<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HomeAssistant + SenseBender MQTT GW + MySensor Node - almost there I think]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have been running OpenHab, Mosquitto (MQTT broker) and some home brew gateways and RF nodes.  I have seen the light and clearly the MySensors platform and Home Assistant as my controller are the way to go.  I've had a good go at getting it to work and I feel I'm close, but now I need some help.</p>
<p dir="auto">I have a Moteino with RFM69W configured based on the sample code here <a href="https://home-assistant.io/components/mysensors/" rel="nofollow ugc">https://home-assistant.io/components/mysensors/</a> and have put a switch (fixed not momentary type) on pin 8.</p>
<p dir="auto">I bought a SenseBender GW board and soldered on an RFM69 and plugged in a W5100 Eth module.  I used a combination of running the <strong>Examples &gt; MySensors &gt; SensebenderGatewaySerial</strong> example and the <strong>Examples &gt; MySensors &gt; GatewayW5100</strong> example to creat my MQTT GW code.</p>
<p dir="auto">I used the sample Home Assistant configuration.yaml code from here <a href="https://home-assistant.io/components/mysensors/" rel="nofollow ugc">https://home-assistant.io/components/mysensors/</a> but customised to just use the "- device: mqtt" section.<br />
I also added an mqtt broker section to my configuration.yaml<br />
My Home Assistant is running on an RPi3.</p>
<p dir="auto"><strong>So whats the problem?</strong><br />
Well, when I press the button on the end node, it successfully transmits what looks like the right info to the gateway and the gateway in turn shoots the right MQTT packet over to the MQTT Broker (mosquitto) and then Home Assistant seems to receive it.<br />
BUT unfortunately Home Assistant then instantly generates  an error</p>
<pre><code>2017-06-29 18:06:56 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on GWPUB/55/11/1/0/2: 0
2017-06-29 18:06:56 DEBUG (Thread-13) [homeassistant.components.mysensors] Update: node 55, child 11 sub_type 2
2017-06-29 18:06:56 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
Traceback (most recent call last):
  File "/usr/lib/python3.4/asyncio/tasks.py", line 237, in _step
    result = next(coro)
  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/helpers/entity.py", line 204, in async_update_ha_state
    "No entity id specified for entity {}".format(self.name))
homeassistant.exceptions.NoEntitySpecifiedError: No entity id specified for entity Switch Sensor 55 11
</code></pre>
<p dir="auto">I will raise this in the Home Assistant forums as well, but I would like to know if anyone can assist here with checking the my MySensors stuff. Or provide some examples of known working configs?<br />
Thanks,<br />
Paul</p>
<p dir="auto"><strong>Here is my Node code</strong></p>
<pre><code>// Enable debug prints to serial monitor
//#define MY_RADIO_NRF24
#define MY_RADIO_RFM69
#define MY_RFM69HW false
#define MY_RFM69_NETWORKID 101
#define MY_NODE_ID 55
#include &lt;MySensors.h&gt;
#include &lt;Bounce2.h&gt;
#define CHILD_ID_SW 11
#define CHILD_ID_REL 22
#define SW_PIN 8
#define REL_PIN 7
#define SW_ON 1
#define SW_OFF 0
MyMessage msgSW(CHILD_ID_SW, V_STATUS); // 16
//MyMessage msgREL(CHILD_ID_REL, V_LIGHT); //2
byte StateREL=0;
Bounce debouncer = Bounce();
int oldValueSW=-1;
int valueSW=0;
const unsigned long tUpdate=60000; //update interval if input do not change
unsigned long t0;
bool state = false;
bool initialValueSent = false;
void presentation() {
  sendSketchInfo("Node_Test", "0.1");
  present(CHILD_ID_SW, S_BINARY);
  //present(CHILD_ID_REL, S_LIGHT);
  pinMode(SW_PIN,INPUT);
  digitalWrite(SW_PIN,HIGH);
  debouncer.attach(SW_PIN);
  debouncer.interval(5);
  pinMode(REL_PIN, OUTPUT);
  digitalWrite(REL_PIN, StateREL);
  // get state of SW at powerup.
  debouncer.update();
  state = debouncer.read();
  // If this is the first time loop has run, send initial value to Home Assistant.
  if (initialValueSent == false)
    send(msgSW.set(state?SW_ON:SW_OFF), true); //and asking for an ACK
    initialValueSent = true;
    t0=millis();  // reset the interval timer so we don't send update until period expires.
  if (debouncer.update())
    if (debouncer.read()!= state)
      state = !state;
      // Send new state and request ack back
  if ((millis()-t0) &gt; tUpdate)
void receive(const MyMessage &amp;message) {
  if (message.isAck()) {
     Serial.println("Received an ack from gateway");
  else  {
     Serial.println("Received something but not an ack, from gateway");
</code></pre>
<p dir="auto"><strong>Here is what it's serial monitor looks like</strong></p>
<pre><code>0 MCO:BGN:INIT NODE,CP=RRNNA--,VER=2.1.1
3 TSM:INIT
4 TSF:WUR:MS=0
6 TSM:INIT:TSP OK
8 TSM:INIT:STATID=55
10 TSF:SID:OK,ID=55
11 TSM:FPAR
142 TSF:MSG:SEND,55-55-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
621 TSF:MSG:READ,0-0-55,s=255,c=3,t=8,pt=1,l=1,sg=0:0
626 TSF:MSG:FPAR OK,ID=0,D=1
2149 TSM:FPAR:OK
2150 TSM:ID
2151 TSM:ID:OK
2153 TSM:UPL
2160 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
2190 TSF:MSG:READ,0-0-55,s=255,c=3,t=25,pt=1,l=1,sg=0:1
2195 TSF:MSG:PONG RECV,HP=1
2198 TSM:UPL:OK
2199 TSM:READY:ID=55,PAR=0,DIS=1
2208 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
2225 TSF:MSG:READ,0-0-55,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
2280 TSF:MSG:SEND,55-55-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
2336 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
2403 TSF:MSG:READ,0-0-55,s=255,c=3,t=6,pt=0,l=1,sg=0:M
2459 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=11,pt=0,l=9,sg=0,ft=0,st=OK:Node_Test
2516 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:0.1
2572 TSF:MSG:SEND,55-55-0-0,s=11,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
2578 MCO:REG:REQ
2630 TSF:MSG:SEND,55-55-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
2651 TSF:MSG:READ,0-0-55,s=255,c=3,t=27,pt=1,l=1,sg=0:1
2656 MCO:PIM:NODE REG=1
2658 MCO:BGN:STP
2660 MCO:BGN:INIT OK,TSP=1
2669 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
2695 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:0
2700 TSF:MSG:ACK
13868 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:1
13892 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:1
13897 TSF:MSG:ACK
18896 TSF:MSG:SEND,55-55-0-0,s=11,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=OK:0
18922 TSF:MSG:READ,0-0-55,s=11,c=1,t=2,pt=2,l=2,sg=0:0
18927 TSF:MSG:ACK
</code></pre>
<p dir="auto"><strong>Here is my SenseBender MQTT Eth w5100 Gateway code</strong></p>
<pre><code>/**
* Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
* The ArduinoGateway prints data received from sensors on the serial link.
* The gateway accepts input on seral which will be sent out on radio network.
* This GW code is designed for Sensebender GateWay / (Arduino Zero variant)
* Wire connections (OPTIONAL):
* - Inclusion button should be connected to SW2
* LEDs on board (default assignments):
* - Orange: USB RX/TX - Blink when receiving / transmitting on USB CDC device
* - Yellow: RX  - Blink fast on radio message recieved. In inclusion mode will blink fast only on presentation recieved
* - Green : TX  - Blink fast on radio message transmitted. In inclusion mode will blink slowly
* - Red   : ERR - Fast blink on error during transmission error or recieve crc error
* - Blue  : free - (use with LED_BLUE macro)
#define SKETCH_VERSION "0.2"
#define MY_DEBUG_VERBOSE
//#define MY_RF24_PA_LEVEL RF24_PA_HIGH
// Enable serial gateway
//#define MY_GATEWAY_SERIAL
// Define a lower baud rate for Arduino's running on 8 MHz (Arduino Pro Mini 3.3V &amp; SenseBender)
#if F_CPU == 8000000L
#define MY_BAUD_RATE 38400
//#define MY_GATEWAY_W5100
// Enable gateway ethernet module type with MQTT
#define MY_MQTT_PUBLISH_TOPIC_PREFIX "GWPUB"
#define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "GWSUB"
// Set MQTT client id
#define MY_MQTT_CLIENT_ID "mysensors-gw"    // this is used when this gw connects to the MQTT Broker.
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 200, 251   // HOMER my Raspi running Home Assistant and Mosquitto
#define MY_CONTROLLER_IP_ADDRESS 192, 168, 200, 241   // HABPI my Raspi running OpenHAB and Mosquitto
#define MY_PORT 1883
//#define MY_MQTT_USER "pimqtt"           // as generated when I installed Mosquitto on my Home Assistant RasPi.
//#define MY_MQTT_PASSWORD "lowsecpass"   // as generated when I installed Mosquitto on my Home Assistant RasPi.
//#define MY_W5100_SPI_EN 4
// radio on the same spi bus.
#if !defined(MY_W5100_SPI_EN) &amp;&amp; !defined(ARDUINO_ARCH_SAMD)
#define MY_SOFTSPI
#ifndef MY_RF24_CE_PIN
#define MY_RF24_CE_PIN 5
#ifndef MY_RF24_CS_PIN
#define MY_RF24_CS_PIN 6
// Enable to UDP
//#define MY_USE_UDP
#define MY_IP_ADDRESS 192,168,200,230
//#define MY_PORT 5003    // ONLY for MY_GATEWAY_W5100 mode.
#define MY_IP_GATEWAY_ADDRESS 192,168,200,254
// Controller ip address. Enables client mode (default is "server" mode). // ONLY for MY_GATEWAY_W5100 mode.
//#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
#define MY_MAC_ADDRESS 0xDE, 0xAD, 0xBE, 0xEF, 0x01, 0x01
// Enable inclusion mode
// Set blinking period
// Inverses the behavior of leds on the Gateway
#define MY_WITH_LEDS_BLINKING_INVERSE
// Flash leds on rx/tx/err
#if defined(MY_USE_UDP)
#include &lt;EthernetUdp.h&gt;
#include &lt;Ethernet.h&gt;
#include &lt;SD.h&gt;
#include &lt;drivers/ATSHA204/ATSHA204.cpp&gt;
Sd2Card card;
#define EEPROM_VERIFICATION_ADDRESS 0x01
static uint8_t num_of_leds = 5;
static uint8_t leds[] = {LED_BLUE, LED_RED, LED_GREEN, LED_YELLOW, LED_ORANGE};
 //if (Serial) {
 //      Serial.println(F("In Loop() "));
void preHwInit()
	pinMode(MY_SWC1, INPUT_PULLUP);
	pinMode(MY_SWC2, INPUT_PULLUP);
	if (digitalRead(MY_SWC1) &amp;&amp; digitalRead(MY_SWC2)) {
		return;
	uint8_t tests = 0;
	for (int i=0; i&lt; num_of_leds; i++) {
		pinMode(leds[i], OUTPUT);
	uint8_t led_state = 0;
	if (digitalRead(MY_SWC1)) {
		while (!Serial) {
			digitalWrite(LED_BLUE, led_state);
			led_state ^= 0x01;
			delay(500);
		} // Wait for USB to be connected, before spewing out data.
	digitalWrite(LED_BLUE, LOW);
	if (Serial) {
		Serial.println("Sensebender GateWay test routine");
		Serial.print("Mysensors core version : ");
		Serial.println(MYSENSORS_LIBRARY_VERSION);
		Serial.print("GateWay sketch version : ");
		Serial.println(SKETCH_VERSION);
		Serial.println("----------------------------------");
		Serial.println();
	if (testSha204()) {
		digitalWrite(LED_GREEN, HIGH);
		tests++;
	if (testSDCard()) {
		digitalWrite(LED_YELLOW, HIGH);
		tests++;
	if (testEEProm()) {
		digitalWrite(LED_ORANGE, HIGH);
		tests++;
	if (testAnalog()) {
		digitalWrite(LED_BLUE, HIGH);
		tests++;
	if (tests == 4) {
		while(1) {
			for (int i=0; i&lt;num_of_leds; i++) {
				digitalWrite(leds[i], HIGH);
				delay(200);
				digitalWrite(leds[i], LOW);
	} else {
		while (1) {
			digitalWrite(LED_RED, HIGH);
			delay(200);
			digitalWrite(LED_RED, LOW);
			delay(200);
bool testSha204()
	uint8_t rx_buffer[SHA204_RSP_SIZE_MAX];
	uint8_t ret_code;
	if (Serial) {
		Serial.print("- &gt; SHA204 ");
	atsha204_init(MY_SIGNING_ATSHA204_PIN);
	ret_code = atsha204_wakeup(rx_buffer);
	if (ret_code == SHA204_SUCCESS) {
		ret_code = atsha204_getSerialNumber(rx_buffer);
		if (ret_code != SHA204_SUCCESS) {
			if (Serial) {
				Serial.println(F("Failed to obtain device serial number. Response: "));
			Serial.println(ret_code, HEX);
		} else {
			if (Serial) {
				Serial.print(F("Ok (serial : "));
				for (int i=0; i&lt;9; i++) {
					if (rx_buffer[i] &lt; 0x10) {
						Serial.print('0'); // Because Serial.print does not 0-pad HEX
					Serial.print(rx_buffer[i], HEX);
				Serial.println(")");
			return true;
	} else {
		if (Serial) {
			Serial.println(F("Failed to wakeup SHA204"));
	return false;
bool testSDCard()
	if (Serial) {
		Serial.print("- &gt; SD CARD ");
	if (!card.init(SPI_HALF_SPEED, MY_SDCARD_CS)) {
		if (Serial) {
			Serial.println("SD CARD did not initialize!");
	} else {
		if (Serial) {
			Serial.print("SD Card initialized correct! - ");
			Serial.print("type detected : ");
			switch(card.type()) {
			case SD_CARD_TYPE_SD1:
				Serial.println("SD1");
				break;
			case SD_CARD_TYPE_SD2:
				Serial.println("SD2");
				break;
			case SD_CARD_TYPE_SDHC:
				Serial.println("SDHC");
				break;
			default:
				Serial.println("Unknown");
		return true;
	return false;
bool testEEProm()
	uint8_t eeprom_d1, eeprom_d2;
	SerialUSB.print(" -&gt; EEPROM ");
	Wire.begin();
	eeprom_d1 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
	delay(500);
	eeprom_d1 = ~eeprom_d1; // invert the bits
	i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, eeprom_d1);
	delay(500);
	eeprom_d2 = i2c_eeprom_read_byte(EEPROM_VERIFICATION_ADDRESS);
	if (eeprom_d1 == eeprom_d2) {
		SerialUSB.println("PASSED");
		i2c_eeprom_write_byte(EEPROM_VERIFICATION_ADDRESS, ~eeprom_d1);
		return true;
	SerialUSB.println("FAILED!");
	return false;
bool testAnalog()
	int bat_detect = analogRead(MY_BAT_DETECT);
	Serial.print("-&gt; analog : ");
	Serial.print(bat_detect);
	if (bat_detect &lt; 400 || bat_detect &gt; 650) {
		Serial.println(" Failed");
		return false;
	Serial.println(" Passed");
	return true;
</code></pre>
<p dir="auto"><strong>And here are what I think are the relevant sections of my Home Assistant configuration.yaml</strong></p>
<pre><code>logger:
  default: info   #ignore any messages below this level. PJ - I often use 'info' here.
  logs:
    homeassistant.components.mqtt: debug
    homeassistant.components.mysensors: debug
mqtt:
  broker: habpi     # my mosquitto based broker on my habpi box.
  port: 1883
  client_id: homer_home_assist
  keepalive: 60
  birth_message:                #this MQTT message gets sent every time Home Assistant starts up or is restarted.
    topic: 'home/hass/status'
    payload: 'online'
  will_message:
    payload: 'offline'
mysensors:
  gateways:
    - device: mqtt
      persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
      topic_in_prefix: 'GWPUB'
      topic_out_prefix: 'GWSUB'
  optimistic: false
  persistence: true
  retain: true
  version: 2.0
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/7079/homeassistant-sensebender-mqtt-gw-mysensor-node-almost-there-i-think</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:08:47 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7079.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 29 Jun 2017 08:14:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HomeAssistant + SenseBender MQTT GW + MySensor Node - almost there I think on Fri, 30 Jun 2017 16:19:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mr6510" aria-label="Profile: Mr6510">@<bdi>Mr6510</bdi></a></p>
<p dir="auto">Hi! This is a known issue on the home assistant side. I have a fix in progress but it's not ready yet.</p>
<p dir="auto">You should be able to work around it by not sending values too frequently until the entity is added to home assistant, if you only have one value type.</p>
<p dir="auto"><a href="https://github.com/home-assistant/home-assistant/issues/8243" rel="nofollow ugc">https://github.com/home-assistant/home-assistant/issues/8243</a></p>
]]></description><link>https://forum.mysensors.org/post/70149</link><guid isPermaLink="true">https://forum.mysensors.org/post/70149</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Fri, 30 Jun 2017 16:19:47 GMT</pubDate></item></channel></rss>
