 27 Nov 2017 03:30:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rozpruwacz" aria-label="Profile: rozpruwacz">@<bdi>rozpruwacz</bdi></a> The big downside to using forced instead of normal is that you can't use the IIR filters, since they require relatively recent previous readings to work.</p>
]]></description><link>https://forum.mysensors.org/post/80484</link><guid isPermaLink="true">https://forum.mysensors.org/post/80484</guid><dc:creator><![CDATA[Craig Thom]]></dc:creator><pubDate>Mon, 27 Nov 2017 03:30:37 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Sun, 26 Nov 2017 13:00:50 GMT]]></title><description><![CDATA[<p dir="auto">You can checkout my code from github: <a href="https://github.com/mczerski/MyMultiSensorBME280" rel="nofollow ugc">https://github.com/mczerski/MyMultiSensorBME280</a>. If you want to build this project remember pull also git submodule (git submodule init; git submodule update)</p>
]]></description><link>https://forum.mysensors.org/post/80444</link><guid isPermaLink="true">https://forum.mysensors.org/post/80444</guid><dc:creator><![CDATA[rozpruwacz]]></dc:creator><pubDate>Sun, 26 Nov 2017 13:00:50 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Sat, 25 Nov 2017 22:16:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rozpruwacz" aria-label="Profile: rozpruwacz">@<bdi>rozpruwacz</bdi></a><br />
Hi,<br />
Could you please share with me how you managed to get the power consumption of the BME280 down.<br />
Can this also be done with the Adafruit library?</p>
]]></description><link>https://forum.mysensors.org/post/80278</link><guid isPermaLink="true">https://forum.mysensors.org/post/80278</guid><dc:creator><![CDATA[peerv]]></dc:creator><pubDate>Sat, 25 Nov 2017 22:16:41 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Thu, 22 Jun 2017 18:51:12 GMT]]></title><description><![CDATA[<p dir="auto">ok, i think the problem is solved, the example i was looking at is just wrong, the default mode is normal not forced so default configuration of the driver put in nornal mode not forced, changing the constructor values solves the problem.</p>
]]></description><link>https://forum.mysensors.org/post/69698</link><guid isPermaLink="true">https://forum.mysensors.org/post/69698</guid><dc:creator><![CDATA[rozpruwacz]]></dc:creator><pubDate>Thu, 22 Jun 2017 18:51:12 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] BME280 power consumtion on Thu, 22 Jun 2017 18:49:30 GMT]]></title><description><![CDATA[<p dir="auto">Maybe you could try the adafruit library and see if it works better</p>
]]></description><link>https://forum.mysensors.org/post/69697</link><guid isPermaLink="true">https://forum.mysensors.org/post/69697</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Thu, 22 Jun 2017 18:49:30 GMT</pubDate></item></channel></rss>
