MySensor Stopped communicating after NRF upgrade
  • Hey, I was successfully using my sensor along with home assistant for my home using cheap Chinese SMD type nrf with a ceramic antenna. The problem with them was that the packet loss due to signal strength across my hallway was significant. So after going through some post in the forum, I decided to upgrade to a better module which had shielding and genuine nrf chip. Now the problem is that since I changed to a better module I am constantly getting NACK with the old chips ( might be because genuine ones won't communicate with fakes. ) and getting NACK with the genuine chips on both my raspberry pi gateway and Arduino sensor nodes. I have tried two different antenna one is 2.5db Omni directional one and the other is Airgain n2420S.
    The module I was using earlier
    NRF 24 Ceramic Antenna
    The Upgraded Module
    NiceRf NRF24
    AirGain Antenna
  • Mod
    Assuming you are using voltage regulator and correct cap on radio vcc, did you try to lower the TX power? Are you getting NACKs every time on on random packets?
  • Yes, I am using a 10uf Tantalum and 100nF ceramic caps for NRF, along with Proper supply. It was working great with the old modules. I am getting constant NACK but I noticed one thing when I touch the base of the antenna it transmits data sometimes.
  • Mod
    I can't help much as I have never used those modules, I have the ones with trace antenna or the other pa lna with 20+cm antenna
  • Could this be a grounding issue with the antenna as it works when I touch the antenna both the PCB one and the Omni directional one.
  • Mod
    If it is a grounding issue you can check it with the multimeter
  • @ayuclack It does no harm to check grounding in any case, but this sounds more like an inadequate antenna... By touching an antenna you essentially become an extension of it, or react with it capacitatively where it is insulated.
  • Ok so with the same antenna and Raspberry Pi hub I am able to get my custom designed RGB controller to work flawless but when I try to do same with an Arduino nano and nrf24L01 module I get NACKS.
    Here My sensor Debug in NANO
     TSM:INIT
    4 TSF:WUR:MS=0
    11 TSM:INIT:TSP OK
    12 TSM:FPAR
    15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2022 !TSM:FPAR:NO REPLY
    2024 TSM:FPAR
    2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4034 !TSM:FPAR:NO REPLY
    4036 TSM:FPAR
    4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6046 !TSM:FPAR:NO REPLY
    6048 TSM:FPAR
    6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8058 !TSM:FPAR:FAIL
    8059 TSM:FAIL:CNT=1
    8061 TSM:FAIL:PDT
    18065 TSM:FAIL:RE-INIT
    18067 TSM:INIT
    18074 TSM:INIT:TSP OK
    18076 TSM:FPAR
    18078 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    20086 !TSM:FPAR:NO REPLY
    20088 TSM:FPAR
    20090 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    22099 !TSM:FPAR:NO REPLY
    22102 TSM:FPAR
    22104 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    24112 !TSM:FPAR:NO REPLY
    24114 TSM:FPAR
    24116 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    26124 !TSM:FPAR:FAIL
    26125 TSM:FAIL:CNT=2
    26127 TSM:FAIL:PDT
    36130 TSM:FAIL:RE-INIT
    36132 TSM:INIT
    36140 TSM:INIT:TSP OK
    36142 TSM:FPAR
    36144 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    38152 !TSM:FPAR:NO REPLY
    38154 TSM:FPAR
    38156 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    40164 !TSM:FPAR:NO REPLY
    40166 TSM:FPAR
    40168 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    42176 !TSM:FPAR:NO REPLY
    42178 TSM:FPAR
    42180 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    44188 !TSM:FPAR:FAIL
    44189 TSM:FAIL:CNT=3
    44191 TSM:FAIL:PDT
    54194 TSM:FAIL:RE-INIT
    54196 TSM:INIT
    54203 TSM:INIT:TSP OK
    54205 TSM:FPAR
    54207 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    56215 !TSM:FPAR:NO REPLY
    56217 TSM:FPAR
    56219 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    58227 !TSM:FPAR:NO REPLY
    58229 TSM:FPAR
    58231 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    60239 !TSM:FPAR:NO REPLY
    60241 TSM:FPAR
    60243 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    62252 !TSM:FPAR:FAIL
    62253 TSM:FAIL:CNT=4
    62255 TSM:FAIL:PDT
    72258 TSM:FAIL:RE-INIT
    72260 TSM:INIT
    72267 TSM:INIT:TSP OK
    72269 TSM:FPAR
    72271 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    74280 !TSM:FPAR:NO REPLY
    74283 TSM:FPAR
    74285 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    76293 !TSM:FPAR:NO REPLY
    76295 TSM:FPAR
    76297 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    78305 !TSM:FPAR:NO REPLY
    78307 TSM:FPAR
    78309 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    80317 !TSM:FPAR:FAIL
    80318 TSM:FAIL:CNT=5
    80320 TSM:FAIL:PDT
    90323 TSM:FAIL:RE-INIT
    90326 TSM:INIT
    90333 TSM:INIT:TSP OK
    90335 TSM:FPAR
    90337 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    92345 !TSM:FPAR:NO REPLY
    92347 TSM:FPAR
    92349 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    94357 !TSM:FPAR:NO REPLY
    94359 TSM:FPAR
    94361 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    96369 !TSM:FPAR:NO REPLY
    96371 TSM:FPAR
    96373 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    98381 !TSM:FPAR:FAIL
    98382 TSM:FAIL:CNT=6
    98384 TSM:FAIL:PDT
    108387 TSM:FAIL:RE-INIT
    108389 TSM:INIT
    108396 TSM:INIT:TSP OK
    108398 TSM:FPAR
    108401 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    110408 !TSM:FPAR:NO REPLY
    110410 TSM:FPAR
    110413 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    112420 !TSM:FPAR:NO REPLY
    112422 TSM:FPAR
    112425 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    114433 !TSM:FPAR:NO REPLY
    114435 TSM:FPAR
    114438 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    116445 !TSM:FPAR:FAIL
    116447 TSM:FAIL:CNT=7
    116449 TSM:FAIL:PDT
    176452 TSM:FAIL:RE-INIT
    176454 TSM:INIT
    176461 TSM:INIT:TSP OK
    176463 TSM:FPAR
    176466 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    178475 !TSM:FPAR:NO REPLY
    178477 TSM:FPAR
    178480 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    180487 !TSM:FPAR:NO REPLY
    180489 TSM:FPAR
    180492 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    182499 !TSM:FPAR:NO REPLY
    182501 TSM:FPAR
    182504 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    184511 !TSM:FPAR:FAIL
    184513 TSM:FAIL:CNT=7
    184515 TSM:FAIL:PDT
    244518 TSM:FAIL:RE-INIT
    244520 TSM:INIT
    244528 TSM:INIT:TSP OK
    244530 TSM:FPAR
    244533 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    246540 !TSM:FPAR:NO REPLY
    246542 TSM:FPAR
    246545 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    248552 !TSM:FPAR:NO REPLY
    248554 TSM:FPAR
    248557 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    250564 !TSM:FPAR:NO REPLY
    250566 TSM:FPAR
    250569 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    252576 !TSM:FPAR:FAIL
    252578 TSM:FAIL:CNT=7
    252580 TSM:FAIL:PDT
    312583 TSM:FAIL:RE-INIT
    312585 TSM:INIT
    312592 TSM:INIT:TSP OK
    312594 TSM:FPAR
    312597 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    314604 !TSM:FPAR:NO REPLY
    314606 TSM:FPAR
    314609 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    316616 !TSM:FPAR:NO REPLY
    316618 TSM:FPAR
    316621 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    318628 !TSM:FPAR:NO REPLY
    318630 TSM:FPAR
    318633 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    320641 !TSM:FPAR:FAIL
    320643 TSM:FAIL:CNT=7
    320645 TSM:FAIL:PDT
    Here MySensor Gateway Debug
    pi@hassbian:~/MySensors $ sudo ./bin/mysgw -d
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-rc.2
    mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.2
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: Listening for connections on 0.0.0.0:5003
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: New connection from 127.0.0.1
    mysgw: GWT:TSA:C=0,CONNECTED
    mysgw: GWT:RFC:C=0,MSG=0;255;3;0;2;
    mysgw: GWT:RFC:C=0,MSG=255;255;3;0;20;
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: GWT:RFC:C=0,MSG=14;2;1;0;2;0
    mysgw: !TSF:MSG:SEND,0-0-14-14,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: GWT:RFC:C=0,MSG=13;4;1;0;2;0
    mysgw: !TSF:MSG:SEND,0-0-13-13,s=4,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
    mysgw: GWT:RFC:C=0,MSG=13;3;1;0;2;0
    mysgw: !TSF:MSG:SEND,0-0-13-13,s=3,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
    mysgw: GWT:RFC:C=0,MSG=13;2;1;0;2;0
    mysgw: !TSF:MSG:SEND,0-0-13-13,s=2,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:CKU:OK
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:BC
  • Mod
    You forgot to set node ID on the nano
  • @gohan said in MySensor Stopped communicating after NRF upgrade:
    My Node ID is set via HomeAssistant with Mysensor. I tried manually setting the node ID but same response. I did a RF24 pingpair_ack test using two nano and it works fine. Dont know why its not working with mysensor.
  • So, it just worked after I did an EPROM wipe and reflashed it again. Don't know if it was a hardware problem or just a minor firmware one.
  • Mod
    Maybe some data got corrupted in eeprom...
7.4k
8.2k
89.0k
Looks like your connection to MySensors Forum was lost, please wait while we try to reconnect.
