<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Omron SSR with 3.3V node]]></title><description><![CDATA[<p dir="auto">Guys,<br />
I like the Omron G3MB-202 SSR<br />
So far I have used these on 5V arduinos<br />
I am now moving on towards my next project (touch wall switch) and would like to go for 3.3V nodes<br />
Any of you using these SSRs with 3.3V trigger ?<br />
Thanks a lot for your return ;)</p>
]]></description><link>https://forum.mysensors.org/topic/7321/omron-ssr-with-3-3v-node</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 03:51:39 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7321.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Aug 2017 14:01:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Omron SSR with 3.3V node on Fri, 11 Aug 2017 11:04:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nca78" aria-label="Profile: Nca78">@<bdi>Nca78</bdi></a><br />
Great!<br />
Orders on the way then!!</p>
]]></description><link>https://forum.mysensors.org/post/73605</link><guid isPermaLink="true">https://forum.mysensors.org/post/73605</guid><dc:creator><![CDATA[ben999]]></dc:creator><pubDate>Fri, 11 Aug 2017 11:04:50 GMT</pubDate></item><item><title><![CDATA[Reply to Omron SSR with 3.3V node on Fri, 11 Aug 2017 07:20:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ben999" aria-label="Profile: ben999">@<bdi>ben999</bdi></a> yes, directly connected. I suppose transistor is here for the case when your board signal voltage is too low compared to the voltage of the SSR as the necessary current for SSR is low.</p>
]]></description><link>https://forum.mysensors.org/post/73590</link><guid isPermaLink="true">https://forum.mysensors.org/post/73590</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Fri, 11 Aug 2017 07:20:15 GMT</pubDate></item><item><title><![CDATA[Reply to Omron SSR with 3.3V node on Thu, 10 Aug 2017 20:47:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nca78" aria-label="Profile: Nca78">@<bdi>Nca78</bdi></a><br />
Thank you for sharing your experience<br />
There are resistors and transistors on the relay board... I guess the relay is triggered via a transistor then...<br />
Do you run the relay itself (black bloc only) straight from the arduino output?</p>
]]></description><link>https://forum.mysensors.org/post/73566</link><guid isPermaLink="true">https://forum.mysensors.org/post/73566</guid><dc:creator><![CDATA[ben999]]></dc:creator><pubDate>Thu, 10 Aug 2017 20:47:48 GMT</pubDate></item><item><title><![CDATA[Reply to Omron SSR with 3.3V node on Thu, 10 Aug 2017 14:39:37 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="/user/ben999" aria-label="Profile: ben999">@<bdi>ben999</bdi></a>,</p>
<p dir="auto">I have not had any problem with those relays (at least the cheap clones from aliexpress) when running the full board at 3.3V (using HLK-PM03).</p>
]]></description><link>https://forum.mysensors.org/post/73548</link><guid isPermaLink="true">https://forum.mysensors.org/post/73548</guid><dc:creator><![CDATA[Nca78]]></dc:creator><pubDate>Thu, 10 Aug 2017 14:39:37 GMT</pubDate></item></channel></rss>
