<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Invalid Message, Sensor not being added]]></title><description><![CDATA[<p dir="auto">Having managed to get HASS to connect to the USB I am now unable to get the sensor recognised :)</p>
<p dir="auto">HASS is logging the following error:</p>
<p dir="auto"><img src="/assets/uploads/files/1515837978992-7c136908-fe6d-4fec-8ced-d16ee5662e6a-image-resized.png" alt="0_1515837980561_7c136908-fe6d-4fec-8ced-d16ee5662e6a-image.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">My sketch appears similar to the example here: <a href="https://home-assistant.io/components/sensor.mysensors/" rel="nofollow ugc">https://home-assistant.io/components/sensor.mysensors/</a></p>
<p dir="auto">I'm using an S_MULTIMETER to send V_VOLTAGE and V_CURRENT values but not V_IMPEDANCE.</p>
<p dir="auto">Tried changing the child_id to 255 in the sketch but no luck so switched it back to 1.</p>
<pre><code>#include &lt;SPI.h&gt;
#include &lt;MySensor.h&gt;
//#define DEBUG_ON  // comment out this line to disable serial debug
#define CHILD_ID 1
MyMessage msgVolts(CHILD_ID, V_VOLTAGE);
MyMessage msgAmps(CHILD_ID, V_CURRENT);
// Possible variable types for multimeter:  V_VOLTAGE, V_CURRENT, V_IMPEDANCE
unsigned long SLEEP_TIME = 5000;  // sleep time between reads (seconds * 1000 milliseconds)
int oldVoltage = 0;
int oldCurrent = 0;
int VOLTAGE_SENSE_PIN = A1;  // select the input pin for the battery sense point
int CURRENT_SENSE_PIN = A2;  // select the input pin for the battery sense point
  gw.begin();
  gw.present(CHILD_ID, S_MULTIMETER);
   gw.sendSketchInfo("Battery Charger", "1.0");
  pinMode(VOLTAGE_SENSE_PIN, INPUT);
  pinMode(CURRENT_SENSE_PIN, INPUT);
  #ifdef DEBUG
    Serial.begin(9600);
   // get the battery Voltage
  int     voltageLevel = analogRead(VOLTAGE_SENSE_PIN);
  int     currentLevel = analogRead(CURRENT_SENSE_PIN);
  double  levelinVolts = voltageLevel*0.0492903225806452;
  double  levelinAmps  = currentLevel*0.041125;
  #ifdef DEBUG
    Serial.println(voltageLevel);
    Serial.println(currentLevel);
    Serial.print("Voltage:");
    Serial.print(levelinVolts);
    Serial.print("v ");
    Serial.print(" Current:");
    Serial.print(levelinAmps);
    Serial.print("a MaxAmps:");
    //Serial.print(maxAmps);
    Serial.println("a ");
//   if (oldVoltage != levelinVolts) {
     // Power up radio after sleep
      gw.send(msgVolts.set(levelinVolts,1));
     oldVoltage = levelinVolts;
//  if (oldCurrent != levelinAmps) {
    gw.send(msgAmps.set(levelinAmps,1));
    oldCurrent = levelinAmps;
   gw.sleep(SLEEP_TIME);
</code></pre>
<p dir="auto">(I'm no Arduino expert and most of the sketch was adapted from a similar example I found.)</p>
<p dir="auto">Looking at how its set in Domoticz it does seem like the node itself has an id of 255 but I don't see anywhere to set that?  Maybe I should add this manually to the configuration.yaml some how?!</p>
]]></description><link>https://forum.mysensors.org/topic/8875/invalid-message-sensor-not-being-added</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 03:53:45 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8875.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Jan 2018 10:37:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 24 Nov 2018 14:39:13 GMT]]></title><description><![CDATA[<p dir="auto">Ok so after further reading I found info on the issue, it seems that these are debug messages, we can safaly ignore them.</p>
<p dir="auto"><a href="https://community.home-assistant.io/t/mysensors-multiple-sensors-on-same-child-id/34927/9" rel="nofollow ugc">homeassistant forum</a></p>
]]></description><link>https://forum.mysensors.org/post/95311</link><guid isPermaLink="true">https://forum.mysensors.org/post/95311</guid><dc:creator><![CDATA[terxw]]></dc:creator><pubDate>Sat, 24 Nov 2018 14:39:13 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 24 Nov 2018 14:31:13 GMT]]></title><description><![CDATA[<p dir="auto">I have same problem, on both my GWs  using MQTT (ESP2866 nodes ) in homeassistant i get lots of these errors</p>
<p dir="auto">At my parents:</p>
<pre><code>2018-11-24 15:23:51 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.4'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-11-24 15:23:51 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Lifepo solar node G 18 7: value_type 38, value = 0.4
2018-11-24 15:24:00 DEBUG (SyncWorker_18) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:24:17 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/255/3/0/0: b'50'
2018-11-24 15:24:21 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;255;3;0;0;50
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 255
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 28
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/1/1/0/38: b'2604.0'
2018-11-24 15:24:21 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;1;1;0;38;2604.0
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 1
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-11-24 15:24:21 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 1: value_type 38, value = 2604.0
2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/0/1/0/0: b'20.3'
2018-11-24 15:24:22 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;0;1;0;0;20.3
2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 0
2018-11-24 15:24:22 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 0: value_type 0, value = 20.3
2018-11-24 15:24:30 DEBUG (SyncWorker_0) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/255/3/0/0: b'80'
2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;255;3;0;0;80
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 255
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 21
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/1/1/0/38: b'3033.0'
2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;1;1;0;38;3033.0
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 1
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node 21 is missing sketch name
2018-11-24 15:24:47 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/21/0/1/0/0: b'22.5'
2018-11-24 15:24:47 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 21;0;1;0;0;22.5
2018-11-24 15:24:47 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 21 child 0
2018-11-24 15:24:50 DEBUG (SyncWorker_16) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/18/255/3/0/0: b'255'
2018-11-24 15:24:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 18;255;3;0;0;255
2018-11-24 15:24:55 WARNING (MainThread) [mysensors] Not a valid message: value must be integer between 0 and 100 for dictionary value @ data['payload']
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/18/7/1/0/38: b'0.3'
2018-11-24 15:24:55 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 18;7;1;0;38;0.3
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 18 child 7
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.3'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_CURRENT @ data[39]
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '0.3'}: sensor platform: node 18 child 7: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-11-24 15:24:55 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: Lifepo solar node G 18 7: value_type 38, value = 0.3
2018-11-24 15:25:00 DEBUG (SyncWorker_12) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:25:17 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/255/3/0/0: b'50'
2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;255;3;0;0;50
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 255
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 28
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/1/1/0/38: b'2604.0'
2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;1;1;0;38;2604.0
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 1
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2604.0'}: sensor platform: node 28 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: detska_dole 28 1: value_type 38, value = 2604.0
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on golianovo/mygateway1-out/28/0/1/0/0: b'20.3'
2018-11-24 15:25:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 28;0;1;0;0;20.3
2018-11-24 15:25:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 28 child 0
</code></pre>
<p dir="auto">And at home:</p>
<pre><code>2018-11-24 15:26:07 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;0;13
2018-11-24 15:26:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
2018-11-24 15:26:07 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/4/1/0/0: b'0.0'
2018-11-24 15:26:08 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;4;1;0;0;0.0
2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 4
2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 4: value_type 0, value = 0.0
2018-11-24 15:26:08 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/5/1/0/16: b'0.0'
2018-11-24 15:26:08 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;5;1;0;16;0.0
2018-11-24 15:26:08 WARNING (MainThread) [mysensors] Not a valid message: value must be either 0 or 1 for dictionary value @ data['payload']
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/2/1/0/37: b'0.0'
2018-11-24 15:26:09 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;2;1;0;37;0.0
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 2
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: binary_sensor platform: node 14 child 2: S_MOISTURE requires value_type V_TRIPPED @ data[16]
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: switch platform: node 14 child 2: S_MOISTURE requires value_type V_ARMED @ data[15]
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 2: value_type 37, value = 0.0
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/22: b'17283381'
2018-11-24 15:26:09 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;22;17283381
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
2018-11-24 15:26:09 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
2018-11-24 15:26:09 DEBUG (SyncWorker_12) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:26:15 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/255/3/0/0: b'53'
2018-11-24 15:26:25 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;255;3;0;0;53
2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 255
2018-11-24 15:26:25 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 16
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/1/1/0/38: b'2654.0'
2018-11-24 15:26:26 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;1;1;0;38;2654.0
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 1
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2654.0'}: sensor platform: node 16 child 1: S_MULTIMETER requires value_type V_CURRENT @ data[39]
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {38: '2654.0'}: sensor platform: node 16 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: cerman_kuchyna 16 1: value_type 38, value = 2654.0
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/16/0/1/0/0: b'25.0'
2018-11-24 15:26:26 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 16;0;1;0;0;25.0
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 16 child 0
2018-11-24 15:26:26 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: cerman_kuchyna 16 0: value_type 0, value = 25.0
2018-11-24 15:26:29 DEBUG (SyncWorker_10) [mysensors.persistence] Saving sensors to persistence file /config/mysensors.json
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/0: b'13'
2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;0;13
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/4/1/0/0: b'0.0'
2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;4;1;0;0;0.0
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 4
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 4: value_type 0, value = 0.0
2018-11-24 15:26:44 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/5/1/0/16: b'0.0'
2018-11-24 15:26:44 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;5;1;0;16;0.0
2018-11-24 15:26:44 WARNING (MainThread) [mysensors] Not a valid message: value must be either 0 or 1 for dictionary value @ data['payload']
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/2/1/0/37: b'0.0'
2018-11-24 15:26:45 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;2;1;0;37;0.0
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 2
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: binary_sensor platform: node 14 child 2: S_MOISTURE requires value_type V_TRIPPED @ data[16]
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Invalid values: {37: '0.0'}: switch platform: node 14 child 2: S_MOISTURE requires value_type V_ARMED @ data[15]
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.device] Entity update: balkon_polievanie 14 2: value_type 37, value = 0.0
2018-11-24 15:26:45 INFO (MainThread) [homeassistant.components.http.view] Serving / to 127.0.0.1 (auth: False)
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mqtt] Received message on cerman/mygateway1-out/14/255/3/0/22: b'17287055'
2018-11-24 15:26:45 DEBUG (MainThread) [mysensors.gateway_mqtt] Receiving 14;255;3;0;22;17287055
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Node update: node 14 child 255
2018-11-24 15:26:45 DEBUG (MainThread) [homeassistant.components.mysensors.gateway] Not a child update for node 14
</code></pre>
<p dir="auto">My config (same on both hass dockers only prefixes are different):</p>
<pre><code>mysensors:
  gateways:
    - device: mqtt
      topic_in_prefix: 'cerman/mygateway1-out'
      topic_out_prefix: 'cerman/mygateway1-in'
      persistence_file: '/config/mysensors.json'
      nodes:
        1:
#        3:
#          name: 'living_room'
  optimistic: false
  persistence: true
  retain: true
  version: '2.0'
</code></pre>
]]></description><link>https://forum.mysensors.org/post/95309</link><guid isPermaLink="true">https://forum.mysensors.org/post/95309</guid><dc:creator><![CDATA[terxw]]></dc:creator><pubDate>Sat, 24 Nov 2018 14:31:13 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 22:05:24 GMT]]></title><description><![CDATA[<p dir="auto">Ok I'll try that.  Think I have already tried with just sending one value in the sketch but perhaps I would also need to delete the persistent mysensors.json file for it to have a chance.</p>
]]></description><link>https://forum.mysensors.org/post/84214</link><guid isPermaLink="true">https://forum.mysensors.org/post/84214</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sat, 20 Jan 2018 22:05:24 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 16:22:58 GMT]]></title><description><![CDATA[<p dir="auto">I've looked at the home assistant log you've provided. Unfortunately I think I would need a serial log from the node to get more info. It's weird that you get an error about unit of measurement, since all values should be validated when leaving pymysensors before entering the home assistant layer.</p>
<p dir="auto">If I would guess, I'd say that some message is not sent/received and presentation not fully performed.</p>
<p dir="auto">I would recommend to change your sketch and keep one sensor value per child sensor, ie not both V_VOLTAGE and V_CURRENT in one child. Home assistant expects one value per child for normal sensors. Only complex entities like cover should report more than one value. It will avoid entity_id clashes.</p>
]]></description><link>https://forum.mysensors.org/post/84204</link><guid isPermaLink="true">https://forum.mysensors.org/post/84204</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Sat, 20 Jan 2018 16:22:58 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:57:50 GMT]]></title><description><![CDATA[<p dir="auto">Brilliant thanks very much for the help!</p>
]]></description><link>https://forum.mysensors.org/post/84189</link><guid isPermaLink="true">https://forum.mysensors.org/post/84189</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:57:50 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:54:54 GMT]]></title><description><![CDATA[<p dir="auto">That's good at least. Then the home assistant core feature of installing requirements seems to work in your installation.</p>
<p dir="auto">I'll have a look at the log messages and see if I can find the problem.</p>
<p dir="auto">I'll post back later tonight.</p>
]]></description><link>https://forum.mysensors.org/post/84188</link><guid isPermaLink="true">https://forum.mysensors.org/post/84188</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:54:54 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:48:18 GMT]]></title><description><![CDATA[<p dir="auto">3.4:</p>
<pre><code>Name: pyserial
Version: 3.4
Summary: Python Serial Port Extension
Home-page: https://github.com/pyserial/pyserial
Author: Chris Liechti
Author-email: cliechti@gmx.net
License: BSD
Location: /srv/homeassistant/lib/python3.4/site-packages
</code></pre>
]]></description><link>https://forum.mysensors.org/post/84187</link><guid isPermaLink="true">https://forum.mysensors.org/post/84187</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:48:18 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:46:14 GMT]]></title><description><![CDATA[<p dir="auto">What version of pyserial is installed inside the virtual environment?</p>
<pre><code>sudo su -s /bin/bash homeassistant
cd /srv/homeassistant
source bin/activate
pip3 show pyserial
</code></pre>
]]></description><link>https://forum.mysensors.org/post/84186</link><guid isPermaLink="true">https://forum.mysensors.org/post/84186</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:42:34 GMT]]></title><description><![CDATA[<p dir="auto">Installed Home Assistant manually on Raspian following the <a href="https://home-assistant.io/docs/installation/raspberry-pi/" rel="nofollow ugc">install guide</a></p>
]]></description><link>https://forum.mysensors.org/post/84185</link><guid isPermaLink="true">https://forum.mysensors.org/post/84185</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:42:34 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:39:35 GMT]]></title><description><![CDATA[<p dir="auto">Pymysensors and home assistant requires pyserial version 3.1.1 or higher. This should be installed automatically when installing and running home assistant with mysensors activated. If it doesn't do that something with your install and environment is not operating normally.</p>
<p dir="auto">How have you installed home assistant?</p>
]]></description><link>https://forum.mysensors.org/post/84184</link><guid isPermaLink="true">https://forum.mysensors.org/post/84184</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:39:35 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Fri, 19 Jan 2018 17:50:55 GMT]]></title><description><![CDATA[<p dir="auto">Given up!</p>
<p dir="auto">Written a simple flow in NodeRed that forwards the messages on just fine.</p>
<p dir="auto"><img src="/assets/uploads/files/1516383923415-cfbb9bf7-e0d9-4e36-9b18-c38263905244-image-resized.png" alt="0_1516383923802_cfbb9bf7-e0d9-4e36-9b18-c38263905244-image.png" class="img-markdown  img-fluid" /></p>
<pre><code>[{"id":"a0e7c229.c1b2","type":"serial in","z":"c20914f0.8b8318","name":"MySensorsInput","serial":"4ba29f87.c500a","x":100,"y":68,"wires":[["c275b371.0a92a"]]},{"id":"2c003b62.b3ca04","type":"debug","z":"c20914f0.8b8318","name":"","active":true,"console":"false","complete":"true","x":976,"y":57,"wires":[]},{"id":"c275b371.0a92a","type":"function","z":"c20914f0.8b8318","name":"Decode Message","func":"var message = msg.payload;\nvar result = message.split(\";\");\nvar arrlength = result.length;\n\nmsg.payload = {};\n\nif(arrlength==6){\nmsg.payload.nodeid = result[0];\nmsg.payload.childid = result[1];\nmsg.payload.command = result[2];\nmsg.payload.ack = result[3];\nmsg.payload.type = result[4];\nmsg.payload.payload = result[5];\n} else {\n    msg.payload = \"Ignore\";\n}\n\n\n//1;1;1;0;39;8.8\n\n//1;;1;0;38;3.6\n\nreturn msg;","outputs":1,"noerr":0,"x":324,"y":68,"wires":[["5e07aa77.6b3884"]]},{"id":"5e07aa77.6b3884","type":"switch","z":"c20914f0.8b8318","name":"Filter Update Messages","property":"payload.command","propertyType":"msg","rules":[{"t":"eq","v":"1","vt":"str"}],"checkall":"true","outputs":1,"x":581,"y":68,"wires":[["764204f4.fe8bdc"]]},{"id":"a9be705b.07cec","type":"mqtt out","z":"c20914f0.8b8318","name":"","topic":"","qos":"","retain":"","broker":"9ccc9e2b.1b109","x":1018,"y":157,"wires":[]},{"id":"764204f4.fe8bdc","type":"function","z":"c20914f0.8b8318","name":"Format MQTT Message","func":"var nodeid = msg.payload.nodeid;\nvar type =  msg.payload.type;\nvar value = msg.payload.payload;\n\nmsg.payload = {}\n\nmsg.topic = \"haas/mySensors/\"+ nodeid +\"/\" + type;\nmsg.payload.string = value;\n\nreturn msg;","outputs":1,"noerr":0,"x":785,"y":157,"wires":[["a9be705b.07cec","2c003b62.b3ca04"]]},{"id":"4ba29f87.c500a","type":"serial-port","z":"","serialport":"/dev/ttyUSB0","serialbaud":"115200","databits":"8","parity":"none","stopbits":"1","newline":"\\n","bin":"false","out":"char","addchar":false},{"id":"9ccc9e2b.1b109","type":"mqtt-broker","z":"","broker":"localhost","port":"1883","clientid":"","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"willTopic":"","willQos":"0","willPayload":"","birthTopic":"","birthQos":"0","birthPayload":""}]
</code></pre>
<p dir="auto">This sends updates to a couple of MQTT sensors set up in my config.</p>
<pre><code>sensor:
  - platform: mqtt
    state_topic: "haas/mySensors/1/39"
    value_template: '{{ value_json.string }}'
    unit_of_measurement: 'a'
  - platform: mqtt
    state_topic: "haas/mySensors/1/38"
    unit_of_measurement: 'V'
</code></pre>
<p dir="auto">Not sure if there's a better value template than string? Couldn't find any detail on what options there were..</p>
]]></description><link>https://forum.mysensors.org/post/84139</link><guid isPermaLink="true">https://forum.mysensors.org/post/84139</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Fri, 19 Jan 2018 17:50:55 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 20 Jan 2018 11:58:16 GMT]]></title><description><![CDATA[<p dir="auto">Well I've had about enough of this nothing I do seems to work.</p>
<ul>
<li>Upgraded both my gateway and node to MySensors 2</li>
<li>Configuration.yaml seems correct as per previous post</li>
<li>Some messages seem like they are accepted but no sensors show up</li>
<li>
<ul>
<li>It also seems like the Gateway may store messages or values, as some that are logged are older values?</li>
</ul>
</li>
<li>PySerial is 2.6 and I can't seem to down/upgrade it whatever I do</li>
<li>strange script errors also but this could also be because of the bad data errors</li>
</ul>
<p dir="auto">Script Error:</p>
<pre><code>  File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/sensor/mysensors.py", line 68, in unit_of_measurement
    set_req.V_ORP: 'mV',
</code></pre>
<p dir="auto">I'm about ready to give up now, very frustrating when Domoticz is working just fine on the same RaspberryPi and gateway.  I've even considered having Domoticz forward the messages on to Home Assistant! :)</p>
<p dir="auto">Could really use some help before I throw the damn Arduino out completely and buy a PiZero to see if I can use that!</p>
]]></description><link>https://forum.mysensors.org/post/84124</link><guid isPermaLink="true">https://forum.mysensors.org/post/84124</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sat, 20 Jan 2018 11:58:16 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Tue, 16 Jan 2018 23:43:57 GMT]]></title><description><![CDATA[<p dir="auto">Damn it still not managed to get this working properly :(</p>
<p dir="auto">This is an extract from the log:</p>
<pre><code>2018-01-16 21:56:57 INFO (MainThread) [homeassistant.loader] Loaded sensor.mysensors from homeassistant.components.sensor.mysensors
2018-01-16 21:56:57 INFO (MainThread) [homeassistant.loader] Loaded mysensors from homeassistant.components.mysensors
2018-01-16 21:56:57 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mysensors
2018-01-16 21:56:58 INFO (MainThread) [homeassistant.setup] Setting up mysensors
2018-01-16 21:56:58 INFO (MainThread) [homeassistant.setup] Setup of domain mysensors took 0.4 seconds.
2018-01-16 21:56:58 INFO (MainThread) [homeassistant.core] Bus:Handling &lt;Event component_loaded[L]: component=mysensors&gt;
2018-01-16 21:57:00 DEBUG (Thread-7) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.1'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] Trying to connect to /dev/ttyUSB0
2018-01-16 21:57:00 INFO (MainThread) [homeassistant.core] Bus:Handling &lt;Event platform_discovered[L]: service=load_platform.sensor, discovered=name=mysensors, devices=[(1843074256, 1, 1, 38), (1843074256, 1, 1, 39)], platform=mysensors&gt;
2018-01-16 21:57:00 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.mysensors
2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] /dev/ttyUSB0 is open...
2018-01-16 21:57:00 INFO (Thread-2) [homeassistant.components.mysensors] Adding new devices: [&lt;Entity Battery Charger 1: None&gt;, &lt;Entity Battery Charger 1: None&gt;]
2018-01-16 21:57:00 INFO (Thread-14) [mysensors.gateway_serial] Connected to /dev/ttyUSB0
2018-01-16 21:57:00 DEBUG (Thread-12) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:00 DEBUG (Thread-12) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
2018-01-16 21:57:00 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:00 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
2018-01-16 21:57:03 WARNING (Thread-14) [mysensors] Error decoding message from gateway, bad data received: 0=1,c=1,t=38,pt=7,l=5,sg=0:3.6
2018-01-16 21:57:03 WARNING (Thread-14) [mysensors] Not a valid message:
2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Node update: node 1 child 1
2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.1'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-01-16 21:57:03 DEBUG (Thread-9) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:03 DEBUG (Thread-9) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
2018-01-16 21:57:03 DEBUG (Thread-14) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,1-1-0,s=1,c=1,t=39,pt=7,l=5,sg=0:8.2
2018-01-16 21:57:03 DEBUG (Thread-7) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:03 DEBUG (Thread-7) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.1
2018-01-16 21:57:03 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.2'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-01-16 21:57:03 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:03 DEBUG (Thread-4) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
2018-01-16 21:57:03 DEBUG (Thread-8) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:03 DEBUG (Thread-8) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
2018-01-16 21:57:08 DEBUG (Thread-14) [mysensors] n:0 c:255 t:3 s:9 p:TSF:MSG:READ,1-1-0,s=1,c=1,t=38,pt=7,l=5,sg=0:3.6
2018-01-16 21:57:08 DEBUG (Thread-14) [homeassistant.components.mysensors] Node update: node 1 child 1
2018-01-16 21:57:08 DEBUG (Thread-14) [homeassistant.components.mysensors] Invalid values: {38: '3.6', 39: '8.2'}: sensor platform: node 1 child 1: S_MULTIMETER requires value_type V_IMPEDANCE @ data[14]
2018-01-16 21:57:08 DEBUG (Thread-5) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
2018-01-16 21:57:08 DEBUG (Thread-5) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 39, value = 8.2
</code></pre>
<p dir="auto">To me, this looks like it should be working. There are some invalid data messages  but there are also valid ones which appear to post valid sensor data.</p>
<p dir="auto">This looks like a valid update for example:</p>
<pre><code>2018-01-16 21:57:03 DEBUG (Thread-7) [homeassistant.components.mysensors] Entity update: Battery Charger 1: value_type 38, value = 3.6
</code></pre>
<p dir="auto">Current configuration in HASS:</p>
  gateways:
    - device: '/dev/ttyUSB0'
      persistence_file: '/home/homeassistant/.homeassistant/mysensors.json'
      baud_rate: 115200
      nodes:
         1:
  optimistic: false
  persistence: true
  retain: true
  version: 2
</code></pre>
<p dir="auto">Maybe I need to define the sensors here?!  I've tried updating pyserial but whatever I do (including uninstall and reinstall) it still seems to remain on 2.6.</p>
]]></description><link>https://forum.mysensors.org/post/83966</link><guid isPermaLink="true">https://forum.mysensors.org/post/83966</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Tue, 16 Jan 2018 23:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sun, 14 Jan 2018 11:01:45 GMT]]></title><description><![CDATA[<p dir="auto">Ok that seems to have worked... once...</p>
<p dir="auto">The sensors appeared in HASS but are not now updating, getting these errors:</p>
<p dir="auto"><img src="/assets/uploads/files/1515927677437-87da4b70-8634-46c1-a26a-b671bab453b0-image-resized.png" alt="0_1515927681773_87da4b70-8634-46c1-a26a-b671bab453b0-image.png" class="img-markdown  img-fluid" /></p>
<p dir="auto">I think I read another thread about Pyserial being an issue so wondering if this is causing these errors..</p>
]]></description><link>https://forum.mysensors.org/post/83741</link><guid isPermaLink="true">https://forum.mysensors.org/post/83741</guid><dc:creator><![CDATA[David Pinnock]]></dc:creator><pubDate>Sun, 14 Jan 2018 11:01:45 GMT</pubDate></item><item><title><![CDATA[Reply to Invalid Message, Sensor not being added on Sat, 13 Jan 2018 22:44:53 GMT]]></title><description><![CDATA[<p dir="auto">What version of mysensors are you using? Your sketch is using a pre 2.0 library api. I suggest you use the latest mysensors library version and update your sketch to use the current api.</p>
<p dir="auto">Read the api documentation on the mysensors site for more info.</p>
]]></description><link>https://forum.mysensors.org/post/83723</link><guid isPermaLink="true">https://forum.mysensors.org/post/83723</guid><dc:creator><![CDATA[martinhjelmare]]></dc:creator><pubDate>Sat, 13 Jan 2018 22:44:53 GMT</pubDate></item></channel></rss>
