<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[veralite ui5 not seeing distance sensor in 1.4]]></title><description><![CDATA[<p dir="auto">ok here is problem added distance sketch from my sensors and when included, plugin saw 2 devices, node1 and distance 1.<br />
both boxes are blank as well as my sensors plugin box<br />
Have been using temp/humidity successfully for the last few weeks. After including new device allboxes ( distance,temp,hum,and plugin) are there but blank.<br />
Using veralite ui5, lib 1.4 and issue 1.4<br />
I have tried with only distance deleting the temp portion and reinstalling plugin and including with same results. reverting back to both units gave the same results?<br />
I have included pic .<br />
Is there something I missed and need to do with the gw? or new node?</p>
<p dir="auto">It is on a pro mini 5v clone  with3 v  regulator   for radio and seemed to compile correctly and uploaded with no problems<br />
any ideas</p>
]]></description><link>https://forum.mysensors.org/topic/800/veralite-ui5-not-seeing-distance-sensor-in-1-4</link><generator>RSS for Node</generator><lastBuildDate>Sat, 10 Oct 2026 17:13:00 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/800.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 09 Jan 2015 19:53:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to veralite ui5 not seeing distance sensor in 1.4 on Fri, 09 Jan 2015 22:39:47 GMT]]></title><description><![CDATA[<p dir="auto">all sensors are good now thanks! <a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a></p>
]]></description><link>https://forum.mysensors.org/post/8511</link><guid isPermaLink="true">https://forum.mysensors.org/post/8511</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Fri, 09 Jan 2015 22:39:47 GMT</pubDate></item><item><title><![CDATA[Reply to veralite ui5 not seeing distance sensor in 1.4 on Fri, 09 Jan 2015 21:39:06 GMT]]></title><description><![CDATA[<p dir="auto">Thanks <a class="plugin-mentions-user plugin-mentions-a" href="/user/hek" aria-label="Profile: hek">@<bdi>hek</bdi></a>!</p>
<p dir="auto">Another problem solved for the rookie!</p>
]]></description><link>https://forum.mysensors.org/post/8509</link><guid isPermaLink="true">https://forum.mysensors.org/post/8509</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Fri, 09 Jan 2015 21:39:06 GMT</pubDate></item><item><title><![CDATA[Reply to veralite ui5 not seeing distance sensor in 1.4 on Fri, 09 Jan 2015 19:59:39 GMT]]></title><description><![CDATA[<p dir="auto">Did you upload the Distance device files?</p>
<p dir="auto"><a href="http://www.mysensors.org/build/vera#device-specific-settings-and-files" rel="nofollow ugc">http://www.mysensors.org/build/vera#device-specific-settings-and-files</a></p>
]]></description><link>https://forum.mysensors.org/post/8502</link><guid isPermaLink="true">https://forum.mysensors.org/post/8502</guid><dc:creator><![CDATA[hek]]></dc:creator><pubDate>Fri, 09 Jan 2015 19:59:39 GMT</pubDate></item><item><title><![CDATA[Reply to veralite ui5 not seeing distance sensor in 1.4 on Fri, 09 Jan 2015 19:56:35 GMT]]></title><description><![CDATA[<p dir="auto"><img src="/uploads/upload-91b0a365-68b3-4ab3-af60-d995bf94f36b.png" alt="Screenshot (24).png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/post/8501</link><guid isPermaLink="true">https://forum.mysensors.org/post/8501</guid><dc:creator><![CDATA[5546dug]]></dc:creator><pubDate>Fri, 09 Jan 2015 19:56:35 GMT</pubDate></item></channel></rss>
