<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[SOLVED] Itead Rboard 2.1.1]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I've been using Mysensors for a long time without need to update from version 1.4!  :)</p>
<p dir="auto">Most of my nodes are mains powered and use relay's for switching lots of different stuff. Recently I have updated my serial gateway, uno's and nano's to 2.1 without problem, however, not so lucky with the Itead Rboard. <a class="plugin-mentions-user plugin-mentions-a" href="/user/gregl" aria-label="Profile: gregl">@<bdi>gregl</bdi></a> helped me last time by showing me how to reference pins 8 &amp; 9 for CE/CS. Could someone please help me understand what I must modify in a sketch using version 2.1.1?</p>
<p dir="auto">Thanks,<br />
Tim</p>
<p dir="auto">Re: <a href="/topic/364/itead-rboard-4-relay">ITEAD RBoard (4 relay)</a></p>
]]></description><link>https://forum.mysensors.org/topic/8027/solved-itead-rboard-2-1-1</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 00:02:32 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8027.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Nov 2017 12:17:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [SOLVED] Itead Rboard 2.1.1 on Thu, 23 Nov 2017 03:26:03 GMT]]></title><description><![CDATA[<p dir="auto">This page helped me solve the problem.</p>
<p dir="auto">Regards,<br />
Tim</p>
<p dir="auto"><a href="https://www.mysensors.org/download/sensor_api_20" rel="nofollow ugc">https://www.mysensors.org/download/sensor_api_20</a></p>
<pre><code>/**
 * Created by Henrik Ekblad &lt;henrik.ekblad@mysensors.org&gt;
 * Version 1.0 - Henrik Ekblad
//CE/CS Pins
#define MY_RF24_CE_PIN 8
#define MY_RF24_CS_PIN 9
#define MY_REPEATER_FEATURE
#include &lt;MySensors.h&gt;
#define RELAY_1  4  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
#define NUMBER_OF_RELAYS 4 // Total number of attached relays
void before()
	for (int sensor=1, pin=RELAY_1; sensor&lt;=NUMBER_OF_RELAYS; sensor++, pin++) {
		pinMode(pin, OUTPUT);
		present(sensor, S_BINARY);
void receive(const MyMessage &amp;message)
	if (message.type==V_STATUS) {
		// Change relay state
		// Store state in eeprom
		// Write some debug info
		Serial.print(message.sensor);
</code></pre>
]]></description><link>https://forum.mysensors.org/post/80083</link><guid isPermaLink="true">https://forum.mysensors.org/post/80083</guid><dc:creator><![CDATA[timg]]></dc:creator><pubDate>Thu, 23 Nov 2017 03:26:03 GMT</pubDate></item></channel></rss>
