<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[2gang in wall dimmer with touch sensors]]></title><description><![CDATA[<p dir="auto">Hello,<br />
I would like to present you my latest project - 2 gang dimmer to be placed in wall (EU) with livolo panel on top of it. Works with standard light bulbs and dimmable leds<br />
sorry fot the panel condition - it wen throuhg a lot :)<br />
in short:<br />
220v to 3v3 power supply<br />
esp8266-12e<br />
printable case<br />
zero-cross detection<br />
ttp223 touch sensors<br />
1.2A per dimm channel<br />
ws2812b RGB led![alt text](image url)</p>
<p dir="auto">and some pictures:<br />
<img src="https://preview.ibb.co/kHohaG/20171202_153542.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/m8GeNw/20171202_145547.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/hyAZpb/20171202_145539.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/gCo9Nw/20171202_144346.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/iRz5vG/20171202_144323.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/gBxEpb/20171202_144236.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/fLsQvG/20171202_144153.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/efFZpb/20171202_144110.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/jmpupb/20171202_144101.jpg" alt="alt text" class=" img-fluid img-markdown" /><br />
<img src="https://preview.ibb.co/kHLdFG/20171122_105453_1.jpg" alt="alt text" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/8498/2gang-in-wall-dimmer-with-touch-sensors</link><generator>RSS for Node</generator><lastBuildDate>Thu, 12 Mar 2026 19:18:19 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8498.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 02 Dec 2017 14:43:19 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 2gang in wall dimmer with touch sensors on Thu, 09 Apr 2020 00:46:26 GMT]]></title><description><![CDATA[<p dir="auto">I would be interested in the project, it is still working</p>
]]></description><link>https://forum.mysensors.org/post/104785</link><guid isPermaLink="true">https://forum.mysensors.org/post/104785</guid><dc:creator><![CDATA[Camposmansi]]></dc:creator><pubDate>Thu, 09 Apr 2020 00:46:26 GMT</pubDate></item><item><title><![CDATA[Reply to 2gang in wall dimmer with touch sensors on Sat, 09 Dec 2017 13:37:35 GMT]]></title><description><![CDATA[<p dir="auto">Nice project!<br />
I'm working on a partially similar solution as well :) hopefully it will be ready to release in the next weeks.<br />
In my setup I did not change the top board but reprogrammed the PIC MCU instead to be able to interface properly with my replaced controller board at the bottom.</p>
<p dir="auto">What did you use on your top board at the touch sensing section? I'm interested in the plastic stuff.</p>
]]></description><link>https://forum.mysensors.org/post/81500</link><guid isPermaLink="true">https://forum.mysensors.org/post/81500</guid><dc:creator><![CDATA[andrew]]></dc:creator><pubDate>Sat, 09 Dec 2017 13:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to 2gang in wall dimmer with touch sensors on Thu, 07 Dec 2017 10:34:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/davidzh" aria-label="Profile: davidzh">@<bdi>davidzh</bdi></a><br />
Powersupply is rather simple chinese one:<br />
<a href="https://aliexpress.com/item/1pcs-small-size-ac-dc-power-supply-module-220v-to-3-3v-1w-isolated-LED-" rel="nofollow ugc">https://aliexpress.com/item/1pcs-small-size-ac-dc-power-supply-module-220v-to-3-3v-1w-isolated-LED-</a><br />
ac/32653670258.html?spm=a2g17.10010108.1000016.1.73e0545dSSfyHB&amp;isOrigTitle=true</p>
]]></description><link>https://forum.mysensors.org/post/81396</link><guid isPermaLink="true">https://forum.mysensors.org/post/81396</guid><dc:creator><![CDATA[Mateusz Pięta]]></dc:creator><pubDate>Thu, 07 Dec 2017 10:34:36 GMT</pubDate></item><item><title><![CDATA[Reply to 2gang in wall dimmer with touch sensors on Sun, 03 Dec 2017 19:39:09 GMT]]></title><description><![CDATA[<p dir="auto">Interesting! Can you share some more details? I'm particularly interested in you power supply.</p>
]]></description><link>https://forum.mysensors.org/post/81237</link><guid isPermaLink="true">https://forum.mysensors.org/post/81237</guid><dc:creator><![CDATA[DavidZH]]></dc:creator><pubDate>Sun, 03 Dec 2017 19:39:09 GMT</pubDate></item></channel></rss>
