<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nemaxx smoke alarm WL2]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just wanted to share my findings so far for this smoke detector I'm currently working on in case somebody is interested.</p>
<p dir="auto">I bought 5 of them for ~40 EUR a year ago from <a href="http://amazon.de" rel="nofollow ugc">amazon.de</a> . They use a 9V battery + 3x 1.5V AA batteries. They are able to network over 433Mhz; if 1 alarm is triggered, they will all sound alarm. Amazon link is below:<br />
<a href="https://www.amazon.de/Nemaxx-Funkrauchmelder-Rauchmelder-Brandmelder-koppelbar/dp/B00EZCMFPC/ref=sr_1_2?ie=UTF8&amp;qid=1529688708&amp;sr=8-2&amp;keywords=nemaxx%2Bwl2&amp;th=1" rel="nofollow ugc">https://www.amazon.de/Nemaxx-Funkrauchmelder-Rauchmelder-Brandmelder-koppelbar/dp/B00EZCMFPC/ref=sr_1_2?ie=UTF8&amp;qid=1529688708&amp;sr=8-2&amp;keywords=nemaxx%2Bwl2&amp;th=1</a></p>
<p dir="auto">I did a quick analysis of the PCB and here are the findings:</p>
<ul>
<li>9V battery powers the smoke detector and piezzo alarm part.</li>
<li>3x 1.5V AA batteries powers  a seperate MCU +  flash memory through a 3.3V LDO regulator.</li>
<li>The MCU seems responsible for user interface (buttons and leds) and communications. It integrates with the smoke detector part.</li>
<li>MCU chip is em78p156el</li>
<li>When the alarm is activated, pin P64 is pulled low for the duration of the alarm.</li>
</ul>
<p dir="auto">This makes it pretty easy to turn into a MySensors device. There is already a power source + LDO regulator with 3.3V output. Detecting the alarm activating / deactivating is very straightforward using the P64 pin.</p>
<p dir="auto">I'm only hesitating if I should use the LDO regulator outputs directly or rather add my own.</p>
<p dir="auto"><img src="/assets/uploads/files/1529692684274-pins-resized.png" alt="1_1529692669044_pins.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1529692676793-img_20180622_191743-resized.jpg" alt="0_1529692669044_IMG_20180622_191743.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mysensors.org/topic/9453/nemaxx-smoke-alarm-wl2</link><generator>RSS for Node</generator><lastBuildDate>Sat, 05 Sep 2026 08:15:57 GMT</lastBuildDate><atom:link href="https://forum.mysensors.org/topic/9453.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jun 2018 18:43:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nemaxx smoke alarm WL2 on Mon, 25 Jun 2018 07:49:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freynder" aria-label="Profile: freynder">@<bdi>freynder</bdi></a> it is different. I don't know if they try to connect to each other and if some having issues with that it drains the battery.</p>
]]></description><link>https://forum.mysensors.org/post/91225</link><guid isPermaLink="true">https://forum.mysensors.org/post/91225</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Mon, 25 Jun 2018 07:49:32 GMT</pubDate></item><item><title><![CDATA[Reply to Nemaxx smoke alarm WL2 on Mon, 25 Jun 2018 05:43:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sundberg84" aria-label="Profile: sundberg84">@<bdi>sundberg84</bdi></a> Interestingly, the 9V battery ran out on me after a year. I'm now replacing it with an amazon basics battery. So far all 5 still have their 3xAA's running. How long before yours run out?</p>
]]></description><link>https://forum.mysensors.org/post/91224</link><guid isPermaLink="true">https://forum.mysensors.org/post/91224</guid><dc:creator><![CDATA[freynder]]></dc:creator><pubDate>Mon, 25 Jun 2018 05:43:11 GMT</pubDate></item><item><title><![CDATA[Reply to Nemaxx smoke alarm WL2 on Sat, 23 Jun 2018 12:58:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/freynder" aria-label="Profile: freynder">@<bdi>freynder</bdi></a> nice work. I have these as well and the 3xaa runs out pretty fast for me so a good hack to give it a longer life would be interesting.</p>
]]></description><link>https://forum.mysensors.org/post/91190</link><guid isPermaLink="true">https://forum.mysensors.org/post/91190</guid><dc:creator><![CDATA[sundberg84]]></dc:creator><pubDate>Sat, 23 Jun 2018 12:58:19 GMT</pubDate></item></channel></rss>
