<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Alternative passive mode]]></title><description><![CDATA[<p dir="auto">This is a small example of a sketch in which part of the passive node functionality is implemented. Ask works. This can be used in void setup () or void loop (), you can both enable and disable it when an event is detected. I hope this will be useful in your development.</p>
<p dir="auto"><a href="https://youtu.be/SNAq0W37lrg" rel="nofollow ugc">https://youtu.be/SNAq0W37lrg</a></p>
<pre><code>bool state = true;
#define MY_NODE_ID 100
#define MY_TRANSPORT_WAIT_READY_MS 10000  // optional parameter used for the test
#define MY_PARENT_NODE_ID 101  // optional parameter used for the test
#define MY_PARENT_NODE_IS_STATIC  // optional parameter used for the test
//#define MY_PASSIVE_NODE  // !!! Please note this is disabled :) !!!
#include &lt;MySensors.h&gt;
#define RELAY 1
MyMessage msg(RELAY,V_STATUS);
  present(RELAY, S_BINARY);
  sendSketchInfo("TEST RELAY", "1.1");
  transportSwitchSM(stReady);
  Serial.begin(115200);
Serial.println(" SEND HELLO ");
_transportConfig.parentNodeId = 101;
send(msg.setDestination(101).setSensor(1).set(state));
  delay(5000);
_transportConfig.parentNodeId = 0;
send(msg.setDestination(0).setSensor(1).set(state));
  delay(5000);
void receive(const MyMessage &amp;message) {
  Serial.println("Hello is delivered");
</code></pre>
]]></description><link>https://forum.mysensors.org/topic/7810/alternative-passive-mode</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Apr 2026 23:33:28 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7810.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 14 Oct 2017 09:32:50 GMT</pubDate><ttl>60</ttl></channel></rss>
