<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[vera ,the green dead brick]]></title><description><![CDATA[<p dir="auto">hi.  my vera just died. i'm changing radios on my mysensors network,from nrf24 to rfm69 and when i connect a new gw with arduino 3.3 volts and new radio, serial port wont detect my gw,so i restart vera.  it enters in a restart loop... it already happened a few months after one update, and i recover it by following this steps: <a href="http://wiki.mios.com/index.php/Firmware_Flash_VeraLite" rel="nofollow ugc">http://wiki.mios.com/index.php/Firmware_Flash_VeraLite</a></p>
<p dir="auto">but now after flash it with sucess (it says), restart,and no light at all. just flash all lights for a second when plug the power cable and then....   nothing.<br />
no lights ,no response to reset and power in, no response to any ip.<br />
Happend to any of you already?    i think its really bricked and i have to move to raspberry and razberry(zwave shield)</p>
]]></description><link>https://forum.mysensors.org/topic/9093/vera-the-green-dead-brick</link><generator>RSS for Node</generator><lastBuildDate>Fri, 16 Oct 2026 06:08:17 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9093.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 05 Mar 2018 14:25:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to vera ,the green dead brick on Wed, 07 Mar 2018 16:49:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tmaster" aria-label="Profile: tmaster">@<bdi>tmaster</bdi></a> The OpenHab website has some info about zwave shield(s) and Fibraro device compatibility here <a href="https://docs.openhab.org/addons/bindings/zwave1/readme.html#fibaro-door-contact-fgk-101" rel="nofollow ugc">https://docs.openhab.org/addons/bindings/zwave1/readme.html#fibaro-door-contact-fgk-101</a></p>
]]></description><link>https://forum.mysensors.org/post/86756</link><guid isPermaLink="true">https://forum.mysensors.org/post/86756</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Wed, 07 Mar 2018 16:49:52 GMT</pubDate></item><item><title><![CDATA[Reply to vera ,the green dead brick on Wed, 07 Mar 2018 14:32:02 GMT]]></title><description><![CDATA[<p dir="auto">Second support,if it won't enters in recover mode(press reset and power it) its dead(defective unit) . Nice term for;buy another.<br />
So i'm configuring Domoticz to give a try with mysensors.<br />
About fibaro zwave devices i'm thinking reverse engenniering vera zwave module and connect it to domoticz. Its that possible?<br />
Vera lite have the z-wave part at one corner of the board. And  its a zw0302(3rt geneneration) and an EPROM. If i connect tx,rx,gng and vcc from the chip to raspberry,i have an zwave shield. Or will not work because zwave firmware on the z-wave chip?</p>
]]></description><link>https://forum.mysensors.org/post/86741</link><guid isPermaLink="true">https://forum.mysensors.org/post/86741</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Wed, 07 Mar 2018 14:32:02 GMT</pubDate></item><item><title><![CDATA[Reply to vera ,the green dead brick on Tue, 06 Mar 2018 10:25:23 GMT]]></title><description><![CDATA[<p dir="auto">I didn't know about razberry limitations. i only have fibaro 222 modules(windows outside aluminium shutters). And i only want that zwave module.The  rest are mysensors  sensors. Since i found them ,now i don't change the fact that i know how they work and how to repair it ,against the fact of buy already made and get stuck..like happens with vera know!</p>
]]></description><link>https://forum.mysensors.org/post/86668</link><guid isPermaLink="true">https://forum.mysensors.org/post/86668</guid><dc:creator><![CDATA[Tmaster]]></dc:creator><pubDate>Tue, 06 Mar 2018 10:25:23 GMT</pubDate></item><item><title><![CDATA[Reply to vera ,the green dead brick on Tue, 06 Mar 2018 02:31:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tmaster" aria-label="Profile: tmaster">@<bdi>tmaster</bdi></a> You'll probably have better luck posting to the <a href="http://forum.micasaverde.com" rel="nofollow ugc">Vera forums</a> or sending an email to <a href="mailto:support@getvera.com" rel="nofollow ugc">support@getvera.com</a>.</p>
<p dir="auto">Also, depending upon your z-wave nodes, you may find that the z-wave shield doesn't work reliably with all nodes because it uses a reverse-engineered protocol with known limitations to avoid licensing issues.</p>
]]></description><link>https://forum.mysensors.org/post/86656</link><guid isPermaLink="true">https://forum.mysensors.org/post/86656</guid><dc:creator><![CDATA[blacey]]></dc:creator><pubDate>Tue, 06 Mar 2018 02:31:50 GMT</pubDate></item></channel></rss>
