<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Radio no longer working after new Hassbian install]]></title><description><![CDATA[<p dir="auto">I had a perfectly working MySensors Pi Gateway working on Ethernet alongside a Home Assistant install on the same Pi.</p>
<p dir="auto">I decided to upgrade the Home Assistant to the latest Hassbian image which meant reinstallation of MySensors. Everything installed OK however now MySensors fails to talk to the radio. Nothing was physically changed on the Pi so I'm reasonably certain the radio and wiring are OK although I have since added a cap on the power supply pins.</p>
<p dir="auto">Any thoughts?</p>
<p dir="auto">Here is the debugging output:</p>
<pre><code>pi@ShedHA:~/MySensors $ ./bin/mysgw -d
mysgw: Starting gateway...
mysgw: MCO:BGN:INIT GW,CP=RNNG---,VER=2.1.1
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: !TSM:INIT:TSP FAIL
mysgw: TSM:FAIL:CNT=1
mysgw: TSM:FAIL:PDT
mysgw: TSM:FAIL:RE-INIT
mysgw: TSM:INIT
mysgw: TSM:FAIL:CNT=2
mysgw: TSM:FAIL:PDT
mysgw: TSM:INIT
mysgw: TSM:FAIL:CNT=3```</code></pre>
]]></description><link>https://forum.mysensors.org/topic/7924/radio-no-longer-working-after-new-hassbian-install</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 05:09:34 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/7924.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 05 Nov 2017 06:01:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Radio no longer working after new Hassbian install on Sun, 05 Nov 2017 19:44:55 GMT]]></title><description><![CDATA[<p dir="auto">Installed development version and all working 100%. Thanks for the help.</p>
]]></description><link>https://forum.mysensors.org/post/78949</link><guid isPermaLink="true">https://forum.mysensors.org/post/78949</guid><dc:creator><![CDATA[pgv]]></dc:creator><pubDate>Sun, 05 Nov 2017 19:44:55 GMT</pubDate></item><item><title><![CDATA[Reply to Radio no longer working after new Hassbian install on Sun, 05 Nov 2017 17:17:08 GMT]]></title><description><![CDATA[<p dir="auto">I had the same problem and can confirm that development version works better.</p>
]]></description><link>https://forum.mysensors.org/post/78940</link><guid isPermaLink="true">https://forum.mysensors.org/post/78940</guid><dc:creator><![CDATA[monkee]]></dc:creator><pubDate>Sun, 05 Nov 2017 17:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to Radio no longer working after new Hassbian install on Sun, 05 Nov 2017 17:06:05 GMT]]></title><description><![CDATA[<p dir="auto">There are some issues with 2.1.1, try with development version</p>
]]></description><link>https://forum.mysensors.org/post/78938</link><guid isPermaLink="true">https://forum.mysensors.org/post/78938</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Sun, 05 Nov 2017 17:06:05 GMT</pubDate></item></channel></rss>
