<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RFM69 bitrate settings]]></title><description><![CDATA[<p dir="auto">I have been looking around in config file di see if is possible to set a higher bitrate for the RFM69 radio and I found these</p>
<pre><code>#define MY_RFM69_BITRATE_MSB (RFM69_BITRATEMSB_55555)
#define MY_RFM69_BITRATE_LSB (RFM69_BITRATELSB_55555)
</code></pre>
<p dir="auto">and if I understood correctly it should set bitrate to 57kbps and I could define something different in sketch with any of the values I can find in RFM69registers_new.h, right? If so, is it possible to have a higher TX bitrate for the GW to speed up FOTA process or all nodes and gateway must have the same values?</p>
]]></description><link>https://forum.mysensors.org/topic/8835/rfm69-bitrate-settings</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 06:05:34 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8835.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Jan 2018 09:06:42 GMT</pubDate><ttl>60</ttl></channel></rss>
