<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Ethernet GW how know?]]></title><description><![CDATA[<p dir="auto">im have a question about ethernet gw. im buy one to test with my own controller in .net but when iupload the code i dont know if work or not., if upload from the mysensors page im get check wires, if upload from my pc im view in the serial monitor "Gateway startup complete" and start showing the recieved data from other sensors. but the ethernet work?? i cant connect from my custom controller</p>
]]></description><link>https://forum.mysensors.org/topic/883/ethernet-gw-how-know</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 09:24:35 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/883.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 25 Jan 2015 22:28:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Ethernet GW how know? on Mon, 26 Jan 2015 11:31:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/olaeke" aria-label="Profile: olaeke">@<bdi>olaeke</bdi></a> yes the softspi is enable. If upload from  the pc the radio work</p>
]]></description><link>https://forum.mysensors.org/post/9291</link><guid isPermaLink="true">https://forum.mysensors.org/post/9291</guid><dc:creator><![CDATA[ch3b7]]></dc:creator><pubDate>Mon, 26 Jan 2015 11:31:57 GMT</pubDate></item><item><title><![CDATA[Reply to Ethernet GW how know? on Mon, 26 Jan 2015 08:23:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/ch3b7" aria-label="Profile: ch3b7">@<bdi>ch3b7</bdi></a> Are you sure you have enabled SOFTSPI by uncomment #define SOFTSPI in RF24_config.h? It is easy to make the change in the wrong library file and not in the one that is acctually used by the IDE</p>
]]></description><link>https://forum.mysensors.org/post/9280</link><guid isPermaLink="true">https://forum.mysensors.org/post/9280</guid><dc:creator><![CDATA[olaeke]]></dc:creator><pubDate>Mon, 26 Jan 2015 08:23:13 GMT</pubDate></item></channel></rss>
