<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[The gateway to the Raspberry Pi does not give the node address.]]></title><description><![CDATA[<p dir="auto">Hello. Help to deal with the problem.<br />
The gateway to the Raspberry Pi does not give the node address.<br />
Radio NRF24 works fine, packets from the node come:</p>
<pre><code>Jun 20 17:10:58 INFO  Starting gateway...
Jun 20 17:10:58 INFO  Protocol version - 2.3.0
Jun 20 17:10:58 DEBUG MCO:BGN:INIT GW,CP=RNNGL-Q-,VER=2.3.0
Jun 20 17:10:58 DEBUG TSF:LRT:OK
Jun 20 17:10:58 DEBUG TSM:INIT
Jun 20 17:10:58 DEBUG TSF:WUR:MS=0
Jun 20 17:10:58 DEBUG TSM:INIT:TSP OK
Jun 20 17:10:58 DEBUG TSM:INIT:GW MODE
Jun 20 17:10:58 DEBUG TSM:READY:ID=0,PAR=0,DIS=0
Jun 20 17:10:58 DEBUG MCO:REG:NOT NEEDED
Jun 20 17:10:58 DEBUG MCO:BGN:STP
Jun 20 17:10:58 DEBUG MCO:BGN:INIT OK,TSP=1
Jun 20 17:10:58 DEBUG GWT:RMQ:MQTT RECONNECT
Jun 20 17:10:58 DEBUG connected to 127.0.0.1
Jun 20 17:10:58 DEBUG GWT:RMQ:MQTT CONNECTED
Jun 20 17:10:58 DEBUG GWT:TPS:TOPIC=mysensors-out/0/255/0/0/18,MSG SENT
Jun 20 17:11:21 DEBUG TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
Jun 20 17:11:21 DEBUG TSF:MSG:BC
Jun 20 17:11:21 DEBUG TSF:MSG:FPAR REQ,ID=255
Jun 20 17:11:21 DEBUG TSF:PNG:SEND,TO=0
Jun 20 17:11:21 DEBUG TSF:CKU:OK
Jun 20 17:11:21 DEBUG TSF:MSG:GWL OK
Jun 20 17:11:22 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
Jun 20 17:11:23 DEBUG TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
Jun 20 17:11:23 DEBUG TSF:MSG:BC
Jun 20 17:11:23 DEBUG TSF:MSG:FPAR REQ,ID=255
Jun 20 17:11:23 DEBUG TSF:CKU:OK,FCTRL
Jun 20 17:11:23 DEBUG TSF:MSG:GWL OK
Jun 20 17:11:24 DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
Jun 20 17:11:25 DEBUG TSF:MSG:READ,255-255-0,s=146,c=3,t=3,pt=0,l=0,sg=0:
Jun 20 17:11:25 DEBUG GWT:TPS:TOPIC=mysensors-out/255/146/3/0/3,MSG SENT
Jun 20 17:11:27 DEBUG TSF:MSG:READ,255-255-0,s=109,c=3,t=3,pt=0,l=0,sg=0:
Jun 20 17:11:27 DEBUG GWT:TPS:TOPIC=mysensors-out/255/109/3/0/3,MSG SENT
Jun 20 17:11:29 DEBUG TSF:MSG:READ,255-255-0,s=72,c=3,t=3,pt=0,l=0,sg=0:
Jun 20 17:11:29 DEBUG GWT:TPS:TOPIC=mysensors-out/255/72/3/0/3,MSG SENT
Jun 20 17:11:31 DEBUG TSF:MSG:READ,255-255-0,s=35,c=3,t=3,pt=0,l=0,sg=0:
Jun 20 17:11:31 DEBUG GWT:TPS:TOPIC=mysensors-out/255/35/3/0/3,MSG SENT
</code></pre>
<p dir="auto">If I install a "passive node", then the data begins to be transmitted</p>
]]></description><link>https://forum.mysensors.org/topic/9450/the-gateway-to-the-raspberry-pi-does-not-give-the-node-address</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 16:11:28 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9450.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Jun 2018 17:17:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to The gateway to the Raspberry Pi does not give the node address. on Wed, 20 Jun 2018 19:01:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/ksandr" aria-label="Profile: ksandr">@<bdi>ksandr</bdi></a>, welcome to the forum!</p>
<p dir="auto">Handing out node IDs is handled by the controller. If you haven't already, connect a controller to the gateway.</p>
]]></description><link>https://forum.mysensors.org/post/91117</link><guid isPermaLink="true">https://forum.mysensors.org/post/91117</guid><dc:creator><![CDATA[mfalkvidd]]></dc:creator><pubDate>Wed, 20 Jun 2018 19:01:46 GMT</pubDate></item></channel></rss>
