<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Otabootloader upload ?]]></title><description><![CDATA[<p dir="auto">I can upload the bootloader using Arduino as ISP ? who i need add in a board.txt?</p>
<p dir="auto">im use this but give an error<br />
#######################################<br />
Mysensors.name=[Mysensors OTA] Arduino Uno<br />
Mysensors.upload.protocol=arduino<br />
Mysensors.upload.maximum_size=32256<br />
Mysensors.upload.speed=115200<br />
Mysensors.bootloader.low_fuses=0xff<br />
Mysensors.bootloader.high_fuses=0xde<br />
Mysensors.bootloader.extended_fuses=0x05<br />
Mysensors.bootloader.path=MySensorsOTA<br />
Mysensors.bootloader.file=MyOtaBootloader.hex<br />
Mysensors.bootloader.unlock_bits=0x3F<br />
Mysensors.bootloader.lock_bits=0x0F<br />
Mysensors.build.mcu=atmega328p<br />
Mysensors.build.f_cpu=16000000L<br />
Mysensors.build.core=arduino<br />
Mysensors.build.variant=standard<br />
#####################################</p>
]]></description><link>https://forum.mysensors.org/topic/879/otabootloader-upload</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 04:26:42 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/879.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Jan 2015 01:41:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Otabootloader upload ? on Mon, 02 Mar 2015 18:15:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dheeraj" aria-label="Profile: Dheeraj">@<bdi>Dheeraj</bdi></a> Did you install the most recent version of the library? There were some significant changes in the routing and find_parent parts of the code...</p>
]]></description><link>https://forum.mysensors.org/post/10912</link><guid isPermaLink="true">https://forum.mysensors.org/post/10912</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Mon, 02 Mar 2015 18:15:38 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Mon, 02 Mar 2015 18:05:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a><br />
Is OTA or MYS bootloader  end to end working for you. if yes, let me know the steps that needs to be followed. i'm getting error in gateway where I_FIND_PARENT request(from sensor)  response is failing and not reaching to sensor node. however, it works after fresh make load command issue..</p>
]]></description><link>https://forum.mysensors.org/post/10910</link><guid isPermaLink="true">https://forum.mysensors.org/post/10910</guid><dc:creator><![CDATA[Dheeraj]]></dc:creator><pubDate>Mon, 02 Mar 2015 18:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:15:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> excellent :) have fun</p>
]]></description><link>https://forum.mysensors.org/post/9259</link><guid isPermaLink="true">https://forum.mysensors.org/post/9259</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:15:10 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:13:10 GMT]]></title><description><![CDATA[<p dir="auto">now it works ^^ thanks!</p>
]]></description><link>https://forum.mysensors.org/post/9258</link><guid isPermaLink="true">https://forum.mysensors.org/post/9258</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:12:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> you have to give us more information to troubleshoot. which error msg do you get?</p>
]]></description><link>https://forum.mysensors.org/post/9257</link><guid isPermaLink="true">https://forum.mysensors.org/post/9257</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:12:02 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:10:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> said:</p>
<blockquote>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> download and save from <a href="https://raw.githubusercontent.com/mysensors/Arduino/master/Bootloader/MyOtaBootloader.hex" rel="nofollow ugc">here</a>.</p>
</blockquote>
<p dir="auto">thanks. now i not get the error but i cant upload sketch</p>
]]></description><link>https://forum.mysensors.org/post/9256</link><guid isPermaLink="true">https://forum.mysensors.org/post/9256</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:10:09 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:06:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> download and save from <a href="https://raw.githubusercontent.com/mysensors/Arduino/master/Bootloader/MyOtaBootloader.hex" rel="nofollow ugc">here</a>.</p>
]]></description><link>https://forum.mysensors.org/post/9255</link><guid isPermaLink="true">https://forum.mysensors.org/post/9255</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:06:46 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 17:02:09 GMT]]></title><description><![CDATA[<p dir="auto">im downloaded from here <a href="https://github.com/mysensors/Arduino/tree/master/Bootloader" rel="nofollow ugc">link text</a> im try to copy manually</p>
]]></description><link>https://forum.mysensors.org/post/9253</link><guid isPermaLink="true">https://forum.mysensors.org/post/9253</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Sun, 25 Jan 2015 17:02:09 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 16:56:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> did you download/copy the entire .hex file? seems like you are missing some parts (eof)</p>
]]></description><link>https://forum.mysensors.org/post/9252</link><guid isPermaLink="true">https://forum.mysensors.org/post/9252</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 25 Jan 2015 16:56:54 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 16:48:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/daulagari" aria-label="Profile: daulagari">@<bdi>daulagari</bdi></a> said:</p>
<blockquote>
<p dir="auto">What kind of error do you get?</p>
</blockquote>
<p dir="auto">this error:</p>
<p dir="auto">avrdude: WARNING: no end of file record found for Intel Hex file "G:\arduino-1.0.5-r2\hardware\arduino\bootloaders\MySensorsOTA\MyOtaBootloader.hex"<br />
avrdude: WARNING: no end of file record found for Intel Hex file "G:\arduino-1.0.5-r2\hardware\arduino\bootloaders\MySensorsOTA\MyOtaBootloader.hex"</p>
]]></description><link>https://forum.mysensors.org/post/9251</link><guid isPermaLink="true">https://forum.mysensors.org/post/9251</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Sun, 25 Jan 2015 16:48:32 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 16:48:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tekka" aria-label="Profile: tekka">@<bdi>tekka</bdi></a> dont work for me</p>
]]></description><link>https://forum.mysensors.org/post/9250</link><guid isPermaLink="true">https://forum.mysensors.org/post/9250</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Sun, 25 Jan 2015 16:48:02 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 11:54:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> this setting is working for me (4k BL)</p>
<p dir="auto">proMS.name=Arduino Pro Mini (3V3 &amp; 5V, 16 MHz) w/ ATmega328 MySensors</p>
<p dir="auto">proMS.upload.tool=avrdude<br />
proMS.upload.protocol=arduino<br />
proMS.upload.maximum_size=28672<br />
proMS.upload.maximum_data_size=2048<br />
proMS.upload.speed=115200</p>
<p dir="auto">proMS.bootloader.tool=avrdude<br />
proMS.bootloader.unlock_bits=0x3F<br />
proMS.bootloader.lock_bits=0x0F<br />
proMS.bootloader.low_fuses=0xFF<br />
proMS.bootloader.high_fuses=0xD8<br />
proMS.bootloader.extended_fuses=0x05<br />
proMS.bootloader.file=MySensors/MyOtaBootloader.hex</p>
<p dir="auto">proMS.build.board=AVR_PRO<br />
proMS.build.core=arduino<br />
proMS.build.variant=standard</p>
<p dir="auto">proMS.build.mcu=atmega328p<br />
proMS.build.f_cpu=16000000L</p>
]]></description><link>https://forum.mysensors.org/post/9219</link><guid isPermaLink="true">https://forum.mysensors.org/post/9219</guid><dc:creator><![CDATA[tekka]]></dc:creator><pubDate>Sun, 25 Jan 2015 11:54:17 GMT</pubDate></item><item><title><![CDATA[Reply to Otabootloader upload ? on Sun, 25 Jan 2015 09:23:25 GMT]]></title><description><![CDATA[<p dir="auto">What kind of error do you get?</p>
]]></description><link>https://forum.mysensors.org/post/9212</link><guid isPermaLink="true">https://forum.mysensors.org/post/9212</guid><dc:creator><![CDATA[daulagari]]></dc:creator><pubDate>Sun, 25 Jan 2015 09:23:25 GMT</pubDate></item></channel></rss>
