<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] W5100 Gateway code modification]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I'm looking for an anwser but cannot find it anywhere.<br />
Is it possible to change pin from A0 to different one (for example A3) for NRF24l01 in a gateway ?<br />
If yes, where can I defined it ? (it's not defined on my sketches&gt;</p>
<p dir="auto">Thank you in advance</p>
]]></description><link>https://forum.mysensors.org/topic/7055/solved-w5100-gateway-code-modification</link><generator>RSS for Node</generator><lastBuildDate>Wed, 18 Nov 2026 05:30:27 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7055.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Jun 2017 14:59:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] W5100 Gateway code modification on Sat, 24 Jun 2017 16:19:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> Thank you! It works.<br />
I was searching for "A0" not the GPIO number (newbie here)</p>
<p dir="auto">Thank you once again.</p>
]]></description><link>https://forum.mysensors.org/post/69763</link><guid isPermaLink="true">https://forum.mysensors.org/post/69763</guid><dc:creator><![CDATA[fejt]]></dc:creator><pubDate>Sat, 24 Jun 2017 16:19:26 GMT</pubDate></item><item><title><![CDATA[Reply to [SOLVED] W5100 Gateway code modification on Sat, 24 Jun 2017 16:09:56 GMT]]></title><description><![CDATA[<p dir="auto">Welcome to the MySensors community <a class="plugin-mentions-user plugin-mentions-a" href="/user/fejt" aria-label="Profile: fejt">@<bdi>fejt</bdi></a> !</p>
<p dir="auto">The pin is defined by</p>
<pre><code>#define MY_SOFT_SPI_SCK_PIN 14
</code></pre>
<p dir="auto">Look at a pinout diagram of your Arduino and select a different pin.</p>
<p dir="auto">More detailed information: <a href="https://www.mysensors.org/build/ethernet_gateway" rel="nofollow ugc">https://www.mysensors.org/build/ethernet_gateway</a></p>
]]></description><link>https://forum.mysensors.org/post/69761</link><guid isPermaLink="true">https://forum.mysensors.org/post/69761</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Sat, 24 Jun 2017 16:09:56 GMT</pubDate></item></channel></rss>
