<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Define Mysensor (rgbw) Things in openhab2]]></title><description><![CDATA[<p dir="auto">I am currently trying to get my domoticz based network ported to openhab 2. I have installed the binding (2.2) and got openhab to connect to the serial gateway. I am struggling though to get it to use my existing nodes.</p>
<p dir="auto">I mainly have several RGBW nodes I want to use. I am trying to configure this via the config files, not the paper ui.</p>
<p dir="auto">Here is my .things file:</p>
<pre><code>Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200 ] {
    /** define things connected to that bridge here */
  	rgbwLight LichtFenster [nodeID=5, childId=1]
  	rgbwLight LichtSchrank [nodeID=6, childId=1]
  	rgbwLight LichtWand [nodeID=7, childId=1]
</code></pre>
<p dir="auto">The ids are correct but they are shown as uninitialzed in the paper ui. Why is that?<br />
When restarting one node it showed up in the paperui but as</p>
<pre><code>mysensors:rgbwLight:gateway:rgbwlight_5_1
</code></pre>
<p dir="auto">Also is this the right way to controll the lights:<br />
.items:</p>
<pre><code>Color LichtSchrank "Licht Schrank" &lt;slider&gt; ["Lighting"] { channel="mysensors:rgbwLight:gateway:LichtSchrank:rgbw" }
Color LichtFenster "Licht Fenster" &lt;slider&gt; ["Lighting"] { channel="mysensors:rgbwLight:gateway:rgbwlight_5_1:rgbw" }
</code></pre>
<p dir="auto">.sitemap</p>
<pre><code>sitemap lights label="Wohnzimmer" {
	Frame label="Licht" {
		Colorpicker item=LichtSchrank
		Switch item=LichtSchrank
		Colorpicker item=LichtFenster
		Switch item=LichtFenster
</code></pre>
<p dir="auto">I can change the color (for the second one) but not switch them on/off. I also can't control the one only defined in the things file at all.<br />
Thanks for any help, I am still trying to learn this stuff ;)</p>
]]></description><link>https://forum.mysensors.org/topic/7241/define-mysensor-rgbw-things-in-openhab2</link><generator>RSS for Node</generator><lastBuildDate>Thu, 15 Oct 2026 02:17:09 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7241.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jul 2017 20:41:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Define Mysensor (rgbw) Things in openhab2 on Fri, 11 Aug 2017 10:46:46 GMT]]></title><description><![CDATA[<p dir="auto">Ok I'll answer my question here as I found the error with some help:<br />
it has to be</p>
<pre><code>nodeId
// not nodeID
</code></pre>
]]></description><link>https://forum.mysensors.org/post/73600</link><guid isPermaLink="true">https://forum.mysensors.org/post/73600</guid><dc:creator><![CDATA[LastSamurai]]></dc:creator><pubDate>Fri, 11 Aug 2017 10:46:46 GMT</pubDate></item></channel></rss>
