<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Version 2.3.0 with RFM69HW - Problem communication]]></title><description><![CDATA[<p dir="auto">Hi<br />
Todaye i update from 2.2.0 version to 2.3.0 on my Home Assistant 0.71.0<br />
After update to 2.3.0 i have a problem with communication on radio RFM69HW. Sometime lost communication and no reaction. When come back to 2.2.0 all is ok. Please help me....</p>
]]></description><link>https://forum.mysensors.org/topic/9449/version-2-3-0-with-rfm69hw-problem-communication</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Mar 2026 00:21:00 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9449.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Jun 2018 16:22:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Version 2.3.0 with RFM69HW - Problem communication on Tue, 19 Jun 2018 16:26:14 GMT]]></title><description><![CDATA[<p dir="auto">This is my sketch</p>
<pre><code>// Enable debug prints to serial monitor
#define MY_RADIO_RFM69
#define MY_IS_RFM69HW
#define RFM69_868MH
#define MY_RFM69_NEW_DRIVER
#define MY_REPEATER_FEATURE
//#define MY_RFM69_CSMA_LIMIT_DBM (-85)
// uncomment if we want to manually assign an ID
#define MY_NODE_ID 1
#include &lt;Bounce2.h&gt;
#include &lt;MySensors.h&gt;
#include &lt;SPI.h&gt;
#define BUTTON_UP_PIN 3  // Arduino Digital I/O pin number for up button
#define BUTTON_DOWN_PIN 4  // Arduino Digital I/O pin number for down button
//#define BUTTON_STOP_PIN 5  // Arduino Digital I/O pin number for stop button
//#define RELAY_DIR_PIN 6  // Arduino Digital I/O pin number for direction relay
//#define RELAY_POWER_PIN 7  // Arduino Digital I/O pin number for power relay
#define RELAY_UP_PIN 5
#define RELAY_DOWN_PIN 6
#define RELAY_ON 0
#define RELAY_OFF 1
//#define RELAY_DOWN 1
//#define RELAY_UP 0
#define DIRECTION_DOWN 0
#define DIRECTION_UP 1
#define SKETCH_NAME "Roleta w sypialni"
#define SKETCH_VER "2.3"
#define CHILD_ID_COVER 0   // sensor Id of the sensor child
#define STATE_UP 100 // 100 is open - up
#define STATE_DOWN 0 // 0 is closed - down
//#define CHILD_ID_CALIBRATE 1   // sensor Id of the sensor child to calibrate
#define CHILD_ID_SET 1   // sensor Id of the sensor child to init the roll time
#define PRESENT_MESSAGE "Rolety dla Home Assistant"
const int LEVELS = 100; //the number of levels
float rollTime = 20.0; //the overall rolling time of the shutter
const bool IS_ACK = false; //is to acknowlage
static bool initial_state_sent = false;//for hass we need at list one state send at begining
// debouncing parameters
int value = 0;
int oldValueUp = 0;
int oldValueDown = 0;
int oldValueStop = 0;
//static unsigned long last_interrupt_time_up = 0;
//static unsigned long last_interrupt_time_down = 0;
//static unsigned long debounce_time = 200;
Bounce debouncerUp = Bounce();
Bounce debouncerDown = Bounce();
Bounce debouncerStop = Bounce();
// shutter position parameters
float timeOneLevel = rollTime / LEVELS;
int requestedShutterLevel = 0;
int currentShutterLevel = 0;
unsigned long lastLevelTime = 0;
bool isMoving = false;
int directionUpDown;
bool calibrateDown;
bool calibrateUp;
unsigned long calibrationStartTime;
float calibrationTime = 5.0;
bool calibratedDown;
bool calibratedUp;
enum CoverState {
  STOP,
  UP, // Window covering. Up.
  DOWN, // Window covering. Down.
static int coverState = STOP;
MyMessage msgUp(CHILD_ID_COVER, V_UP);
MyMessage msgDown(CHILD_ID_COVER, V_DOWN);
MyMessage msgStop(CHILD_ID_COVER, V_STOP);
MyMessage msgPercentage(CHILD_ID_COVER, V_PERCENTAGE);
//MyMessage msgCode(CHILD_ID_SET, V_IR_SEND);
void sendState() {
  // Send current state and status to gateway.
//  send(msgUp.set(coverState == UP));
//  send(msgDown.set(coverState == DOWN));
//  send(msgStop.set(coverState == STOP));
  send(msgPercentage.set(currentShutterLevel));
void shuttersUp(void) {
  #ifdef MY_DEBUG
  Serial.println("Shutters going up");
  if (digitalRead(RELAY_DOWN_PIN) == RELAY_ON) {
    digitalWrite(RELAY_DOWN_PIN, RELAY_OFF);
    wait(50);
  digitalWrite(RELAY_UP_PIN, RELAY_ON);
  directionUpDown = DIRECTION_UP;
  isMoving = true;
  coverState = UP;
  sendState();
void shuttersDown(void) {
  #ifdef MY_DEBUG
  Serial.println("Shutters going down");
  if (digitalRead(RELAY_UP_PIN) == RELAY_ON) {
    digitalWrite(RELAY_UP_PIN, RELAY_OFF);
    wait(50);
  digitalWrite(RELAY_DOWN_PIN, RELAY_ON);
  directionUpDown = DIRECTION_DOWN;
  isMoving = true;
  coverState = DOWN;
  sendState();
void shuttersHalt(void) {
#ifdef MY_DEBUG
  Serial.println("Shutters halted");
  isMoving = false;
  requestedShutterLevel = currentShutterLevel;
#ifdef MY_DEBUG
  Serial.println("saving state to: ");
  Serial.println(String(currentShutterLevel));
  saveState(CHILD_ID_COVER, currentShutterLevel);
  coverState = STOP;
  sendState();
void changeShuttersLevel(int level) {
  int dir = (level &gt; currentShutterLevel) ? DIRECTION_UP : DIRECTION_DOWN;
  if (isMoving &amp;&amp; dir != directionUpDown) {
    shuttersHalt();
  requestedShutterLevel = level;
void initShutters() {
#ifdef MY_DEBUG
  Serial.println("Init Cover");
  shuttersUp();
  wait((rollTime + timeOneLevel * LEVELS) * 1000);
  currentShutterLevel = STATE_UP;
void receive(const MyMessage &amp;message) {
#ifdef MY_DEBUG
  Serial.println("recieved incomming message");
  Serial.println("Recieved message for sensor: ");
  Serial.println(String(message.sensor));
  Serial.println("Recieved message with type: ");
  Serial.println(String(message.type));
  if (message.sensor == CHILD_ID_COVER) {
    switch (message.type) {
      case V_UP:
        //Serial.println(", New status: V_UP");
        changeShuttersLevel(STATE_UP);
        //state = UP;
        //sendState();
        break;
      case V_DOWN:
        //Serial.println(", New status: V_DOWN");
        changeShuttersLevel(STATE_DOWN);
        //state = DOWN;
        //sendState();
        break;
      case V_STOP:
        //Serial.println(", New status: V_STOP");
        shuttersHalt();
        //state = IDLE;
        //sendState();
        break;
      case V_PERCENTAGE:
        //Serial.println(", New status: V_PERCENTAGE");
        //          if (!initial_state_sent) {
        //            #ifdef MY_DEBUG
        //            Serial.println("Receiving initial value from controller");
        //            #endif
        //            initial_state_sent = true;
        int per = message.getInt();
        if (per &gt; STATE_UP) {
          per = STATE_UP;
        changeShuttersLevel(per);
        //InitShutters(message.getInt());//send value &lt; 0 or &gt; 100 to calibrate
        //sendState();
        break;
else if (message.sensor ==  CHILD_ID_SET) {
    if (message.type == V_VAR1) {
      #ifdef MY_DEBUG
      Serial.println(", New status: V_VAR1, with payload: ");
      String strRollTime = message.getString();
      rollTime = strRollTime.toFloat();
      #ifdef MY_DEBUG
      Serial.println("rolltime value: ");
      Serial.println(String(rollTime));
      saveState(CHILD_ID_SET, rollTime);
#ifdef MY_DEBUG
  Serial.println("exiting incoming message");
  return;
void before() {
  // Setup the button
  pinMode(BUTTON_UP_PIN, INPUT_PULLUP);
  // Activate internal pull-up
//  digitalWrite(BUTTON_UP_PIN, HIGH);
  //  attachInterrupt(digitalPinToInterrupt(BUTTON_UP_PIN), upButtonPress, FALLING);
  pinMode(BUTTON_DOWN_PIN, INPUT_PULLUP);
//  digitalWrite(BUTTON_DOWN_PIN, HIGH);
  //  attachInterrupt(digitalPinToInterrupt(BUTTON_DOWN_PIN), downButtonPress, FALLING);
//  pinMode(BUTTON_STOP_PIN, INPUT_PULLUP);
//  digitalWrite(BUTTON_STOP_PIN, HIGH);
  debouncerUp.attach(BUTTON_UP_PIN);
  debouncerUp.interval(5);
  debouncerDown.attach(BUTTON_DOWN_PIN);
  debouncerDown.interval(5);
//  debouncerStop.attach(BUTTON_STOP_PIN);
//  debouncerStop.interval(5);
  pinMode(RELAY_UP_PIN, OUTPUT);
  pinMode(RELAY_DOWN_PIN, OUTPUT);
void presentation() {
  sendSketchInfo(SKETCH_NAME, SKETCH_VER);
  present(CHILD_ID_COVER, S_COVER, PRESENT_MESSAGE, IS_ACK);
  // present(CHILD_ID_SET, S_CUSTOM);
void setup(void) {
  //set up roll time if the saved value is not 255
  #ifdef MY_DEBUG
  Serial.println("getting rolltime from eeprom: ");
  float tmpRollTime = loadState(CHILD_ID_SET);
  if (tmpRollTime != 0xff) {
    rollTime = tmpRollTime;
  #ifdef MY_DEBUG
  int state = loadState(CHILD_ID_COVER);
  #ifdef MY_DEBUG
  Serial.println("getting state from eeprom: ");
  Serial.println(String(state));
//  if (state == 0xff) {
//    initShutters();
//  } else {
    currentShutterLevel = state;
    requestedShutterLevel = state;
void loop(void) {
#ifdef MY_DEBUG
    sendState();
   // send(msgCode.set('20.0'));
    //    #ifdef MY_DEBUG
    //    Serial.println("Requesting initial value from controller");
    //    #endif
    //    request(CHILD_ID_COVER, V_PERCENTAGE);
    //    wait(2000, C_SET, V_PERCENTAGE);
  debouncerUp.update();
  value = debouncerUp.read();
  if (value == 0 &amp;&amp; value != oldValueUp) {
    if(isMoving){
      shuttersHalt();
    else{
    calibrateUp = false;
    calibratedUp = false;
    //state = UP;
    //sendState();
  oldValueUp = value;
  debouncerDown.update();
  value = debouncerDown.read();
  if (value == 0 &amp;&amp; value != oldValueDown) {
    if(isMoving){
      shuttersHalt();
    else{
    calibrateDown = false;
    calibratedDown = false;
    //state = DOWN;
    //sendState();
  oldValueDown = value;
/*  debouncerStop.update();
  value = debouncerStop.read();
  if (value == 0 &amp;&amp; value != oldValueStop) {
    shuttersHalt();
    //state = IDLE;
    //sendState();
  oldValueStop = value;
  if(currentShutterLevel != 100)
  if(currentShutterLevel != 0)
  if (isMoving)
    unsigned long _now = millis();
    if (_now - lastLevelTime &gt;= timeOneLevel * 1000) {
      if (directionUpDown == DIRECTION_UP) {
        currentShutterLevel += 1;
      } else {
        currentShutterLevel -= 1;
      currentShutterLevel = constrain(currentShutterLevel, 0, 100);
      #ifdef MY_DEBUG
      Serial.println(String(requestedShutterLevel));
      lastLevelTime = millis();
    if (currentShutterLevel == requestedShutterLevel)
      if(currentShutterLevel == 0 &amp;&amp; !calibratedDown)
        if(calibrateDown == false)
          calibrateDown = true;
          calibrationStartTime = _now;
        else
          if(calibratedDown == false)
            if (_now - calibrationStartTime &gt;= calibrationTime * 1000)
             calibratedDown = true;
      else if (currentShutterLevel == 100 &amp;&amp; !calibratedUp)
        if(calibrateUp == false)
          calibrateUp = true;
        else
          if(calibratedUp == false)
             calibratedUp = true;
      else
        shuttersHalt();
  else
    if (requestedShutterLevel != currentShutterLevel)
      if (requestedShutterLevel &gt; currentShutterLevel) {
        shuttersUp();
      else {
        shuttersDown();
</code></pre>
]]></description><link>https://forum.mysensors.org/post/91079</link><guid isPermaLink="true">https://forum.mysensors.org/post/91079</guid><dc:creator><![CDATA[pepson]]></dc:creator><pubDate>Tue, 19 Jun 2018 16:26:14 GMT</pubDate></item></channel></rss>
