<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Not all of a node&#x27;s children sensors are visible in HA]]></title><description><![CDATA[<p dir="auto">Howdy,</p>
<p dir="auto">I have added a new SenseBender NodeManger which is visible in the dev-states screen.    However one of the children sensors is not showing in the dev-states screen in HA . Specifically the door sensor which is child sensor #3.  Below is a copy and paste from the dev-states screen.</p>
<pre><code>sensor.nodemanager_113_1	24.99	battery_level: 100
child_id: 1
description:
device: /dev/ttyACM1
node_id: 113
V_TEMP: 24.99
unit_of_measurement: °C
friendly_name: NodeManager 113 1
sensor.nodemanager_113_2	69.01	battery_level: 100
child_id: 2
description:
node_id: 113
V_HUM: 69.01
unit_of_measurement: %
friendly_name: NodeManager 113 2
sensor.nodemanager_113_200	SLEEPING	battery_level: 100
child_id: 200
description:
node_id: 113
V_CUSTOM: SLEEPING
friendly_name: NodeManager 113 200
sensor.nodemanager_113_201	3.34	battery_level: 100
child_id: 201
description:
node_id: 113
V_VOLTAGE: 3.34
unit_of_measurement: V
friendly_name: NodeManager 113 201
</code></pre>
<p dir="auto">I'm successfully running a number of other NodeManager SenseBender nodes on HA with just temp and humidity.</p>
<p dir="auto">The mysensors.json file appears to be showing the correct number of children sensors, including sensor #3 which is the door sensor:</p>
<pre><code>"113": {
    "sensor_id": 113,
    "children": {
      "1": {
        "id": 1,
        "type": 6,
        "description": "",
        "values": {
          "0": "24.99"
      "2": {
        "id": 2,
        "type": 7,
        "description": "",
        "values": {
          "1": "69.01"
      "3": {
        "id": 3,
        "type": 23,
        "description": "",
        "values": {
          "16": "1"
      "200": {
        "id": 200,
        "type": 23,
        "description": "",
        "values": {
          "48": "SLEEPING"
      "201": {
        "id": 201,
        "type": 30,
        "description": "",
        "values": {
          "38": "3.34"
</code></pre>
<p dir="auto">I know that the door sensor is working as child sensor #200 shows the change to the wake / sleeping state when the NodeManager wakes up from the door sensor interrupt.  Also, I can see that the NodeManager is sending the message in the serial console on change to the door sensor,</p>
<p dir="auto">Any thoughts as to why child sensor #3 is not showing in HA?</p>
<p dir="auto">Thanks,<br />
Simon</p>
]]></description><link>https://forum.mysensors.org/topic/8010/not-all-of-a-node-s-children-sensors-are-visible-in-ha</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 06:37:35 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8010.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 19 Nov 2017 01:10:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Not all of a node&#x27;s children sensors are visible in HA on Sun, 19 Nov 2017 03:48:50 GMT]]></title><description><![CDATA[<p dir="auto">I'm an idiot.......</p>
<p dir="auto">I just noticed a binary_sensor.nodemanager_113_3 was created in the dev-state page.</p>
]]></description><link>https://forum.mysensors.org/post/79803</link><guid isPermaLink="true">https://forum.mysensors.org/post/79803</guid><dc:creator><![CDATA[simbo]]></dc:creator><pubDate>Sun, 19 Nov 2017 03:48:50 GMT</pubDate></item></channel></rss>
