<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[openhabian +mysensors binding 2.2]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/timo" aria-label="Profile: TimO">@<bdi>TimO</bdi></a><br />
i did a new install on raspberry<br />
i used the openhabian install and the mysensors binding 2.2<br />
but it doesnt work.<br />
the gateway is working with no problem, is in paperui online</p>
<pre><code>21:25:17.899 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 1-1-0 s=12,c=1,t=17,pt=4,l=4,sg=0:468
21:25:17.915 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;12;1;0;17;468
21:25:17.936 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 1-1-0 s=13,c=1,t=17,pt=4,l=4,sg=0:2215
21:25:17.955 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;13;1;0;17;2215
21:25:17.975 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 1-1-0 s=10,c=1,t=34,pt=4,l=4,sg=0:0
21:25:17.993 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;10;1;0;34;0
21:25:18.011 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 1-1-0 s=15,c=1,t=34,pt=2,l=2,sg=0:688
21:25:18.029 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 1;15;1;0;34;688
21:25:18.045 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 1-1-0 s=11,c=1,t=0,pt=2,l=2,sg=0:21
</code></pre>
<p dir="auto">and i made just a 1 simple item. but i keep getting errors en nothing values in paperui</p>
<pre><code>Bridge mysensors:bridge-ser:gateway [ serialPort="/dev/ttyUSB0", sendDelay=200, baudrate=115200, skipStartupCheck=true ] {
        temperature     tempgang01              [ nodeId="1" , childId="11" ]
</code></pre>
<pre><code>Number tempgang01 "Temperature [%.1f °C]" { channel="mysensors:temperature:gateway:tempgang01:temp" }
</code></pre>
<pre><code>21:12:23.321 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'home.things'
21:12:23.741 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Disposing of the MySensors bridge
21:12:23.763 [DEBUG] [.discovery.MySensorsDiscoveryService] - Stopping MySensors discovery scan
21:12:23.911 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent UNREGISTERING - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=348, service.bundleid=181, service.scope=singleton} - org.openhab.binding.mysensors
21:12:24.001 [DEBUG] [col.serial.MySensorsSerialConnection] - Destroying connection
21:12:24.021 [DEBUG] [col.serial.MySensorsSerialConnection] - Shutting down serial connection!
21:12:24.044 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Stopping Writer thread
21:12:24.068 [WARN ] [rsAbstractConnection$MySensorsWriter] - Interrupted MySensorsWriter
21:12:24.117 [DEBUG] [rsAbstractConnection$MySensorsReader] - Stopping Reader thread
21:12:24.143 [WARN ] [rsAbstractConnection$MySensorsReader] - Interrupted MySensorsReader
21:12:24.224 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:tempgang01' changed from ONLINE to OFFLINE (COMMUNICATION_ERROR)
21:12:24.273 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:tempgang01' changed from OFFLINE (COMMUNICATION_ERROR) to OFFLINE (BRIDGE_OFFLINE)
21:12:24.294 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge
21:12:24.342 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache file: given_ids.cached exist.
21:12:24.364 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Cache (given_ids) content: [0]
21:12:24.392 [DEBUG] [col.serial.MySensorsSerialConnection] - Enabling connection watchdog
21:12:24.413 [DEBUG] [col.serial.MySensorsSerialConnection] - Connecting to /dev/ttyUSB0 [baudRate:115200]
21:12:24.451 [DEBUG] [col.serial.MySensorsSerialConnection] - Final port list: /dev/ttyUSB0
21:12:24.494 [DEBUG] [col.serial.MySensorsSerialConnection] - Successfully connected to serial port.
21:12:24.515 [DEBUG] [col.serial.MySensorsSerialConnection] - Waiting 3 seconds to allow correct reset trigger on serial connection opening
21:12:24.557 [DEBUG] [org.openhab.binding.mysensors       ] - ServiceEvent REGISTERED - {org.eclipse.smarthome.config.discovery.DiscoveryService}={service.id=349, service.bundleid=181, service.scope=singleton} - org.openhab.binding.mysensors
21:12:24.627 [DEBUG] [.discovery.MySensorsDiscoveryService] - Starting MySensors discovery scan
21:12:24.644 [DEBUG] [nsors.handler.MySensorsBridgeHandler] - Initialization of the MySensors bridge DONE!
21:12:24.688 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:bridge-ser:gateway' has been updated.
21:12:24.711 [DEBUG] [sensors.internal.event.EventRegister] - Listener org.openhab.binding.mysensors.handler.MySensorsThingHandler@95e2ff not present, cannot remove it
21:12:24.738 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'nodeId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
java.lang.IllegalArgumentException: Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
        at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:167)[:1.8.0_121]
        at sun.reflect.UnsafeFieldAccessorImpl.throwSetIllegalArgumentException(UnsafeFieldAccessorImpl.java:171)[:1.8.0_121]
        at sun.reflect.UnsafeIntegerFieldAccessorImpl.set(UnsafeIntegerFieldAccessorImpl.java:98)[:1.8.0_121]
        at java.lang.reflect.Field.set(Field.java:764)[:1.8.0_121]
        at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:523)[30:org.apache.commons.lang:2.6.0]
        at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:500)[30:org.apache.commons.lang:2.6.0]
        at org.apache.commons.lang.reflect.FieldUtils.writeField(FieldUtils.java:560)[30:org.apache.commons.lang:2.6.0]
        at org.eclipse.smarthome.config.core.Configuration.as(Configuration.java:96)[94:org.eclipse.smarthome.config.core:0.9.0.b5]
        at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.getConfigAs(BaseThingHandler.java:248)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
        at org.openhab.binding.mysensors.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:71)[181:org.openhab.binding.mysensors:2.2.0.201708090807]
        at org.eclipse.smarthome.core.thing.binding.BaseThingHandler.thingUpdated(BaseThingHandler.java:192)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
        at org.eclipse.smarthome.core.thing.internal.ThingManager$7.call(ThingManager.java:528)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
        at org.eclipse.smarthome.core.thing.internal.ThingManager$7.call(ThingManager.java:1)[105:org.eclipse.smarthome.core.thing:0.9.0.b5]
        at org.eclipse.smarthome.core.common.SafeMethodCaller$CallableWrapper.call(SafeMethodCaller.java:181)[98:org.eclipse.smarthome.core:0.9.0.b5]
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)[:1.8.0_121]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
        at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
21:12:24.783 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'childId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.childId to java.lang.String
java.lang.IllegalArgumentException: Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.childId to java.lang.String
21:12:24.840 [DEBUG] [ensors.handler.MySensorsThingHandler] - Configuration: MySensorsSensorConfiguration [nodeId=0, childId=0, requestAck=false, revertState=true, smartSleep=false, childUpdateTimeout=-1, nodeUpdateTimeout=-1, requestHeartbeatResponse=false]
21:12:24.862 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'nodeId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
        at org.openhab.binding.mysensors.handler.MySensorsThingHandler.generateNodeFromThing(MySensorsThingHandler.java:336)[181:org.openhab.binding.mysensors:2.2.0.201708090807]
        at org.openhab.binding.mysensors.handler.MySensorsThingHandler.addIntoGateway(MySensorsThingHandler.java:324)[181:org.openhab.binding.mysensors:2.2.0.201708090807]
        at org.openhab.binding.mysensors.handler.MySensorsThingHandler.initialize(MySensorsThingHandler.java:76)[181:org.openhab.binding.mysensors:2.2.0.201708090807]
21:12:24.910 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'childId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.childId to java.lang.String
21:12:24.970 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'nodeId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.nodeId to java.lang.String
        at org.openhab.binding.mysensors.handler.MySensorsThingHandler.generateNodeFromThing(MySensorsThingHandler.java:337)[181:org.openhab.binding.mysensors:2.2.0.201708090807]
21:12:25.015 [WARN ] [.smarthome.config.core.Configuration] - Could not set field value for field 'childId': Can not set int field org.openhab.binding.mysensors.config.MySensorsSensorConfiguration.childId to java.lang.String
21:12:25.072 [DEBUG] [rs.internal.gateway.MySensorsGateway] - Merging child map: {} with: {0=MySensorsChild [childId=0, nodeValue={V_VAR3=MySensorsVariableVVar3 [value=null], V_VAR1=MySensorsVariableVVar1 [value=null], V_VAR4=MySensorsVariableVVar4 [value=null], V_VAR5=MySensorsVariableVVar5 [value=null], V_ID=MySensorsVariableVId [value=null], V_VAR2=MySensorsVariableVVar2 [value=null], V_TEMP=MySensorsVariableVTemp [value=null]}]}
21:12:25.096 [DEBUG] [ensors.handler.MySensorsThingHandler] - Event listener for node 0-0 not registered yet, registering...
21:12:25.142 [INFO ] [me.event.ThingStatusInfoChangedEvent] - 'mysensors:temperature:gateway:tempgang01' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
21:12:25.229 [INFO ] [smarthome.event.ThingUpdatedEvent   ] - Thing 'mysensors:temperature:gateway:tempgang01' has been updated.
21:12:27.548 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;gateway started, id=0, parent=0, distance=0
21:12:27.552 [DEBUG] [rsAbstractConnection$MySensorsWriter] - Sending to MySensors: 0;0;3;0;2;
21:12:27.589 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;14;Gateway startup complete.
21:12:27.614 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;2;1.5.1
21:12:27.640 [DEBUG] [rsAbstractConnection$MySensorsReader] - Good,Gateway is up and running! (Ver:1.5.1)
21:12:27.722 [DEBUG] [ensors.factory.MySensorsCacheFactory] - Writing on cache given_ids, content: [0]
21:12:27.774 [INFO ] [col.serial.MySensorsSerialConnection] - Successfully connected to MySensors Bridge.
21:12:31.466 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 3-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0:22.0
21:12:31.498 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 3;1;1;0;0;22.0
21:12:31.517 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 3-3-0 s=0,c=1,t=1,pt=7,l=5,sg=0:37.0
21:12:31.544 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 3;0;1;0;1;37.0
21:12:31.565 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 0;0;3;0;9;read: 3-3-0 s=4,c=1,t=23,pt=2,l=2,sg=0:0
21:12:31.594 [DEBUG] [rsAbstractConnection$MySensorsReader] - Message from gateway received: 3;4;1;0;23;0
</code></pre>
<p dir="auto">is something changed</p>
]]></description><link>https://forum.mysensors.org/topic/7339/openhabian-mysensors-binding-2-2</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 19:15:52 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7339.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Aug 2017 19:33:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to openhabian +mysensors binding 2.2 on Sun, 13 Aug 2017 11:06:44 GMT]]></title><description><![CDATA[<p dir="auto">so i was not crazy....<br />
after deleting all 143 items, installing new openhab. configure everything.....<br />
yep ...i forgot to read them   ... mea culpa.... ;)</p>
]]></description><link>https://forum.mysensors.org/post/73788</link><guid isPermaLink="true">https://forum.mysensors.org/post/73788</guid><dc:creator><![CDATA[[[global:former-user]]]]></dc:creator><pubDate>Sun, 13 Aug 2017 11:06:44 GMT</pubDate></item><item><title><![CDATA[Reply to openhabian +mysensors binding 2.2 on Sun, 13 Aug 2017 10:36:33 GMT]]></title><description><![CDATA[<p dir="auto">@ikjes said in <a href="/post/73747">openhabian +mysensors binding 2.2</a>:</p>
<blockquote>
<p dir="auto">[ nodeId="1" , childId="11" ]</p>
</blockquote>
<p dir="auto">Imho this needs to be</p>
<pre><code>[ nodeId=1 , childId=11 ]
</code></pre>
<p dir="auto">Read the patchnotes from the latest mysensors binding update ;)</p>
]]></description><link>https://forum.mysensors.org/post/73786</link><guid isPermaLink="true">https://forum.mysensors.org/post/73786</guid><dc:creator><![CDATA[LastSamurai]]></dc:creator><pubDate>Sun, 13 Aug 2017 10:36:33 GMT</pubDate></item></channel></rss>
