<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor]]></title><description><![CDATA[<p dir="auto">Ideas please?</p>
<p dir="auto">I'm brand new so this could be obvious or I may have missed config steps or anything.<br />
I've built:</p>
<ul>
<li>ESP8266/NodeMCU+NRF24L01 Gateway</li>
<li>Nano+NRF24L01 Sensor</li>
</ul>
<p dir="auto">I can run blink on both. I can connect gateway to my LAN network but I can't get sensor node to to be seen by gateway over NRF24L01 radios.</p>
<p dir="auto">I am looking for any simple code I can load on Gateway and Sensor to prove out/troubleshoot communications.</p>
<p dir="auto">My gateway boots and connects to LAN but never shows any signs of NRF24L01 comms.</p>
<p dir="auto">My Sensor is currently running MockSensor Example. The output is just the following over and over:</p>
<pre><code>16 MCO:BGN:INIT NODE,CP=RNNNA---,VER=2.2.0
25 TSM:INIT
26 TSF:WUR:MS=0
33 !TSM:INIT:TSP FAIL
35 TSM:FAIL:CNT=1
36 TSM:FAIL:DIS
38 TSF:TDI:TSL
10040 TSM:FAIL:RE-INIT
10042 TSM:INIT
10048 !TSM:INIT:TSP FAIL
10051 TSM:FAIL:CNT=2
10052 TSM:FAIL:DIS
10054 TSF:TDI:TSL
</code></pre>
<p dir="auto">Do I need to edit Config somewhere (the MockSensor has a device ID entry built in of 254 so I haven't done anything to that sketch.</p>
<p dir="auto">Ideas, please.</p>
<p dir="auto">Long term I will send the data (dallas temperature) over HTTP to Node-RED but don't trouble yourself with any of that - right now I JUST need to get NRF24L01 comms working - even with fake data.</p>
]]></description><link>https://forum.mysensors.org/topic/8970/getting-started-need-a-simple-test-config-for-esp8266-nodemcu-nrf24l01-gateway-and-nano-nrf24l01-sensor</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 09:32:50 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/8970.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 04 Feb 2018 20:03:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor on Mon, 19 Feb 2018 02:58:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mfalkvidd" aria-label="Profile: mfalkvidd">@<bdi>mfalkvidd</bdi></a> yes, thank you and everyone - I am all fixed and working now.<br />
I am giving 3.3v to the radio with a separate voltage regulator.</p>
]]></description><link>https://forum.mysensors.org/post/85886</link><guid isPermaLink="true">https://forum.mysensors.org/post/85886</guid><dc:creator><![CDATA[Jeff Tapia]]></dc:creator><pubDate>Mon, 19 Feb 2018 02:58:16 GMT</pubDate></item><item><title><![CDATA[Reply to Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor on Mon, 05 Feb 2018 07:34:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jeff-tapia" aria-label="Profile: jeff-tapia">@<bdi>jeff-tapia</bdi></a> welcome to the forum :)</p>
<p dir="auto">The <a href="https://www.mysensors.org/build/parser" rel="nofollow ugc">log parser</a> can be useful when interpreting the logs.</p>
<p dir="auto">Just to check, becuause it is a common mistake: are you giving 3.3V power to the radio? It can not handle 5V (on vcc, data pins are ok with 5V).</p>
]]></description><link>https://forum.mysensors.org/post/85090</link><guid isPermaLink="true">https://forum.mysensors.org/post/85090</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Mon, 05 Feb 2018 07:34:45 GMT</pubDate></item><item><title><![CDATA[Reply to Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor on Sun, 04 Feb 2018 22:16:21 GMT]]></title><description><![CDATA[<p dir="auto">Thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/gohan" aria-label="Profile: gohan">@<bdi>gohan</bdi></a> !</p>
<p dir="auto">In the end - it was wiring!</p>
<p dir="auto">I first swapped out the NRF24L01 for another one - no good.</p>
<p dir="auto">I then realized I wired the NRF24L01 to the Nano as if the Nano was a Micro Pro (as in the Micro Pro diagram - did I mention newbie?)</p>
<p dir="auto">I fixed that but it still didn't work but...</p>
<p dir="auto">I probably burned out the first 2 NRF24L01 boards because I then replaced with another brand new board on the new wiring and all is good,.</p>
<p dir="auto">I think swapping NRF while still bad wiring just burned out additional boards.</p>
<p dir="auto">I get it now - thank you.,</p>
]]></description><link>https://forum.mysensors.org/post/85073</link><guid isPermaLink="true">https://forum.mysensors.org/post/85073</guid><dc:creator><![CDATA[Jeff Tapia]]></dc:creator><pubDate>Sun, 04 Feb 2018 22:16:21 GMT</pubDate></item><item><title><![CDATA[Reply to Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor on Sun, 04 Feb 2018 21:34:43 GMT]]></title><description><![CDATA[<p dir="auto">I didn't know what the output meant (except perhaps "FAIL").</p>
<p dir="auto">Thx, i will try rewiring .</p>
]]></description><link>https://forum.mysensors.org/post/85068</link><guid isPermaLink="true">https://forum.mysensors.org/post/85068</guid><dc:creator><![CDATA[Jeff Tapia]]></dc:creator><pubDate>Sun, 04 Feb 2018 21:34:43 GMT</pubDate></item><item><title><![CDATA[Reply to Getting Started - need a simple test config for ESP8266/NodeMCU+NRF24L01 Gateway and Nano+NRF24L01 Sensor on Sun, 04 Feb 2018 21:30:59 GMT]]></title><description><![CDATA[<p dir="auto">That looks a bad wiring of the radio</p>
]]></description><link>https://forum.mysensors.org/post/85067</link><guid isPermaLink="true">https://forum.mysensors.org/post/85067</guid><dc:creator><![CDATA[gohan]]></dc:creator><pubDate>Sun, 04 Feb 2018 21:30:59 GMT</pubDate></item></channel></rss>
